PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36
  1. Strange warning light?exclamation point
  2. Warped flywheel...
  3. Oil leak R56
  4. What's going on here??
  5. Somthing inside my tire?
  6. Harmon-Kardon, distortion and door rattles
  7. Driver side Output shaft
  8. Key fob stuck in ignition.
  9. Sluggish 2004 with automatic transmission
  10. High Oil Usage - What is this
  11. Trim Seal came Loose, Suggestions?
  12. What do these warning lights mean?
  13. Is this correct
  14. Indicator/warning light question.
  15. Thumping sound while driving after dealer visit
  16. Quick Hood Scoop melting question
  17. R56 MCS Air Con gas leak......
  18. exclamation point inside of a triangle and weird scratching sound
  19. Brake Problem after repairs!
  20. Rough Idol
  21. Super Knocking
  22. Oil & Filter Change..
  23. Sputter and die on cold start / Cold start procedure
  24. 07 MC Red Temperature light
  25. Fuel trim /idle issue R56 MCS
  26. Sun roof wont work
  27. Low oil pressure... anybody? Long Story
  28. Recall Scheduled, Should I....
  29. URGENT PROBLEM need help quick please!
  30. MAF Sensor needs to be replaced....
  31. Water Pump Recall repair completed...
  32. Knocking Noise possibly front left - Any Ideas?
  33. r56 Wheel well plug
  34. 2007 MCS unknown problem. Rough idle, stalling, No fault code
  35. Tips for using Mini Roadside Assistance?
  36. Wiring Harness wear causing Check Engine light (2010 Clubman)
  37. Oxigen Sensor removal
  38. Halogen H13 Headlight mystery!
  39. manual transmission fluid overfill
  40. Speaker Buzzing
  41. '07 Hatchback Check Engine Light
  42. BlowOffValve issues
  43. 2012 MCS Start and stall/stumble events, no CEL.
  44. Headlight bolt broke free from socket
  45. roll call, have you replaced your thermostat housing .
  46. Replaced thermostat housing...now 2.9 psi of boost?!
  47. Cold start / stalling issues with video. Help!
  48. An interesting noise I've never heard of...
  49. Extended warranty question
  50. Steering question from new MINI owner
  51. timing chain, timing tensioner Recall effect 500,000 Mini's
  52. AC/heater fan noise, something caught? ARGH!
  53. Looking at 09 jcw 55k mi. Any thoughts? First Time Buyer
  54. Fan staying on to long after car is off?
  55. Just bought 09 JCW – 2 questions
  56. Haven't got a notice for the water pump recall...
  57. Heater "kinda" working
  58. Another check engine light issue
  59. JCW Worn Emblem Replacement
  60. Low coolant led to...
  61. Random hesitation/throttle surges at part-throttle (and rarely at idle)
  62. Sunroof adjustment specifications
  63. made it ALMOST 2.5 weeks in between trips to the dealer
  64. Rear Knock on bumps and movement
  65. OBDII code P2065
  66. HELP!! Blown radiator after aux water pump recall performed...
  67. help 08 MCS cranks but no start
  68. Just threw code P2885, charging press control min?
  69. Airbag Light Woes NOT Overhead Light
  70. Air noise
  71. Misfire multiple cylinders HELP
  72. CV Boot Replacement, Anyone with the Bently Manual?
  73. Check Engine P1434?
  74. Tons of problems with MCS 2007 R56 65k, exasperated.
  75. To Replace Rear Struts, or Not?
  76. Overheating... still.
  77. orange key light & no start
  78. transmission mount
  79. Door speaker squeak/buzz
  80. Aux Water Pump Recall Letter?
  81. Disappointed - Timing Chain R56
  82. air conditioning / heat control lights do not alway turn on
  83. Air Bag warning light
  84. After Recall Pump Replaced - loss of performance
  85. Another check engine light thread...recall
  86. Will engine rebuilt solve Oil Consumption issue
  87. Dash Pad removal?
  88. Electric steering lock malfunction RED
  89. SZL Replacement Question
  90. Rocker arm troubles...
  91. Seat Heaters suddenly wonky
  92. Sunroof - loud cracking noise
  93. Gear box noise
  94. R56 Turbo 55K miles oil usage question
  95. and the fun continues...
  96. My engine wants to stall ...
  97. Yellow "Brake" Light - Hill Assist Fail
  98. Power mirror/seat heater fuse blowing in '09 Clubman S
  99. Latest problem
  100. AEM intake issue/flaw...
  101. R56 Headlight Problem, check engine light
  102. R56 2011 Oil Seal Leak
  103. Rear bumper fascia part number?
  104. '11 MCS starts then dies
  105. Shocks/ When to replace?
  106. Door Rattle (sooooooo annoying)
  107. I think my speedometer is off
  108. Valve noise when cold.
  109. Low fan not working possible solution
  110. Strange problem. Almost sounds like my Mini is backfiring!
  111. Possible Clutch Problem
  112. Weird engine sound in clubman s when accelerating
  113. Lower Radiator Hose
  114. Should MINI take a page from Lotus?
  115. 2011 MCS Hazard Lights Turned On Themselves and Now Headlights Turn Off
  116. Where is coolant bleeder screw?
  117. turbo oil feed line access from bottom?
  118. Primary Water Pump
  119. Half full check engine light came on
  120. MINI Extended Motoring Protection XXL
  121. Stuck between a rattle and a hard place
  122. Thousands of Minis and Mini Coopers recalled
  123. Valve Cover Gasket leaking prematurely?
  124. P0300 - Cylinder Misfire Detected - What should I do?
  125. MINI USA Announces Water Pump Recall Affecting 89,000
  126. Oil Leak!
  127. Need Dealership information
  128. Broken Spark plug caused $8000 Engine damage
  129. Predicting 6 speed auto troubles?
  130. Knocking and clicking from manual transmission
  131. Anyone hear a slight scrape sound at ~2k to 2.5k rpm?
  132. Help Me Diagnose a Tranny Problem?
  133. The continuing saga that is our Mini
  134. 2011 non-s cooper cold start engine rattle
  135. Sound & Microphone suddenly dead
  136. Has anyone ever had their timing chain paid for by an extended warranty?
  137. Turbo Dead at 72K....
  138. 2007 MINI Cooper S won't start
  139. Coolant leak - oil filter housing?
  140. Approaching the line
  141. CEL on my wife's cooper
  142. turbo issues
  143. Part numbers required?
  144. Ignition Coil Cylinder 4 Error
  145. Hard Starting, Cold
  146. New to the Fam but has arrived with a few probs
  147. Mini Not Paying for Oil or Fluids Between Scheduled Maintanence
  148. 2007 MC S turbo problems
  149. Both Window Toggles won't work
  150. Red Warning Critical Failure
  151. Oil leak update/ question
  152. rough idle cold start R56
  153. Beware! Turbo design flaw
  154. Radio static
  155. R56 Justa Cooper - Cold Engine Rattle Clatter Noise
  156. Turbo\DV issue
  157. My Awful experience at Keeler in Latham
  158. Stupid question time...
  159. Engine Whine on an 08 Turbo
  160. Yellow Check Engine Light -But -No Code Thrown?
  161. a picture of the OXYGEN O2 SENSOR with socket
  162. MINI LINK not working?
  163. Thermostat leak
  164. MINI out of warranty, check engine light on
  165. Boost leak / coolant leak
  166. AC Compressor not turning on..any ideas?
  167. Knocking from right front wheel well
  168. 2010 JCW Clutch Issues
  169. Sunroof Sunshade Rattle
  170. Oil Change Mystery
  171. oil on turbo?
  172. HPFP, Timing Chain, Cold Start "RESOLVED" for 2011 and 2012 "S" Models?
  173. Weird warning light? Anyone else see this?
  174. 2011 MCS (Squeaky Engine Bay Sound) Video Inside...
  175. Rubbing sound at 1800 RPM take off......
  176. TPMS issues
  177. transmission no longer feels connected to engine
  178. Emergency! Engine/turbo failure possibly due to low/no oil
  179. Stuck sunroof, left side
  180. Power steering speed-sensitive question
  181. Automatic Transmission Stalls - Any Ideas?
  182. Sunroof buffer
  183. 2007 COOPER S - 82,000 miles - Repair, Scrap, Sue?
  184. Need some quick advice re: window problem
  185. Help me find Diverter Valve
  186. Power Steering Malfunction 2007 S
  187. 2011 just a cooper steering issue
  188. Several Problems with 08 Mini Cooper
  189. LOVE my car, but....
  190. hard start/rough idle 2007 R56
  191. Run Flat Tire Repair??
  192. Door not closing all the way?
  193. Spare fuse in fusebox
  194. Warped rotors
  195. Cheap online replacement bumper cover?
  196. Timing chain issue could also happen in 2010 r57?
  197. name that sludge :)
  198. Is it drivable with engine lights on??
  199. How, exactly, does the valvetronic software cause engine to 'slip'?
  200. Broken oil pump solenoid and thermostat
  201. 2012 Cooper Hatchback changes
  202. Slight grind between 1st and 2nd when cold
  203. Water pouring inside car when it's raining and you open the door(or window)
  204. HPFP symptoms list? I think mine died.
  205. Which dealer to use near Asheville for Timing Chain/Tensioner Failure
  206. Innovate OT-2 OBDII Gauges
  207. have a red warning light need some input
  208. replaced coolant temp sensor, cant get system to bleed
  209. MAJOR electrical issues, nearly every warning light went off
  210. Interior lights flashing?
  211. Half engine power... Supposed vacuum pump issue.
  212. "The Rattle"....
  213. so help me out here
  214. What's that rattling sound?
  215. MINI Service Common Sense?
  216. New Key Charging Error
  217. Anyone do SIM110207 themselves
  218. 2007 All motors...going...
  219. Xenon Control Module bad ... replace myself?
  220. Increased Emissions: O2 Pumping Current Sensor Open Circuity
  221. Roof Rack Clearance
  222. no start condition, starts on ether, runs fine after. every day
  223. Clubman S - brakes
  224. Cold start on 2011? Anyone?
  225. Thermostat DIY
  226. Cold Engine Rattle/Knock but NOT timing chain tensioner
  227. Sport Mode Default
  228. Leaking Oil/Coolant Again!
  229. 2011 MCS Magnetic Drain Plug Pics @4500 miles
  230. Turbo Oil Pipe Leak
  231. Back Up Key Issues
  232. Best anti-scoop melt product
  233. Engine stalls on cold start
  234. Help with CEL Code
  235. Wheel well
  236. coolant fluid reduce
  237. Mini From a Flood
  238. Timing Chain Tensioner Measurements
  239. Headlight problem
  240. "Lines Cut" on Rear Passenger Window
  241. Not another cold start issue? Searched and not found anywhere else.
  242. Rear Sway Bar Bushings Worn? R56 2008 justa Cooper
  243. Cam tensioner replaced, cold start rattle gone!
  244. 07-08 R56 NHTSA Complaints--Spontaneous engine bay fires
  245. Harsh Bump Causes Airbag Warning Light to Illuminate
  246. I Love driving, but hate owning my Mini
  247. Newbie question
  248. Important facts about stupid "ETHANOL""
  249. Unusual sound from engine
  250. D.A.B/Battery/ECU/Memory/Sunroof help please :)
