PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. R56 Location of Diagnostic Leak Detection Pump
  2. P053A? How do I fix
  3. Wastegate movement and code 2885
  4. Clutch Bleed
  5. Major oil leak
  6. rebuild started but died and now it doesn't want to start
  7. Coolant leak
  8. Official Transmission Fluid Change
  9. 2011 Cooper S - $1385 for Resealing oil filter housing?
  10. What are BANK1 and BANK2 cylinders?
  11. fresh rebuilt + slipped time = FML HELP!
  12. Abs control module question
  13. Clubman Club Door Stuck Won't Open / Fixed
  14. Intake Valve Carbon: why not vent PCV to atmosphere?
  15. Buzzsaw Noise from engine rpm
  16. Rich at idle lean off idle
  17. MCS R56 P1497 and P2187 codes
  18. Walnut Blasting Effect On Performance
  19. Blown Engine
  20. Clutch bleed help high pedal?
  21. Noise when revving cold engine
  22. Trifecta on a 2008 Clubman S - 5E57 and 6053 codes
  23. R56 MINI Cooper Base (Start-Up Issue)
  24. 2010 clubman S blown engine, advise?
  25. Mystery part from engine bay
  26. Buzzing noise after ignition off - something is running on?
  27. 2009 MC Base Catless Exhaust Manifold?
  28. R56 Cooper S Loose Steering
  29. Timing Chain Rattle/Oil Pressure Bleeding Off?
  30. New Turbo Break in?
  31. R55 Clubman S - Rich at Idle (P2188)
  32. 2008 Mini S - Fans come on without even cranking the car. HELP
  33. What would cause engine to shut off while driving?
  34. .tpms
  35. Stage 2 JCW power?
  36. 2011 MCS burps, loses power.
  37. Some idle issue
  38. Clubman gulping down coolant as I pour it in.
  39. Hurricane Related Misfires
  40. MINI Cooper S 2011 - Code "P15DF"
  41. Signs of Turbo Failing?
  42. I think this is where the dipstick went
  43. Car Immobilized?
  44. Anything else to check while I'm in here...
  45. Turbo heat shield necessary?
  46. The Excitable Ignition Switch
  47. Bought a 2010 R55 JCW - Need Guidance
  48. Where is and how to remove BCM 2010 Mini Cooper
  49. Repairing R56S ignition coils
  50. Spark Plug for N14
  51. Super knocking, I am going to fix this!
  52. high pitch squeal after cold start
  53. Cooper S auto tranny shifting differently after Mini Dealer repairs...
  54. Gear selector stuck, won't go into Park
  55. Brake & Clutch Problem
  56. Transmission Issue HELP
  57. Intermittent misfire under acceleration S Coupe
  58. N12 Rough idle and stall only when hot
  59. misfire codes enlightenment needed
  60. Rebuild abs module
  61. JCW Radiator support
  62. Who can Smoke Test in Indianapolis Area
  63. 2008 Base Hatch won't Idle
  64. N14 Recurring Cam Timing Slip
  65. Nobody can diagnose this-Can anyone help please?
  66. What is this sensor on N18?
  67. Is my clutch slipping?
  68. Coolant Temp
  69. How to know if friction wheel needs replacing?
  70. How many times have you had chain tensioner/kit replaced?
  71. Carly Diagnostic Results
  72. Temp sensor vs Themostat
  73. Pass. Airbag Off Light Question
  74. Center LCD display fix
  75. 2012 Mini Air Conditioning blowing warm
  76. Water Pump
  77. R55 Clubman Third Brake Light Issue?
  78. 2007 R56 non S bogging down with acceleration
  79. Mini Roadside assistance question
  80. N18 Timing Chain Tensioner
  81. Boost Surge/Cut? PCV Clog? Videos Linked
  82. acceleration hesitation
  83. where can I get a blower switch
  84. Low boost up hill/limp mode
  85. Problem with my mini - Help
  86. Fan Question
  87. Help HPFP again!!
  88. Another 2009 Clubman S issues (started today)
  89. Seeking Friendly Advice from the MINI Community
  90. N14 High Pressure Fuel Pump
  91. 2009 Clubman S issues
  92. Timing chain/oil filter gasket: low mileage for 2009 Mini
  93. 2009 MiniCooper ATF Problems
  94. Blue Smoke from Tailpipe
  95. HPFP grumblies, fuel level, thermostat, and is this cigar really just a cigar
  96. Need help troubleshooting clutch
  97. CC-ID 231 Light System Failure after reconnecting battery. "FRM"="Fried Module" huh?
  98. Possible Short Circuit in Pressure Converter
  99. Oil leak/usage
  100. Now the Battery
  101. Can a bad fuse block or CAS unit cause a starter/fuel pump to fail?
  102. Single mass flywheel conversions?
  103. Leaves in Bodywork Can't Remove
  104. 07 r56 S rear shock help!!
  105. Rear Break Pads
  106. P1551 engine code after installing a new stereo
  107. Hood cable "broke"... HELP!
  108. R56-167k mi / blue smoke after idling / multiple cylinder misfire / no loss of power
  109. 2010 cooper s wont do anything when key is inserted
  110. When did the convertible turbo cars get "reliable"
  111. P115c Throttle body replacement R56s
  112. Possible Bad Valve Seals
  113. Headlights
  114. Emissions 'not ready' for inspection
  115. Engine cooling fan on too often
  116. Need indy shop-dead car
  117. R56 Fuel Smell?
  118. R56 Piston Rings replacement
  119. 2010 R55 JCW, water pump/pulley/belt noise, please help
  120. [08 MCS] Vacuum Leak from PCV(?) + Oil Leak
  121. Rough morning start, ODBII codes inside. Possibly HPFP??
  122. Engine 'chuckles' from time to time (almost turns off)
  123. r55 clubman s no start / no ground at fuel pump wiring helllp
  124. R56 N12: Idle Hunting after ECU Learning
  125. R56 boost flutters
  126. Shift sensor circuit high code p9077
  127. Water Pump Replacement - 50K Miles
  128. No throttle response when start
  129. N18 HPFP - Anyone know how to tell the date of manufacture?
  130. Brake fluid LEAK.
  131. Turbo Oil Line?
  132. Engine light won't go off... out of ideas
  133. 12V power port in boot hanging by wires
  134. Spark plug broke in cylinder
  135. Decided to change alternator
  136. Changed Battery, Alternator problem?
  137. Jerking, Rough Idle, Stalling and Smoke
  138. One reverse light out, not the bulb, not the fixture, probably not the socket...
  139. Codes
  140. 09 S P0136 and 141
  141. Decreased power/response????
  142. 2008 Cooper base is sputtering/misfiring when warm and idling.
  143. 1 cylinder (#3) running lean and/or misfiring, no check engine light
  144. P0073.?
  145. Accidental Service Indicator Reset
  146. R56 Stalling at redlights
  147. Rough and Puffy
  148. my Cooper-S clutch may be failing
  149. 2008 justa huge oil leak
  150. Mini Cooper S R56 Stage 2 Boost low
  151. P0597 - Check Engine light
  152. Thermostat Installation Screw Up?
  153. Steering tilting slightly to the left...
  154. Need "new" Clubman R55 engine
  155. Ignition Issues?!!
  156. Ignition Help?!!
  157. Exhaust smoking white and smelled of unburnt fuel
  158. HPFP horrible experience with dealer
  159. [Help!] Fuel leak after replacing filter
  160. Front Inner Ball Joint
  161. Avg sensor reading database
  162. r55 tpm maintenance at tire change
  163. Engine Malfunction - Reduced Power
  164. One issue at a time
  165. Another ABS, Wheel Speed, DSC, No Speedometer Dilemma HELP!!!
  166. Continuation of previous problem.
  167. Sputer/hesistation then ABs warning comes on
  168. Loose Rocker Arms
  169. Valve Cover Ground
  170. dealer price for mini cooper key fob
  171. Check Engine light after Oil Change
  172. Coolant leak from snap fitting under reservoir tank !!!
  173. Turbo fan/mechanic questions
  174. Turbo Charger
  175. R56 Fuel Gauge Finally Fixed
  176. 2011 Mini Cooper S Engine Troubles
  177. Thermostat Replacement Problems
  178. More to repair than car is worth
  179. CEL Engine Coolant Temperature
  180. Fuel Door Pin?
  181. Pulsation at mid to high power
  182. N16 into N12 car
  183. Can anyone please tell me what this error code is?
  184. I have a couple of Issues
  185. Oil burn
  186. Advice on Aftermarket Turbos (Dorman, Rotomaster)
  187. ECU / ECM Repair Service
  188. White smoke after replacing oil feed line & oil filter housing gaskets
  189. Help engine management light
  190. Normal voltage for WG / BOV solenoids?
  191. Thermostat Housing help?!?!
  192. Looking to identify a hose
  193. No Keyless Entry
  194. Reduced Power Warning
  195. 2008 Mini
  196. P1497 Code
  197. Can't set A/C below 70
  198. Multiple P codes - common sensor/device ECU power supply pin
  199. Why does a light with exclamation mark goe on?
  200. Help with OBC diagnostic codes
  201. Runs well on high rpm and stall on idle
  202. Got P2885 error code but no power loss?
  203. Still a problem after replacing fuel pump?!
  204. Auxiliary water pump question
  205. Computer Custom Settings not Available
  206. Help getting car back to 100 percent since overheat due to oil loss
  207. MCS - Inlet Camshaft Sensor fault and rough idle?
  208. Break light show up
  209. MPG Display Issue
  210. Code: 2AD2 ??
  211. Help! No fault code for HPFP failure!?
  212. Please help !!! Coolant tank looks real dirty and seems like actual dirt inside tank
  213. 2013 Mini Radiator fluid leak and codes triggered
  214. 09 Base R56 Water Pump Replacement
  215. Help Me Diagnose a Clutch Problem
  216. Misfire and Camshaft sensor (R55 N14)
  217. Cooper S smoke from under turbo heatshield
  218. Tach wonky after valve cover gasket repair.
  219. Issue after a puddle of water
  220. Need to replace the turbo (R55 JCW 2012)... Suggestions?
  221. Flashlight accessory not working
  222. Help with failed Turbo & HPFP
  223. Throttle body for 2009 MCS
  224. 2011 Cooper Thermostat
  225. 2009 Valve Seal leak??
  226. no power at fuel pump
  227. Smoke from tailpipe after coming up to temp
  228. 2011 Mini 1.6L misses
  229. Leak issue and engine sputtering on startup
  230. 07 R56s engine issues please help.
  231. Overheating Issue....
  232. 2013 S Coupe Oil Filter Housing Leak
  233. Disconnecting Coolant tube on rear of engine from Thermostat housing
  234. Acceleration issue
  235. 2010 HPFP problem? Step inside
  236. Question on system readiness.
  237. Wheel speed sensor supply fault
  238. Gushing out coolant near the Thermostat
  239. White smoke-boost problems
  240. Burning oil (possible bad turbo?)
  241. 2009 MC Clubman S CEL after valve job
  242. 2009 R56 Major Engine Issues
  243. Pistons not even when flywheel lock tool installed
  244. Rattle noise only when turning wheel or sometimes in motion, need help ASAP!
  245. Need some opinions
  246. No coolant in resevoir
  247. Help. R56
  248. P0120 and P0221 error codes
  249. Cold Start Stalling
  250. 2011 Clubman S, CD player quit
