Engine Failure light @ 2945 miles...bummer.
Old Sep 19, 2010 | 07:37 PM
Jaque_Mate's Avatar
Jaque_Mate
Well, as the name hints, not good. I did a search of possible causes and I saw anywhere from catelyt converter (spelling) issues to the turbo being fried. Granted this came on when it had been parked in rain and 50 degree weather for 4 hours. It seemed a little sluggish and almost hesitant on a few hills on the way back to my apartment. Oh well, heading to the dealer when it opens tomorrow Morning. Sheez, a 2010...
Old Sep 19, 2010 | 10:56 PM
drsilvermini's Avatar
drsilvermini
What is the engine failure light? Do you mean the check engine light?
Old Sep 20, 2010 | 04:37 AM
MI MINI S's Avatar
MI MINI S
Engine Failure = no lights...nothing. Check engine light at 2,900 miles is covered by warranty.
Old Sep 20, 2010 | 07:32 AM
Jaque_Mate's Avatar
Jaque_Mate
the dealer here in Des Moines is shipping it to Omaha for the day. Lauren over at service there says it should be ok and back on the road in a day or so. We'll see.
Old Sep 20, 2010 | 08:04 AM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
I was wondering/thinking the same thing myself. If the check engine light (CEL) comes on, you can take it to most any auto parts store and have them read the code for free. There are thousands of conditions that will set a CEL, it could be just about anything. One of the more common causes is a loose gas cap.
Old Sep 20, 2010 | 08:14 AM
Jaque_Mate's Avatar
Jaque_Mate
I don't think it was the gas cap, because on the way over, I topped it off and made sure that sucker was tight.
Old Sep 20, 2010 | 08:18 AM
ZippyNH's Avatar
ZippyNH
Thanks for the laugh!!!
Engine failure light!!
I guess if the oil light comes on and you keep driving...it is the same!!
Old Sep 21, 2010 | 04:31 PM
Jaque_Mate's Avatar
Jaque_Mate
Getting Spike back tomorrow. Add another to the list of carbon build up. Service says that premium gas in Iowa is not good enough for Cooper engines. they said to just add a can of fuel injector cleaner every couple of tanks while in Iowa. crazy. at least it wasn't something worse.
Old Sep 21, 2010 | 06:47 PM
ZippyNH's Avatar
ZippyNH
Sorry to break the news to ya....on a direct injection motor...adding detergent to the gas does nothing to remove carbon....it must be removed by adding cleaner to the intake side....or by removing the intake for physical cleaning.
Unlike a standard motor, on a direct injection motor, the fuel is not sprayed intro the intake, but into the cylinder itself....so any oils, etc that is in the PVC system, can condense, and for carbon on the back of the valves. This is a common problem with ALL MAKES of direct injected motors. It is not hard to avoid, just read the "SEA-FOAM" threads.
Good to hear the car is running good again...
But it sounds like if the dealer did not understand the car enough to fix it without shipping it off (it is a well publicized issue, both within MINI, and the ENTIRE automotive industry)....and then gave you 100% incorrect advise for a DI motor....I would be careful about giving them my $$$.
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
stellaherself
Aug 14, 2015 05:28 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
