R56-167k mi / blue smoke after idling / multiple cylinder misfire / no loss of power
Hi folks...
Subject says it all.
2009 R56.
About 6 months ago...every now and then I'd get a rough idle...it would go away immediately or in a few minutes. The code would be:
cylinder 1 misfire
(never got a check engine light)
A few days ago, the rough idling became more prominent and now won't go away at all. The codes are now:
cylinder 1, 2, and 3 misfire (3 separate codes)
(AND I get a check engine light)
I have no power loss that I can tell. It just idles rough.
And...
If I idle more than 30 seconds (?), when I pull away from a stoplight there is a puff of blue smoke.
I've been reading the forums but haven't found an exact match yet as to what the problem might be, and how expensive to fix.
Thanks...
Bill
2009 R56.
cylinder 1 misfire
And...
Thanks...
Bill
Perhaps a dumb question...
How would (what is probably) a single stuck valve result in MULTIPLE cylinder misfires?
Also, is there perhaps an additive that just might UNstick a valve?
Thanks...
Bill
So I thought I'd try a "full treatment" of Sea Foam...yep, I know some people say it's basically a scam...anyway...so far...it WORKED.
I put 16oz in the tank, 5oz in the crankcase, and sprayed a full bottle in the air intake.
Rough idle is gone. The next few days will tell the tale.
In the mean time, the below link sounds more like my problem(?), as the rough idle only happened with a WARM engine...esp when coming off the interstate for some reason.
Maybe the Sea Foam cleaned the Vanos solenoids?
https://www.northamericanmotoring.co...solenoids.html
if the seafoam worked, my guess you have carbon build up and it time for cleaning.
to me when it comes to Minis, there is no stuck valve. it is either bent or fine.
when you get time, remove the intake manifold and look through.
But my symptoms have boiled down to this...
1) Cold engine: idle fine
2) Warm engine: (and weirdly, most especially after coming off a few minutes on the interstate), rough/stumbling idle.
However, if I have the air conditioning on when idling (and perhaps the computer changes the air/fuel ratio, and increases RPM a bit?), I do NOT get the rough idle. I'll research this more today, turning the A/C on and off...making sure I can consistently recreate the behavior.
I haven't seen blue smoke in the last few days (since the Sea Foam), nor have any codes reappeared.
with that mileage, i think the carbon build up is through the roof. take the intake out and inspect. also, do a scan even if there is no CEL.
R56 168k miles - rough idle when warm only, no loss of power or MPG's
As the issue got worse over a period of a couple months, finally the CEL came on...but even then, only sometimes...maybe it's the "multiple/random" cylinder misfire that sets off the CEL?
So yes, I check codes even when the CEL doesn't light.
Anyway, car is in the shop...MINI service (local shop, not dealer), in San Luis Obispo. They say they are MINI (and Mini) experts...hopefully they'll find something.
Plugs
before you spend a small fortune in diag at a shop- pull the coils and plugs and put a scope on top of each piston. If the rings are broken or piston tops chipped- you'll know where you stand quickly. If it looks ok in there, the car would certainly benefit from new ones.
I am amazed at how many people
come back from dealer and repair shop with spark plugs that are loose! Make sure that the washer on each plug is compressed when installed. Usually a 1/4 turn past hand tight will snug them up. I use a touch of antiseize. Many people do not. Do what you are comfortable with and you'll get a " feel for it" with practice. Proper socket and high quality wrachet will yield positive results!!
Good luck and post up your findings!
Thanks guys...
The shop has had it since Friday...probably haven't done anything last 3 days over the holiday weekend.
I know they put in new spark plugs (said they were pretty black), and then moved the coils around to see if the misfire codes would also move...they hadn't as of Friday afternoon. So in other words, sounds like coils and plugs are good.
This shop is pretty fair about diagnoses charges...we'll see. Updates to follow.
So what procedure am I asking to have done? "Clean intake valves"?
Thanks...
Bill
R56...
"Worth every penny"...in what way?
Of course I understand cleaning is necc from time to time, but you seem to be saying it's worth having done for other reasons?
Thanks....
Bill
Thanks....
Bill
Peace of mind
The car starts better, better mileage and crisper at WOT. Hot starts are also quicker without delay. With the intake off and a scope or video- You can see exactly what the condition is. It gave me peace of mind. I had it done at 28k and again at 55k. I never had a CEL or major issue- the car just seemed lazy and didn't feel fresh. It was noticeable improvement.
And while it is s DYI with all the tools readily available- I opted for the dealer visit and free new loaner car for the day. No regrets. Money well spent for me.
Called the shop...asked about a walnut blast. They said carbon buildup on the intake valves would not be a problem with my car as my 2009 non-turbo does NOT have direct injection.
I've been reading up on this and have come across conflicting information...people say:
1) ALL 2007+ engines are direct injection (and therefor ALL susceptible to carbon buildup, thought the turbo engine gets it much worse), or
2) The non-turbo engine (N12?) is NOT direct injection and therefor experiences little if ANY carbon buildup...or at least not enough to cause a problem.
So...which is it? (Geez I feel like a noob.)
Bill
Bill
Bill
Bill
Maybe I missed it, is your car an auto or manual? There are situations with the auto transmission that create misfire codes, as one that is failing causes vibrations that trip misfire codes.
When the wrench pulled the plugs - what did the top of the pistons look like?
