Engine Whine on an 08 Turbo
Old Dec 22, 2011 | 08:22 AM
dbhouston's Avatar
dbhouston
A few days ago, my Clubman S with Stage One package started to make a very noticeable whine as the engine revved and accelerated. When I shift gears and the RPM's go down, the whining noise lowers as well. I have 70K miles on it.
Anyone else have this come up? Don't want to take it to the dealer just yet until I get some idea of what it might be from others.
Thanks.
Old Dec 22, 2011 | 08:41 AM
Bmont82's Avatar
Bmont82
I have a whine as well. But it's completely dependent on the engine temp. At cold it has a very noticeable whine, as it warms up it slowly gets quieter. At operating temp it is gone. It is currently at the dealership being looked at. I'll let you know when they find out what it is.
08 mcs
Old Dec 22, 2011 | 09:45 AM
Bigprfed22's Avatar
Bigprfed22
Stage one meaning? Does the whine follow the rpms, or does it follow the boost map/curve? Does this happen in/out gear?
Thanks.
Old Dec 22, 2011 | 09:54 AM
08Dark's Avatar
08Dark
My 08 S whines as you describe and I've found that its the friction wheel. With my car running I can pull on the friction wheel toward the passenger side of the car and the whine goes away. I've already replaced the friction wheel and belt once and it helped(quieter), but the noise is still there. Hopefully you have a similar issue and its not turbo related.
Old Dec 22, 2011 | 10:01 AM
Bigprfed22's Avatar
Bigprfed22
You referring to the belt tensioner?
Old Dec 22, 2011 | 10:40 AM
08Dark's Avatar
08Dark
No, the friction wheel is between the belt and the water pump.
Old Dec 22, 2011 | 10:49 AM
Bigprfed22's Avatar
Bigprfed22
Understood, i didnt even now there was one in there, i have been schooled
Old Dec 22, 2011 | 12:01 PM
Bmont82's Avatar
Bmont82
08 mcs
So I'll reply to my own reply. Just got my MCS back from the dealer. The whine they called "normal". Not fully convinced but will have an independent mini specialist as a second opinion. Mine was not transmission related, followed engine rpm, with clutch out. Also had in the the engine that would happen at random times, not necessarilly temp related. Turned out it was the oil pump.
Old Dec 26, 2011 | 04:40 PM
dbhouston's Avatar
dbhouston
It varies directly with the RPMs.
Old Jan 4, 2012 | 07:30 AM
dbhouston's Avatar
dbhouston
Well, the heat went out as well and today the temperature light popped on. It is at the shop right now. We shall know soon.
Old Jan 5, 2012 | 06:20 PM
dbhouston's Avatar
dbhouston
Heat issue was a cracked thermostat housing. So that got replaced and heat works fine. Mechanic couldn't pinpoint the source of the whine. On the way home, I noticed the turbo wasn't kicking in. Then the Check Engine light came on. Back to the shop tomorrow.
Old Jan 6, 2012 | 07:01 AM
ThePenl's Avatar
ThePenl
Rpm dependent whine and 70k is most likely to be the turbo.
Have a look at this for a starter...https://www.northamericanmotoring.co...sign-flaw.html
And this...https://www.northamericanmotoring.co...ad-at-72k.html
Old Jan 22, 2012 | 10:08 AM
dbhouston's Avatar
dbhouston
Update: Entire timing chain assembly replaced. Dealership said it "exploded" and there was metal all inside the engine. Great. $2000 later.... Turbo working and no whine. I don't know what to think except that I'm done with Mini.
Old Jan 22, 2012 | 04:11 PM
gregsmini's Avatar
gregsmini
Wow, it's disappointing the diagnosis by the dealer was done so poorly. This is a well known problem and I would think they should have know to check for this.
Did your Mini ever have the timing chain repaired or the tensioner replaced previously?
If so, how long ago was it?
Old Jan 28, 2012 | 07:05 AM
dbhouston's Avatar
dbhouston
I had reported the cold start chatter before, but dealer always said they couldn't replicate it.
I traded in my Mini for a Camry day before yesterday. Mini has proven to be an expensive habit I needed to break before it broke me.
Dec 5, 2016 06:31 PM
KrisMiss
Jan 3, 2016 02:02 PM
damncajun
Aug 17, 2015 08:25 PM
Powershift
Aug 16, 2015 05:14 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
