engine chirp at idle.
Old Oct 26, 2010 | 07:06 AM
madmaxxed's Avatar
madmaxxed
hello all. i just noticed a sound coming from the motor when i'm sitting at idle at a stop light or sign. it only does it when idling at most times and once i hit the throttle it goes away. has anyone else had this issue? it is a chirp, hum sort of sound. bearing of some sort? pulley? suggestions?
thanks.
Old Oct 27, 2010 | 04:27 PM
OPish's Avatar
OPish
Next time it happens, open the hood and just listen till you can pinpoint where the sound is coming from. I had the same issue, I heard little chirps and squeaks and found that it was coming from my water pump.
Does this normally happen once the engine has been running for a while? If so, I would probably look into the water pump.
https://www.northamericanmotoring.co...ak-squeal.html
Hope that helps!
Old Oct 27, 2010 | 04:39 PM
madmaxxed's Avatar
madmaxxed
yes it seems to do it when the motor is warm and has been running for a while. i popped the hood a few times and really can't pin point it out quite yet. the mini is a totally new thing for me. thank you for your help.
Old Oct 29, 2010 | 02:51 PM
sayquack's Avatar
sayquack
I am having a similar chirping sound as well. I have isolated it to the rear of the car on the passenger side. The sound chirps at a about 60rpm and does not speed up when the engine is revved. Anyone have any ideas?
Old Oct 29, 2010 | 05:43 PM
iwashmycar's Avatar
iwashmycar
Water pump.
Had mine replaced under warranty. Supposedly some have a faulty seal or something that starts a chirping squeal.
You can probably do a search on here for more info
WP is down low passenger side:
Old Oct 29, 2010 | 05:44 PM
iwashmycar's Avatar
iwashmycar
yours sounds like brakes or wheel bearings if its strictly speed related
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
Lt. Dan
Aug 10, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
