Shaking in reverse this morning
Old Nov 24, 2010 | 04:58 AM
sekhmet101's Avatar
sekhmet101
Hey all. Long time no see.
So I put Violet in reverse this morning to pull out of the parking spot and she shook. That's never happened before. Anyone have any ideas? It's been colder then this and she didn't shake. So I don't know what the problem could be.
Old Nov 24, 2010 | 05:47 AM
sequence's Avatar
sequence
warped flywheel?
Old Nov 24, 2010 | 05:52 AM
sekhmet101's Avatar
sekhmet101
My car is auto. I didn't think auto's had flywheels?
Old Nov 24, 2010 | 08:22 AM
MINIdave's Avatar
MINIdave
Was the engine missing/running rough or do you think it was a transmission issue?
Hard to guess from your limited description, but was something blocking one of the wheels?
And auto's don't have a flywheel in the same sense as a stick shift car, but they do have one. And no, I doubt it was that either.....
Old Nov 24, 2010 | 08:56 AM
sekhmet101's Avatar
sekhmet101
I truly don't know. I don't remember it running rough before I put it in gear. I guess I'll have to pay close attention and if I continue to have problems, I'll have to bring it in.
Old Nov 24, 2010 | 04:48 PM
ellinara's Avatar
ellinara
Did u try it again when the car was warm. When u drive do the shifts feel rough???
Old Nov 24, 2010 | 05:10 PM
phxsteele's Avatar
phxsteele
wet and cold? Maybe a brake pad was stuck?????
Old Nov 24, 2010 | 05:23 PM
009Mini's Avatar
009Mini
I've had this happen before with the pads freezing to the rotors and not releasing when the emergency brake lever was put down. Creates kind of a jolt and makes you think something broke.
Old Nov 24, 2010 | 05:37 PM
sekhmet101's Avatar
sekhmet101
I didn't try when the car was warm. But I did notice today that when I slow down, I feels jumpy when it downshifts. I don't remember that before. But now I'll probably notice everything.
Old Nov 29, 2010 | 07:49 AM
strobeyprobey's Avatar
strobeyprobey
I had shaking and stall happen a few times in my car. Even though I have a non-turbo, I had stalling just like the High Pressure Fuel Pump issue experienced by some of the turbo engines. That could be your problem.
Old Nov 29, 2010 | 12:38 PM
sequence's Avatar
sequence
Yr. sig says MCS, not MCSa (automatic)
Old Nov 29, 2010 | 12:46 PM
sekhmet101's Avatar
sekhmet101
My sig also says auto.
Old Nov 29, 2010 | 12:47 PM
sekhmet101's Avatar
sekhmet101
I've had the fuel pump replaced and the car was re-programmed because of the warm start issue. The car hasn't been shaking since that day so I don't know what it was.
Old Nov 29, 2010 | 04:32 PM
moondawg14's Avatar
moondawg14
One of these might help:
http://www.waymotorworks.com/bsh-low...mount-r56.html
I've noticed mine rocking around a lot too. I'm thinking about one of these soon. I also have an automagic. (but not an S.)
Old Nov 29, 2010 | 04:39 PM
sekhmet101's Avatar
sekhmet101
Thanks. I want to open up where the air filter is. Someone I know had squirrels use his MINI as their magic hiding place. I want to make sure they aren't doing the same with mine.
ian260
Mar 29, 2017 06:08 AM
randeez
Oct 5, 2015 09:23 AM
NYXF56JCW
Oct 3, 2015 04:27 AM
gknorr
Oct 1, 2015 09:20 AM
ericf1993
Sep 26, 2015 03:58 PM
