View Full Version : Stock Problems/Issues
- USB Media Connect/iPod y-Cable Help!!
- Car in shop - need help
- new glove box now what to do about airbag
- Ok so my mass air is reading 0
- Seatbelt problem with our '08 MCS
- Have to reset TPMS again and again and again...
- Windshield cracked
- Husband hit a pothole-Dash looks like a Christmas Tree
- Your odometer when new - how low can you go?
- Fluctuating RPM's at startup
- Recurring exterior bulb indicator
- Speakers covered in 3 year warranty?
- Window seal issues
- Steering
- Headlight bulb removal
- Maintenance Manual and Repair Instructions
- Does it need to be fixed?
- 2009 Clubman S needs new intake manifold
- Clutch problem on one-year-old 2009 Mini Cooper Clubman S (R55)
- Popping sound when in reverse
- Idle issues
- Carbon Buildup Cleaning
- Brake Issue. Urgent Help!!
- Strange Buyback Experience - LemonLaw
- Drop in Fuel Economy After Service
- Limp Mode, no CEL?
- Misfire Cylinder 3 and 4
- Seatbelt hitting neck...
- Passenger Seat Does Not Return to Position
- sun roof doesnt open when cold??
- P112b Code?
- Moisture in intake manifold 2010 S 4300 miles
- Engine Carbon Treatment
- Wastegate issues anyone?
- Major Oil Leak
- Fault code P1128
- sun roof issue
- 07 MCS - warranty almost up and a couple of problems
- Another electrical gremlin...
- 08 Justa Clubman Electrical Gremlins
- Mini won't start, Yellow engine light on
- Oil pan
- MPG Readout is Way Off?
- What should I say to the dealer?
- Boost Pressure Ramdonly goes Away and Then Returns
- Manual Transmission Suddenly Stopped Working
- Electrical Wiring Bundle Delays Thermostat Replacement
- Run Flat Tire HELP!!!
- Anyone with new fuel pump???
- Shutting off the TPMS ,for winter ( how )
- 2011 MCS Owners - Noisy engine at idle?
- 4th Yellow Check Engine Light on 6-Month-Old Clubman
- COLD Start repair reprograming?
- Help! Lease return and warranty questions
- Water Pump Replacement
- Multiple warning lights many problems
- 2011 MCS forgets setting after sitting...
- What is a normal operating temp?
- 2008 Cooper S leaking Coolant... UGH!!!
- Acceleration issues in cold weather?
- Over Boost problem 23psi!! P0108 and P0030 codes
- Very very surprised!
- Interior Ticking Sound
- Not all bad
- HELP! wont shift into gear. stranded on road.
- not sure what happened
- $389 for "fuel service"?
- Stuck Sunroof Problem
- I need some advice..
- Need some guidance to CEL Service - Car at dealer now
- P0015 CEL ["B" Camshaft Position -Timing Over-Retarded (Bank 1)]
- new cel please help
- so that cold start rattle..
- lock/unlock/trunk buttons no longer work on key fob!
- Noise When Cold
- stupid cel need help
- Window won't automatically roll down when door is closed
- Clunking between 30 -40 mph
- What does my car want?!
- Trunk latch is constantly releasing...
- Newest Problem
- Mini heat cooler at idle
- Engine Vibration Over 3k and Cold
- 07 mini service icon not in the manual
- No heat when stopped
- Problems with stock radio
- Cabin Filter Replacement
- Back to dealer
- Rattle in the Back
- Help! Heat stops blowing hot at idle!
- Need some help, broken foglight clip
- Just a simple observation
- cold start chugging in D
- Almost 3 years; what should I have done?
- excessive carbon build up
- Blower motor noise only when cold
- 3k RMP Engine Rattle
- NEW JCW Clubman 2k mile blown clutch
- Parking Sensors Not Working
- Clutch out
- Hood scoop warped form heat
- My Satellite radio died?
- Window rattle issue
- Help please
- PICS of 2011 MCS New Design Valve Cover - Carbon/PCV Fix?
- Heater isn't heating...
- Shaking in reverse this morning
- Engine Swap
- Suspension knocks
- Spark Plug Ignition Coil Rust/Corrosion
- 2010 MINI Cooper (Non-turbo engine) port injection or direct injection?
- PCV line on 2011's
- Buzzing noises.
- Reliability Mods
- help finding screws for Pillars on center console
- Chrome headlight trim bubbling
- TiMing chain slide broke, causing oil pump chain to snap
- 2nd Gen R56 Purchasing Advice
- Insert Navigational DVD
- Water Pump Leak on 2008 Cooper w/56,000 Miles!
- Quick Knocking question
- Those that are having engine failures
- 2010 mini camshaft sensor
- radio display says "alarm" huh
- Car overheating
- Radio won't turn on for 30 minutes
- Problems with my R56S
- Brahman Mini Denies Warranty for Engine Failure on a 2009 Clubman S
- Mirror cover falls off
- Warning light combination
- 07 CooperS oil filters - FYI
- Rockers knocking and a P00AA code, help?
- Rattle buzz found it!
- No Recall planned for HPFP
- 2010 Cooper S Bottom Door Seal?
- A few things not working
- R56 2007 engine failure twice
- Clutch and Warranty?
- Warning about being able to shift (automatic) transmission without applying brakes?
- Stuttering / Turbo noise
- I didn't even make it 600mi to my first check engine light!
- So is Mushrooming a problem on R55,56's???
- Clutch Engagement Point
- Is this gonna be a problem?
- Car seems to lurch occasionally at constant throttle in higher gears
- Squeaky driver's seat - 2007 Cooper
- Possible clutch problems
- car can't handle accelerating on the highway
- BMW institutes "voluntary recall" of HPFPs 2007-2010
- BMW Admits HPFP Problem - Article
- engine chirp at idle.
- Engine noise
- Random creaking noise from steering
- boost pressure deviation..... turbo problem
- Gen Two Justa Cooling Fan
- Buzzing in driver's ear, '09
- Auto Dimming Mirrors go dark during Daylight!?
- Realtime Traffice issue
- Thumping noise + a few others
- So My R56's Engine Went FUBAR
- MCS starts and turns off??
- in for service again
- Timing Chain/Death Rattle -
- Louise is in for repair so time to upgrade!!! ;-)
- No Audio an Sirius Radio problem on 2011 Clubman S
- Scoops with Heatshields Feedback?
- Sunroof doesn't retract unless button held
- convenient access intermittent
- Just had the timing chain & tensioner replaced and...
- Does this come off?
- Loss of Boost - What Could Be Wrong?
- Water Leak on Front Passenger Floor
- Squeaky . . . headliner?
- '09 MCS Bonnet rubbing bumper and fenders
- Code problems
- According to my dealer, this is not covered by my warranty
- My Xenon Headlights
- MCS feels like its having a problem getting fuel while cruising
- Transmission noises?
- Weird Noise! Help!!!
- Good mechanic to fix timing chain rattle in So Cal
- Steering Issues
- Intermittent low boost issue
- Clutch Advice Please
- OEM wheels and tires
- Engine Squeal
- SEAFOAM just in gas tank?
- Lower radiator hose drooping & worn through on Cooper-S
- Knocking/Creaking Sound on Clutch Let-Up
- Troubleshooting the fuel filler door lock
- Engine Failure light @ 2945 miles...bummer.
- Just bought a MINI, now I have a CEL??
- Seafoam Procedure, please post it
- Fuel door lock stopped working
- SAGA of the dual Mass Flywheel and the dealership hurting my AeroKit
- Why ME?
- Hood Cable Issue
- AC Vents won't stay in place
- Loose Boot Trim Handles
- Seriously though...why a noisemaker?
- Clutch releasing in 6th gear while cruising - any ideas?
- Oil Light Came on After Hard Corner
- How do you access the spark plugs?
- Whats the deal with Inspection II?
- Update on my car
- Northeast Owners - Turbo Rust?
- Dual Mass Flywheel (DMF) Induced Early Clutch Failure
- 2010 base model with 1,900 miles engine whine
- How To Remove OEM Antenna Base???
- HELP! New Engine/Fuel Pump problems and dealership issues!
- Miles to Tank on OBC different...
- weird battery problem?
- Has the HPFP issue been fixed in 2010-2011s
- 07 R56 weird idle problem and extreme hesitation
- Turbo weeping oil?
- weird clicking/rubbing sound any ideas?
- Slide Rail Replacement?
- Comment/Observation regarding Torque Steer...
- 2007 MC Whine When In Gear
- New Mini Stalling Issue
- Survey, carbon-catch cans-and oil changes
- Engine Noise
- New to this Fourms any diy listed on this site?
- Took Delivery of my 2010 S and it broke down..
- Annoying Rattle!! -- Comfort access system ECU
- 2008 Mcs Tire Issues
- Excessive Flywheel/Clutch Assembly
- Mini Problem - Not Starting
- LOL Wasted Service Appointment
- Into the shop for rattles/noises - wish me luck!
- Mood lighting out of sync
- I Lost A Lug Nut?
- Auxiliary / Cigarette Lighter Broken
- Clutch "pop" half-way through pedal press
- MINI versus the car wash
- Low Electrical Problem - No Start Issue
- multiple warning lights - ABS, DTS, Brake, TPM, CEL
- Cold Start issues...
- info needed about 04 r53
- Chirpy Engine
- Cold Start issue?
- Passenger window pops out of Track at high speeds?
- Cold Start Death Rattle
- Side Scuttle fells off
- Yellow sunroof light
- blown head gasket?!
- HELP: Missing rear control arm bolt!!
- Headlights aimed down, How to re-aim?
- Horrible engine noises at low rpm:
- Oil level. Is this normal!?
