Rear Sway Bar Bushings Worn? R56 2008 justa Cooper
Old Oct 18, 2011 | 08:21 AM
walk0080's Avatar
walk0080
Old Oct 24, 2011 | 12:55 PM
33EJB's Avatar
33EJB
Originally Posted by walk0080
Just took my 2008 MINI Cooper in for it's "Vehicle Check" around 49,000km. Anyways, they say they replaced the rear sway bar bushings as they were worn. Is this common? I'm not too concerned as it was replaced under warranty, but I am still curious. They also replaced the worn chrome ring around my key fob
MINI replaced my '08 Justa sway bar bushings at around 25,000km (I think). They've been fine ever since - now @ 68,000.
Worn plastic "chrome" ring on the key is a really common thing. You'll notice that the new replacement is actually real metal - imagine that!
__________________________________________________ _
Old Feb 3, 2013 | 06:51 PM
nutsofamily's Avatar
nutsofamily
Did mine by myself in 1/2 hour, parts 11 bucks each
Easy,
No more rattle
Old Feb 3, 2013 | 07:30 PM
Bilbo-Baggins's Avatar
Bilbo-Baggins
The other thing that goes is the front control arm bushings. They start to rattle when you hit bumps. So much quieter after they are replaced. Went with the poly bushing, myself. No increase in HNV, just much quieter. Also improved the handling, especially the "turn-in" and bump steer under braking.
Old Feb 3, 2013 | 07:56 PM
RJKimbell's Avatar
RJKimbell
Already done...
I've already replaced both Rear Sway Bar and Endlinks with Alta Performance!!
Just replaced Molly's Control Arm Bushings with PowerFlex Bushings!!
Toolman
Jan 20, 2016 06:50 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
