PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. irritating trembling noise
  2. rear light replacing
  3. Will a clogged PCV valve throw a code?
  4. Catalyst clogging and oil burning
  5. Melting headlight trim
  6. replacing the OEM catalyst
  7. Bonjour !
  8. Leaking Coolant (and what sensor is this?)
  9. 07 MCS R56 Engine Blow At 99700ml
  10. Oil leak
  11. Reverse lights: stuck on!
  12. Mood light issue
  13. Brake, DSC, and ABS lights all on in yellow
  14. 2007 Mini Cooper R56 CD player issue
  15. Misfires and Body code
  16. Is this the dreaded "Chain Rattle"
  17. Battery icon . . . not sure what the deal is?
  18. New brake sensor but not reset
  19. Question about exterior lights
  20. Coil Replacement
  21. Heated seat help
  22. Major work going on. Anything I should check while it's torn down?
  23. Wiper problems
  24. Smoke from turbo after oil feed line change
  25. code P0087
  26. Footwell module wiring
  27. Early signs of Aisin transmission trouble?
  28. 2011 S Starter Noise?
  29. Loud exhaust on deceleration
  30. P173b code, CEL light on
  31. Long crank to start after filling gas tank, and stumbles then runs fine.
  32. No start - wipers going crazy, windows dead, radio dead.
  33. N14 Engine challenge
  34. R56 No low beam, hi-beam working
  35. Smelly and Wobbly: 09 Hardtop S
  36. Xenon headlight troubleshooting
  37. P0300 and P0128 - Oh boy!
  38. Spark Plug evaluation help?
  39. Spark Plug evaluation help?
  40. Chassis Stabilization Malfunction - 2017 Clubman S All4
  41. Engine fault code
  42. HPFP part numbers and cut in date
  43. 2012 Countryman S... pos
  44. P115C - Differences between throttle body housings?
  45. Fuel Shut off?
  46. P173B code
  47. Yellow take light and mini on loft
  48. Remote battery low?
  49. Radio Issue
  50. Ripped dashboard
  51. Looking for an experienced opinion. Electrical or simply a battery issue?
  52. Oscillating buzzing noise
  53. What could these codes mean?
  54. Airbag and seatbelt warning light - Fault code 0093CF,0093CE "satellite door"
  55. P0304 Misfire - Swapping Injectors
  56. Has anyone had their IN TANK-FUEL PUMP replaced?
  57. Engine Temp Too High
  58. Interior light not working
  59. Oil Pan drain stripped
  60. Gas in the cylinder!
  61. Spark Plug Seized
  62. Steering question
  63. E717 Fault Code
  64. 2011 R56S Press Clutch Really Hard to Start
  65. ELectrical Problem
  66. 2010 Base Misfire
  67. New valve cover resolved P1497, but still having misfire on cylinder 2
  68. Battery Died, Now No Crank, CAS Issue?
  69. N14 S coil fitment?
  70. Intermittent sounds from drive axle(?)
  71. R56 Base Cooper doesn't think I filled up the tank
  72. 2010 R56 Justa Rough Idle and CEL
  73. $10 Hatch switch DIY fix
  74. exhaust manifold nuts
  75. Rusty bolts in engine bay on NE MINI's
  76. Help mini wont start!?!?
  77. Spark Plug replacement on Mini Maintenance Plan
  78. Mini Relay Clicking
  79. R56 Burning Oil via Exhaust at Idle
  80. Wild warning lights and now it's on the side of the road
  81. DP heat shield hardware
  82. R56 - seafoamed it and now P0641
  83. How to replace the OEM Bi-Xenon Bulb?
  84. Oil cooler bolts torque
  85. R56 Cooper S AC System only supposed to blow at 60 F ?!
  86. 93c9 airbag sensor fault code
  87. P1497/2b64 + Missfires Occasionally + CCat Ineficiency - NEED HELP
  88. N14 Engine Question
  89. Leaking fluorescent yellow fluid
  90. Coolant leak 2012 Coop S
  91. Misfiring, Hesitation at high load
  92. Oil solenoid harness rodent damage, blown 25amp fuse...
  93. 2013 Cooper 3rd Brake Light
  94. Electrical conundrum r56 base electrical failure at 11,000 ft
  95. 09 Cooper S rolls back on slight incline in 1st gear
  96. CC-ID codes 131 & 132
  97. No Turbo after Carbon Cleaning
  98. I want to cry. I'm fed up
  99. Moonroof Nightmare - Need help
  100. whats this from the gearbox ? (oil leak from there)
  101. N18 PCV Delete / Dual Boost Tap?
  102. How to Erase Codes?
  103. 2009 R55 Foot Well Module Wiring help
  104. Rough idle
  105. 2008 mini S stalls when restarting after warmed up
  106. New Exhaust Assembly...
  107. Constant stereo beeping
  108. DIY serpentine belt
  109. Unknown engine rattle
  110. Mud flaps have no red glue strip?
  111. R56 P0599 after water pump replacement
  112. Noises while turning the wheel
  113. Very unsatisfactory coolant bleed
  114. help with DTC codes please
  115. Trunk latch switch repair
  116. My Code 2885 Boost Deviation Solution
  117. 2010 n12 ROUGH IDLE WHEN WARM CODE P0302
  118. 2009 mini cooper rough idle help
  119. Anyone know the coolant capacity for a R56?
  120. Mini s steering wheel Wearing out.
  121. Thermostat-Timing-ECU (Help!)
  122. Can't Get Coolant To Drain
  123. Engine temp indicator came on.
  124. I need help!!
  125. Removing kick panel to fix hood latch
  126. Need help with abrupt power loss!!! R55 clubman s
  127. Tail Light Issue
  128. 2007 MCS Engine Trouble
  129. hpfp testing?
  130. Bav Tech Codes 2EE0 and 2EEP...
  131. How much walnut shell?
  132. Cool starting problem
  133. Vacuum pump failed - what to do?
  134. 2008 Cooper rough idle, trouble starting
  135. Problems with misfire p300 and p2096
  136. 2007 Cooper S Cooling System Oddity
  137. weird loss of power R56
  138. Timing Chain Tensioner - Need Advice
  139. Full engine power no longer available on accelerater pedal release
  140. The dreaded P0128 code
  141. Crank case vent valve?
  142. wheel speed sensor fault
  143. R56 Rollover - Repair Advice?
  144. Multiple codes, possible hpfp issues?
  145. Half Engine Light - no loss of power??
  146. Diverter valve failure? Possibly wastegate?
  147. Oil Leak!
  148. Jmtc clutch disc side
  149. HPFP and recalls DONE!
  150. Why is my mini s running like a wrx all of a sudden??
  151. Problem on every first start (idle and clutch) [Video]
  152. Loud CLICKING Air Conditioner / Heater
  153. Yellow Brake Light with Yellow ! with circle on Startup
  154. High Speed Fan Question
  155. R56 Engine Reduced Power
  156. Boost leak?
  157. R56 fuses- central locking versus rear hatch - different circuit?
  158. Need Help Fast!!!
  159. Grinding/whining noise when oil level gets low
  160. Strange rattle when cold, bad tensioner?
  161. Bad Turbo?
  162. Engine Malfunction, reduced performance
  163. Clutch replacement link
  164. Noises
  165. Radio buttons not working.
  166. Issue after rebuild
  167. R56 S A/C Recharge steps
  168. Turbo Replacement 07 R56 MCS
  169. How to do a Seafoam SPRAY for 08 clubman
  170. Potential timing chain tensioner issue (with a twist)
  171. 08 R56 Hatchback base Fuel Filter
  172. Coolant leaking on oil pan
  173. Engine Question
  174. DIY Rear Brake Job
  175. Replaced Thermostat, P0597 Remains, Next Steps
  176. Clicking noise from passenger fuse box
  177. Right Side mirror rattling
  178. Clutch pedal engage/disengage point
  179. P0013 recurring code solved. Something to watch for
  180. 2007 MCS - P01497, P0130 Help
  181. 2009 MCS P2BCB code
  182. Having Hard Time Shifting From Park (video)
  183. Burning oil - 1 quart per 500 miles
  184. Coolant leak
  185. New member, just bought 08 mini, clutch problems already
  186. CEL, p173B, new thermostat, and 2nd temp sensor, WTF
  187. 2008 Justa radiator replacement
  188. Static/crackling on the radio
  189. 2011 Mini Cooper stopped playing lock/unlock chirp sounds even with alarm package
  190. Oil leak at valve cover
  191. Mileage when towing?
  192. Help with video
  193. Malfunction light - Help
  194. Timing chain broken cam gear bolt snapped
  195. Misfire P0300 and P0304
  196. Can't get a new key
  197. 2007 R56S hot start causes surging idle
  198. Cyl 1 misfire-not plugs or coil, where next?
  199. Do you walnut blast? How often?
  200. Am I covered? Timing Chain!
  201. Can a thunderstorm cause non-starting?
  202. Head Replacement - Poor Running N12
  203. Reverse Instead of Second
  204. CC-ID 231 Light malfunction
  205. Illegible radio display
  206. All Gen2 Water Pump Settlement LINK TO WEBSITE
  207. Buying an MCS that has had the timing chain SB done.
  208. Oil where it shouldn't be
  209. looking to buy 2010 Clubman S
  210. Clacking when braking and parking brake light
  211. Possible Bad Turbo Seal???
  212. Bluetooth buttons no Phone option
  213. reverse lamp switch
  214. 2011 Thermostat Housing help
  215. VANOS problems 2007 MCS
  216. Oil Filter Housing Seal leaking, $1000 to replace?
  217. Sticky/Gummy door handle
  218. Coolant leak and warranty cover
  219. Gas Ventilation Hose
  220. Any idea why I would get a P28AA - BOV - Bypass valve code after top end rebuild?
  221. Did your Harman Kardon amplifier die during the summer??
  222. Vanos Timing - Can it mechanically drift?
  223. Headlight washer system
  224. R56 - replaced everything related to timing we can think of but still having problems
  225. Question on power window motor & engine noise
  226. N12 oil pressure light on during hard rights?
  227. '07 Acceleration Issues..
  228. Shifter bushings out or something else?
  229. Buzzing / Rattle on deceleration
  230. troubleshoot ac? 2009 JCW
  231. Two Quick Water Tube Questions
  232. Foglight Warning Indication
  233. Anyone replace a headlight adjuster motor?
  234. Detonation and timing pull issue
  235. Troubleshooting help, power loss, trying the correct subsection this time
  236. Coolant temp -40F
  237. Code 293A Coolant Temp Sensor
  238. Where is torque converter clutch solenoid? (Error code P0741)
  239. 2010 s coolant massive leak
  240. OVC Leak Engine Oil?
  241. Thermostat Housing Question
  242. 13 JCW N18 Engine chirping sounds
  243. Temps after t-stat housing change: is this right?
  244. oil leak right under turbo on 08 MCS
  245. Code p054b
  246. Restraint System Malfunction R56
  247. metallic whistling sound
  248. Engine wont turn over
  249. Sunroof troubleshooting
  250. Potential Dealer/CPO issue:
