Manual Transmission Suddenly Stopped Working
Old Jan 1, 2011 | 04:19 PM
DigitalPhoenix's Avatar
DigitalPhoenix
Old Jan 1, 2011 | 04:23 PM
phinzup's Avatar
phinzup
Master cylinder? Does the MINI have a slave cylinder? On my '96 Miata, these were symptoms of one or the other going bad. Could you rev it and get it into gear? I could be completely wrong, so I'm really interested to see others' input.
Old Jan 1, 2011 | 04:26 PM
HRM's Avatar
HRM
If you turn the car off, can you get it in gear? If so, probably clutch related. If it still won't go in gear, the cables (probably one) went.
Just a guess based on general knowledge, not mini specific.
Old Jan 1, 2011 | 04:48 PM
DigitalPhoenix
Old Jan 1, 2011 | 05:13 PM
fensty245's Avatar
fensty245
Id have to guess its something with the shift linkage.
Old Jan 1, 2011 | 05:26 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
+ 1 on a cable.
Old Jan 1, 2011 | 05:27 PM
scottab36's Avatar
scottab36
MINI replaced the shifter box on my MINI for a similair issue. Completely fixed the issue. The shifter box is a complete unit right beneath the shift ****.
Old Jan 1, 2011 | 05:39 PM
DigitalPhoenix
Old Jan 1, 2011 | 05:43 PM
scottab36's Avatar
scottab36
Extremely hard to shift gears. Also lost the spring return feel in the neutral position. Had to manually check where the shifter was when shifting around between 1st through 4th gear.
Old Jan 1, 2011 | 09:50 PM
Melangell's Avatar
Melangell
Gotta go with the cable theory...
minicoclub
Nov 11, 2015 07:25 AM
FrostyFox
Oct 28, 2015 02:06 PM
phrza81
Oct 10, 2015 11:37 PM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
IstanBucket
Aug 8, 2015 02:25 PM
