R50/53 I have 02-02 R50. Weird strut mount problem. Thoughts appreciated!
Old Aug 7, 2015 | 05:39 PM
ClayTaylorNC's Avatar
ClayTaylorNC
So I have one of the pre 03-02 manufactured R50's. I just attempted to put on my new coilovers and ran into a problem. The rears popped in just fine, but the front was a little weird so I did not install yet. For starters, the sway bar link mount is vertical instead of horizontal (no biggie, just got adjustable links). The other problem is I hear that my strut mount itself is different from the 03-02 man. date and forward. Now, my thoughts are that I can just get aftermarket camber plates to bypass the plates entirely. Is that correct? Does anyone know if it is just the bearing itself is different, or are the three bolts for the plate itself different too? I am really hoping the 3 bolts are the same so I can just swap out to aftermarket camber plates and sway bar links and be done with it.
Here are the AFTM plates I am referring to, even the add says 03-02 and up in the compatibility section: http://www.ebay.com/itm/MK1-Camber-Plates-Mini-Cooper-Pillow-Adjustable-Strut-Mounts-For-Coilover-Kits-/380556803678?fits=Model%3ACooper&hash=item589af3fe5e&vxp=mtr
Thoughts greatly appreciated!!
Old Aug 8, 2015 | 06:15 AM
ClayTaylorNC
Reading over my question, I think I made it a little convoluted. Bottom line question is: Will those camber plates fit on my 02-02 Cooper. Seeing that is says 03-02 and up. Are the 3 bolts the same?
Old Aug 9, 2015 | 08:35 AM
Sc00terbum's Avatar
Sc00terbum
I have an early car too and ran into this. Mount holes are the same. Struts, mounts and springs are different. There was a bulliten about this after the redesign. In areas with rough roads, I guess the early mounts were prone to breaking. If a car came in while under warranty with broken mounts, it got retrofitted with the new later struts, mounts and springs. Hope this helps
Old Aug 9, 2015 | 08:49 AM
ClayTaylorNC
Wow. Thank you thank you thank you!!!! I have searched and called everywhere (including the dealer) and everyone was clueless. So to be clear, since I am using coilovers (come with the small diameter top spring perches), I will be OK ordering any strut mounts 2002 and up right? And they will bolt directly to the 3 bolt holes?
Old Aug 10, 2015 | 05:37 AM
wilkrod's Avatar
wilkrod
strut mount
I also have an 02/2002 Justa.
I added koni fsd, and IE camber plates, bolted right up.
Jeff
Old Aug 10, 2015 | 06:40 PM
ClayTaylorNC
Jeff
Thank you very much!
Old Aug 10, 2015 | 09:19 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You need to convert the car to the new style mounts and sway bar end links. The parts for the early style are not all avail anymore. Depending on what your using we can get you most the parts used, and then you will only need a few new parts.
iggi
18
Feb 9, 2026 01:00 AM
Alkaidovich
Jan 30, 2021 01:35 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
sabjcw
Aug 14, 2015 07:40 AM
