PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Upper Valve cover oil leak
  2. How much PAG oil goes into the r55/r56 AC system?
  3. How to reset r55/r56 Check Engine Light?
  4. Random CEL then clears O_o
  5. 2008 Stock Clubman rough idle
  6. HELP !! P0720 and P0715 codes
  7. Clutch feels stuck Open
  8. 2010 R56 Won't start - low tire and yellow check engine light on
  9. Accessory Belt 2011 R57 advice needed!!!!
  10. Air intake part ID needed
  11. 2011 Mini Cooper S N18 Engine no Heat
  12. N14: No signal from coolant temp sensor(s)? Fuse?
  13. OBD Scanners, which one?!?
  14. 07 mini cooper n12 cel on
  15. P0302 this morning
  16. High pitch squeal
  17. Check engine light issues (R55)
  18. PCV Oil Leak
  19. R56 mcs outside air temp sensor faulty
  20. Thermostat leaking?
  21. 2009 cooper water leak
  22. Yellow DTS failure light after pothole: worry?
  23. why does the thermostat fail?
  24. coolant leak
  25. Top Ten Cars Most likely to be Dumped!!
  26. Coolant temp low after changing thermostat
  27. Help diagnose coolant leak
  28. R56 Windshield Wipers Won't Shut Off!!
  29. Air bag light on with codes.
  30. Found damaged O ring in oil filter housing
  31. Odd feeling in 4th...
  32. Gp2 turbo installed and now having problems, HELP
  33. A/C issue. Please Help
  34. Rear Brake Lights - Clubman
  35. Blue Smoke from Exhaust
  36. limp mode (Safe Mode) how to fix it
  37. Boost / Vacuum readings out of sorts?
  38. Air conditioner compressor noise (rattle)
  39. Lower outer ball joint torque specs
  40. 2007 Mini Cooper rough idle, P0014 & P0015 Codes
  41. Shift lock delay on cold start?
  42. Fuel Gauge strange behavior
  43. R56 - changed thermostat, now cant shift into drive (need help!)
  44. Whining noise at idle
  45. Increased emissions
  46. Mini Cooper base issues @ 98K
  47. Horrific and sudden noise from all speakers.
  48. Mirror gasket in pieces
  49. Battery died...now have problems...even with new battery
  50. Help! Noises!
  51. Warning light not going off
  52. P0597, comes up to temp normal
  53. Shaking when going in reverse.
  54. Coolant leak R56 New Owner
  55. Help New Owner
  56. How many miles on your R56, and what issues have you had?
  57. Recently bought an R56 with 53k miles. Need some help...
  58. 2010 MCS Passenger Seat Airbag Sensor
  59. diverter valve problem. Tear in Diaphragm
  60. P0128 Code after replacing thermostat?
  61. loud engine ticking problems/rough idle
  62. R56 Cooper Base clutch/transmission problem?
  63. Tail light hyper flash
  64. bought my mini 4 days ago and i have timing concerns and questions
  65. R56 Noise when started and turned off
  66. pano sunroof won't open. Grinding noise. Took motor out and this is it.
  67. Bad hpfp :/
  68. Green fluid and audible purging
  69. Checking for boost leaks and pressureizing the induction
  70. Exterior Trim, Adhesives Question
  71. Suspect Head Gasket - help please
  72. Justacooper Spark Plug Help
  73. Mini covers recall timing chain!
  74. Multiple trouble codes after thermostat replacement.
  75. 2009 IKHA Climate Control On Board Diagnostics?
  76. Another p0015 code issue
  77. Coolant temperature alerts
  78. Odd SAT radio behaviour
  79. Integrated universal remote control issue...
  80. It's About That Time Again, Timing Chain Making Noise
  81. CEL and strange gas smell. Help!!
  82. Mini cooper s r56 strange exaust sound and low boost
  83. R56 heating system questions
  84. After sitting a month, '11 S has whine/buzz on acceleration only
  85. VANOS unit bad = 2B64?
  86. Electronic gremlins in the car - what to diagnose?
  87. Codes: 2781, 2870, 2891
  88. cleaning the throttle
  89. Coolant empty.
  90. Help me find out what connector is this?
  91. Driver's door wiring issue? '07 S
  92. '06 Cooper P00301, low compression #1, excessive leakdown #1
  93. 2009 MCS Check Engine light and No boost.
  94. Which tensioner to use with a new chain ?
  95. Ventilation air path?
  96. 2007 R56 Won't Rev Past 4k
  97. Overboosting (20psi +) on factory tune???
  98. Throttle issue?
  99. Help.. Name those wires.!?!
  100. Intake valves horribly coated with oily black goo after 15,000 miles, half a** job!!
  101. r56 Kazoo sound, no boost!
  102. AC hissing noise / failure
  103. Another Engine malfunction, reduced power thread - Findings
  104. N18 takes loong revving up after ~4.5K
  105. autozone MAX pads look weird
  106. Key fob is in slot. But, no response from the car.
  107. Idle values please
  108. Broken Electrical Connector/ Bushing Housing
  109. p0118, CEL, coolant temperature sensor
  110. MAF Issues! Brand new!
  111. Radiator help please
  112. R56 Unmetered Air 2b64
  113. Help!! R56 Error Code P0304
  114. coolant temp question
  115. Turbo Removal Required to Remove Cylinder head?
  116. Space Behind Fender Liner
  117. turbo cartridge vs entire turbo
  118. Cylinder head cradle bracket
  119. replace motor mounts N18S
  120. Engine Knock When Turning Off?
  121. 08 Cooper won't start
  122. P0599
  123. Dead Transmission
  124. PCV hose missing N18
  125. throwing p3030 code
  126. K03 Turbo Rebuild
  127. VERY strange new problem
  128. Airbag light and interior LEDs
  129. another reduced power light issue.
  130. Auxiliary water pump - what does it sound like?
  131. Stuck Rotor retention Bolts
  132. Won't Start after HPFP & Timing Chain Replacement
  133. Best value water pump brand for replacement?
  134. 09 Cooper hesitates up to 2000rpm
  135. R56 Cooper S engine noise - humming?
  136. Teapot whistle.. figured out it's from front windshield seal... What should I do?
  137. No Compression cranks like its flooded
  138. WOT Shake/rattle then puff of smoke
  139. Driver Door Doesn't Latch
  140. Engine Light (Half-Filled) but no Codes?
  141. No Spark on Number 3 cylinder
  142. possible oil leak - intake manifold hoses??
  143. Electrical problem
  144. key range terrible, drops signal rolling down windows
  145. Best Place to buy Timing Chain Kit?
  146. half yellow engine light without error codes
  147. P0420
  148. A/C issue only under load
  149. Coolant level over-expansion
  150. Death "knock" from water pump??
  151. 02 sensor
  152. Error code P2065
  153. 2011 Cooper S OBDII codes
  154. Odd creak/pop sound
  155. harness rather than thermostat?
  156. 2009 R56 S, CEL after Autocross (P115D, P1497)
  157. Sacramento area/Someone who can do a valve blasting??
  158. Mini Wont Start
  159. timing chain and tensioner
  160. comfort access system question
  161. The Butt Stops Here :)
  162. Sea Foam treatment on an N18. No smoke.
  163. Oil filter housing and coolant leaks
  164. Missing Vacuum Hose
  165. Drive Belt (serpentine) Replacement
  166. stuck sun roof
  167. Possible hpfp issue?
  168. 2010 HPFP - warranty or left to dry
  169. Shift Unit on 6 spd trans
  170. Cooling fan on 90% and rough start
  171. P115C & P2B5C (MAF Check Signal) Even After New MAF sensor and Cable
  172. PCV hose, having trouble taking sea foam
  173. Upper Strut mount crack
  174. loads of fault codes
  175. N14 Piston Damage
  176. Hpfp again?
  177. Which R56 parts fail by 100,000 miles?
  178. No Start R56!! Going nuts...
  179. 2011 S: Exhaust smoke/Oil leak at valve cover. PCV?
  180. R56 boost leak - diverter valve?
  181. Cel 2f07, 08 r56s
  182. R56 stange clutch noise
  183. CEL hesitation and stuttering. P0302
  184. Need some advice dealing w\ dealership and warranty company.
  185. dash brake light
  186. 2010 Base R56 Timing Chain Tensioner - Throttle Body / Manifold in Way
  187. Cooling fan issue with Video
  188. Oil filter housing gasket fails on freeway!! Questions.
  189. Register a new battery - how?
  190. Water Pump Failure/shop says...
  191. Turbocharger 2011 Cooper S
  192. Driver's Airbag Issue
  193. Driving lights harness connectors...
  194. Driving lights harness connectors...
  195. Mult Cyl Misfires - Spark Plugs or Coil Packs?
  196. First gear whines like reverse (6-speed manual)
  197. Boost problems
  198. sunroof malfunction
  199. Misfire at Wide Open Throttle
  200. ROUGH IDLE from cold. 2007 R56 MCS
  201. Cylinder Head Repair Recommendation?
  202. What years burble/pop? R50/R56/JCW
  203. Front End Creaking
  204. Recirc / Diverter valve: N14 vs N18
  205. Rocker Arm Ball Stud Replacement
  206. Whirring sound on right hand side 2010 MCs
  207. valve train noise on ignition on / off
  208. Cruise control issue
  209. No Start - Fuel Pump Voltage
  210. Long Term Preventative Choices
  211. Shaking while Idle
  212. Turbo Inlet
  213. Vacuum Pump
  214. Replace the intank fuel pump
  215. N12 Throwing Codes After Start Idle
  216. Timing Chain Tensioner Advice
  217. Engine error code? Bad car start and misfire
  218. 09 MCS Climate Control
  219. Finally Found My Rattle!!
  220. New HPFP under extended warranty at 67K miles
  221. Control arm bushing tool
  222. Problem with passenger lock
  223. Stripped screws on airbox of my Justa
  224. Wheek Bearing
  225. Whats next?
  226. Anyone familiar with code P114B
  227. 2008 mini cooper s water pump and thermostat
  228. r56 valve cover bolt torque?
  229. key fob
  230. Tach windows go blank
  231. Parking Brake
  232. Tensioner Question
  233. Rich smell to exhaust
  234. Troubleshooting taillight bulb malfunction
  235. taking a peek through the intake manifold!
  236. P0300 cel
  237. Window Dip
  238. new to forum.. 2011 mini rough idle, misfiring post... yes again
  239. Help, can I determine what software I have?
  240. TPMS Malfunction
  241. 09 R55 clubman s: Is this death rattle?
  242. Yellow engine light, died and won't start?
  243. Random Beeping Sound HEELP
  244. Cannot move my shifter left or right!
  245. Multiple Misfire on all cylinder, rough idle, stalling
  246. Need some help and advice on my engine problems
  247. Coolant Leak
  248. Power Steering High Pressure Hose, how-to?
  249. Thermostat Housing
  250. gas pedal broken cooper s 2007
