Thermostat DIY
Old Nov 2, 2011 | 11:08 AM
cosmosmpower's Avatar
cosmosmpower
Thermostat DIY
Did a quick search and didn't see anything. Is a bad thermostat easy to replace? Evidentily we have a small leak and dealer says it's from the thermostat housing. I think I've read that it's a fairly common issue. Is there a TSB or anything out there?
Old Nov 4, 2011 | 04:19 AM
countryboyshane's Avatar
countryboyshane
Not sure about a TSB. I'm sure someone has done it before somewhere on the web in DIY form. To get at the thermostat housing you need to take the entire airbox and turbo inlet piping system off, then remove the snorkel tube that delivers fresh air to the airbox. One this is removed you should be able to see the thermostat housing close to the rear of the engine. It almost looks like a heart. You have to replace the entire module.
Old Dec 6, 2011 | 02:12 PM
dmeadow's Avatar
dmeadow
There is a DIY here:
https://www.northamericanmotoring.co...hermostat.html
Probably should be in the "How to" forum. A little hard to come up with in a search.
vulkandino
Oct 31, 2015 08:29 PM
Cruzer214
Oct 11, 2015 07:45 AM
navybsn
Oct 4, 2015 03:27 PM
M7Speed
Oct 1, 2015 07:05 AM
tag1260
Sep 29, 2015 03:53 PM
