R50/53 R53 Cold Start Problem
Old Aug 5, 2015 | 12:13 PM
iggi's Avatar
iggi
I have a 2005 MCS with about 68k miles on it. I bought it about 2 months ago and after owning it about 2 weeks, it seemed to develop a cold/cool start problem. If I let it sit any more than 30 minutes, it seems to struggle to start (even though it's warm), over night, it takes 3-4 tries to get it to start. When it fails to start, it rocks, misses, and struggles to get going. The weird thing is once I'm able to start it and it idles rough, simply giving it enough gas to go to 2k rpm makes all issues go away for the remainder it's running. Revving the car and immediately shutting it off before I leave it for a few hours seems to help, I'm thinking maybe Injectors?
About 3 weeks ago I swapped plugs, wires, and coil pack (it was rusted on #3), but it hasn't resolved the problem. I've tried fuel injector cleaner, STP complete system cleaner, and I have a bottle of seafoam to try next. I've also tried resetting the ECU. Any help is appreciated.
I recorded it on video, but the audio is a bit off sync. Normally I don't rev it this high to get the issue to go away, but it was struggling and it just picked up.
Old Aug 5, 2015 | 12:37 PM
JABowders's Avatar
JABowders
Veteran: Army
You would really have to pull the codes to help make a guess. I would lean toward the MAP sensors. But the codes would really help.
Manifold Absolute Pressure (MAP) Sensor
Temperature and Manifold Absolute Pressure Sensor (TMAP)
Motor on!
Old Aug 5, 2015 | 12:50 PM
iggi's Avatar
iggi
There are 5 codes in the system:
P0340 - Cam position Sensor (I replaced when I replaced the coil pack)
P0302 - Cylinder 2 Misfire
P2300 - Ignition Coil A (happened when I didn't have the coil pack plugged in after changing it)
P2303 - Ignition Coil B (Didn't have coil pack plugged in after changing it)
P1498 - No idea what this is MAP maybe?
For some reason my Innova 3160 nor my Toque app with a panlong bluetooth ODB2 seems to be able to clear the MINI codes. (they say the do, but don't)
The weird thing is after doing all of my service (cam sensor, valve cover gasket, engine mount, and what I listed above) it ran OK (maybe a little hesitation), but well enough for the CEL to actually go away until about a week ago when it really started having trouble.
Old Aug 5, 2015 | 12:53 PM
iggi's Avatar
iggi
Sorry, I remember what P1498 was! I didn't have the intercooler boot on all the way when I put it back together and the vacuum was reading low. I fixed it and the CEL went off shortly after.
Old Sep 8, 2015 | 03:14 PM
Steffen.Johnson's Avatar
Steffen.Johnson
2005 r53 Mini Cooper S R53 Cold Start Problem - YouTube
Did you end up finding out what it was? I am having similar issues and have had a P0340 code pop up today as well.
Old Jun 14, 2016 | 07:49 AM
DrewWphoto's Avatar
DrewWphoto
Dang, I wish there was a follow up in this one. Same sort of thing for me but not quite as bad as you.
Old Jun 14, 2016 | 07:57 AM
DrewWphoto's Avatar
DrewWphoto
Never mind, just read your YouTube comments. For anyone looking for the cause for this one it was a warped cyclindar head.
Old Jun 14, 2016 | 07:51 PM
Steffen.Johnson
This was caused by a warped head? So was the head gasket blown too? And what did you end up doing to fix it?
Old Nov 2, 2018 | 07:07 AM
Yesman's Avatar
Yesman
There are 2 failure modes. One is electronic/controller the other is mechanical. If the car revs to about 3000 rpm and stays there, it is limp home mode (electronic/controller/servo). If the car revs easily to almost redline (1st gear only, and also reverse). It is mechanical. Please read the attached to familiarize yourself with the CVT.
Posted to wrong thread !
File Type: pdf
Old Nov 6, 2018 | 10:51 AM
IQRaceworks's Avatar
IQRaceworks
I'm curious about this too. It doesn't make since that a warped head/bad gasket would all of a sudden fix itself as soon as the motor is revved up a little. Definitely sounds more like an electrical/sensor type issue.
Old Jul 21, 2019 | 10:07 AM
Minidogger's Avatar
Minidogger
I had idle problems & got a code for MAF sensor. I cleaned sensor, cleared code, problem has not come back.
Old Nov 13, 2019 | 10:00 AM
Basher's Avatar
Basher
R53
Just finished rebuilding mine, now I'm storing her to watch the market. Figure in 20 years my 03 will be worth heaps.
Old Feb 10, 2020 | 06:18 PM
MiniKar's Avatar
MiniKar
? My Mini S is a little rough when I start it.
Maybe it time for a tune since its been 10 years.
Old Aug 4, 2020 | 11:56 PM
Asrani 79's Avatar
Asrani 79
Mini c
cooper s crank but wont start
Old Nov 23, 2020 | 08:47 PM
Doug Glore's Avatar
Doug Glore
mine was a head gasket. I used a endoscope to look im my cylinders after it sit all night. Don't start it just pull the plugs one at a time, and look for small amounts of coolant sitting on the piston, or stuck to the cylinder wall. I tried everything before I happened to check that. It was hard to start, but after it started it ran fine. I was Also having heater problems. Mini's are notorious for the head gaskets failing. It's easy, and fast way to check. I really hope this helps.
Old Feb 5, 2022 | 04:05 PM
Cliffccc's Avatar
Cliffccc
Always buy oem sensors, especially the cam and crank sensors. They operate at a lower voltage than the others, the battery is in the back, when starting the voltage drop in the engine bay is significant, aftermarket sensors don't work properly with the voltage drop making your car hard to start and or the lights to come on after it starts (traction etc).
Old Mar 6, 2022 | 10:08 AM
Raven Mocker's Avatar
Raven Mocker
Posted on wrong thread please delete….
Old Sep 2, 2023 | 03:06 PM
Brainsick's Avatar
Brainsick
Spark plug wires
Same thing was happening to mine they were the ngk and they would snap in tight but they were no good , put the oem wires back and problem solved
Old Feb 9, 2026 | 01:00 AM
GeorgeKimble's Avatar
GeorgeKimble
CONGRATULATION on your beautiful new MINI Cooper S! The High Class Gray is gorgeous, and you seem to really enjoy driving the little car, which is a blast to drive, by the way, in the city or on the twisties. Your Picasa photo album is a clever way to post all the details without cluttering the post. By the way, I have also found the value in utilizing local resources to service and check on the car, e.g., regular checkups on the car with Metrowest car service, etc. Have you found the car to work well for long trips, or is this a strictly city car for you?
SlowR53
Jun 23, 2019 06:41 AM
action428
Jun 17, 2019 06:33 AM
Idoitforthegas
Aug 30, 2018 12:03 PM
na8flush
May 5, 2017 08:38 AM
scolburn79
Jan 6, 2008 10:33 PM
