View Full Version : Stock Problems/Issues
- phantom fan and dead keyfob
- Changing xenon bulbs shorted FRM? Confused and frustrated
- Cylinder 2 misfire?
- Major coolant leak R56
- N18 water pipe clip is an SOB
- Auxiliary Water Pump Not Coming On
- Rough Idle on Cold Start with Jerky throttle N12
- Intermittent acceleration problem
- Oil filter housing seals
- Wheel speed sensors or ABS Module?
- Do I need a new engine?
- Clutch Pedal Engagement Point
- Diagnosing oil consumption
- Can't find the clunk
- Oring behind the water pump
- Thermostat & water pipe fittings
- Electrical/Starter issue???
- 2010 Mini Cooper S cranks but not start, no spark
- Fuel Filter
- no pt can bus from dme
- N14 Intake Valve Rocker Fell Off...
- Ran out of gas. Now no start! Stuck in parking lot!
- Clubman barn door problem
- Rear brake caliper piston won't screw in - help
- No idle after rebuild.
- P115C Help
- Whiny fan noise when accelerating
- Engine buzzing briefly in low RPMs (cold)
- stuck open wastegate?
- Intermittent oil light
- R56 Rear View Mirror
- Help needed - stuttering/stall
- Stuck Flywheel Alignment pin...
- 07 R56 Fuel Line Thread Size
- Con rod bearing weirdness
- P0012 won't clear
- Evap leak after walnut blast
- P0015 Exhaust Timing Over Retarded
- Warping rotors
- Valve Cover Oil Leak
- 06 mini turns over won’t start after battery was hooked up backwards
- The dreaded timing chain
- Should I change the Valve Cover?
- Vanos solenoid missing?!
- Fixed my P053A code
- HEELPPP!! (Clutch)
- P0597 question
- Replaced Valve Cover Gasket and PCV Diaphram
- Possible pcv diaphragm/valve cover leak?
- 2007 r56 issues
- is this safe to drive?
- Engine Surging
- IN need of some major help from you wonder(fuel) people
- Something Wrong . Warning light Chaos .
- Turbo problems
- flywheel help DMF vs SMF
- Drivers Side Footwell Leak?
- Engine malfunction/power loss
- Good Independent Mini/BMW shops around Montclair, NJ!
- mass air flow plausibility
- 2009 JCW limp mode after getting in boost
- 2009 Clubman Serpentine Belt
- unlisted bolt torque specs ?
- 2007 Cooper S (N14) Oil pressure Loss! Need ideas!
- Carbon build up issues
- 2008 R56 JCW won't start
- 2013 R56 problem..read the description plz
- Possessed Gauges! (Intermittent Electrical Issue) Please help!
- "Half" Engine Light
- Coolant Temp Sensor and Thermostat Housing
- Two quarts low on oil and loss of power but no low-oil indicator!!!
- Tracking down an intake leak, anyone know what this is?
- Windows whistling - picture attached
- Spilled water, now airbag and seat belt lights
- Cylinder Misfire
- Electrical gremlins when it rains
- Thermostat Housing and crossover pipe
- some coolant in the oil, but not much
- Missing hose on Intake?
- Air Conditioning Pressures Don’t Make Sense
- Just did the clutch clutch fork doesnt spring back
- 2013 mini cooper transmission dead????
- Windows/headlight switch not working
- Malfunctioning High Pressure Fuel Pump - R58S (N18)
- Paddle Shifters completely dead don't work
- 13 cooper wont start
- Vacuum pump replacement - R56
- P2171 intermittent
- P0597 after oil filter housing gasket
- Burnt exhaust valve: intake cam timing offset a possible issue?
- Engine Timing? N14
- How reliable are the 2nd gen Minis?
- Columbus Ohio indy's?
- Windshield cowl is not flush.
- Is this a missing trans bolt?
- I need help to identify a oil leak from the top of transmission
- Light after hooking up battery again
- Flapping sound matching engine rpm
- troubleshooting P2171 intermittent
- Coolant leak found - but what part is it?
- 2010 Mini Cooper S vacuum pump leaking oil. How critical is this?
- Broken Spring in OFH?
- 11 S jerky aceleration and high idle
- Stop start neutral position sensor location
- Brake / Clutch Bleed
- Footwell Ambient Lights don’t work
- Dead Mini
- need serious help please, alternator
- What module controls the thermostat? I am on my 3rd and out of ideas
- Thermostat housing with sensor,
- Passenger side axle output shaft seal
- thermostat house ?
- water pipe btw water pump and thermostat
- Replacing VANOS Solenoids and Chain Tensioner
- 07 R56 MCS with only 56k miles having HPFP issues
- Szl/sas question
- Broken thermostat housing bolt in the block...?
- Oops..broke hose connected to coolant. Part number?
- Over torqued crankshaft bolt doing timing chain
- Turbo Spool Down Noise
- R56 Auto Oil Leaks
- Boost question
- P115c code 2007 mini n/a
- Engine Help
- Coolant Leak - Center
- VANOS Solenoid Replacement
- Coolant capacity include distilled water or not?
- Super Weird Problem with Starting
- Misfire Service Mode
- error code fuel level sensor
- Head removal: keep timing chain in?
- New Car Newbie - Bunch of Fault Codes Listed for 2011 MCS - Should I Worry?
- Gearbox axle shaft bearings
- New engine generating P0015 0x2d60
- Code P02EF and P02F1
- Radio pre-set buttons stopped working - Cause found
- Need Marker Light Connector Source
- N18 Can't find a new starter!!
- Shifter/possible transmission issue
- Looks like I got a milkshake and it's not bringing boys to the yard
- R56 N14 Mini JCW Engine Rattle
- Strange camshaft sensor issue
- n14 no oil pressure (no not the filter housing or pump)
- Spark plug 1 Soaked in Oil
- Limp mode and P1338 code after timing chain replacement
- 2010 R56 no start
- new here - P0304
- Check Engine Code P16E9
- Battery light and belt broke. Alternator or belt blame?
- Weird knocking when it's cold (not chain, nor vacuum pump related)
- Fan Staying after car is turned off.
- Battery replacement for 2012 Cooper S
- Looking at a Mini Cooper S today, just read about possible timing chain problems
- P112b
- Left tail light upper brake light not working. Bulb fine.
- No-Xenon Assembly replacement
- Dead Stereo, burnt electrical odor smell
- Replacing Aisin transmission in 2007 R56
- 2007 R56 No Key Respnse
- No heat at low RPM
- OEM vs Aftermarket Head Gasket
- HELP! Clutch woes in my new-to-me Mini
- Help with code 0x2D50
- Oil Cap Crankcase Vacuum Test
- Flywheel to crank bolts "feel" stripped
- Timing Chain Installed. Intake off 1/4 inch
- Nothing wrong here not the timing chain
- Xgauge with scanguage II for oil pressure, Unsure of readings.
- Oil leaks and other issues, help!
- 2011 mini s code/Fault help?
- R56 N16 cranks but won't start. Need help with decoding codes
- JUST Rolled over 100k today, and my gift - sounds like rod knock & I have no idea why
- New Timing Chain still has Death Rattle ?
- A Few R56 Mini Maintenance Questions
- 2010 cooper s hpfp
- Oil in boost pipe dry PCV hose?
- P0172 2012 Mini Cooper S R56
- No oil pressure
- R56 P129E code
- Video- Weird thumping noise when motor turned off
- Spec's for N12 Air Fuel Mixture
- Engine Light & low coolant temp
- Seatbelt light is on now
- Clutch issue.
- Fluid Bolt and Turbo Oil Line question
- Spare key and fob for my 2005 mini
- Air bag warning in cold weather
- Oil foam on oil cap
- Urgent need of valve cover dowel
- Are codes suppressed while reading live data?
- 2008 Cooper S 123k miles starts then dies
- Boost Problem! No Codes!
- New parts install question
- Oil leak R58
- ECS PCV valve cover patch kit
- N12 Rough Idle when cold, Possible PCV valve issue
- Speedo and tach issue with my 09 S
- How to remove a stuck LH drive axle
- 2007 Mini Cooper S won’t start
- P0303 error code
- Coolant Thermostat Adapter Lead placement
- Crossover water pipe
- Odd damage to head and pistons
- 2011 R56 non s cooling fan inop
- Almost TOTAL Confusion
- Fuel Pump not working... Do I have a bad Fuse box?
- Good NonDealer Service?
- Non dealer R56 N12 Tensioner Replacement etc...
- Intermittent DSC malfunction light only
- Brake Caliper leaking
- Tensioner and Mechanic
- Thermostat Code
- any "SN Plus" AND A3/B3 (or A3/B4) oils?
- In need of adapters for 2nd oil catch can
- 2013 R56S, how complex is a water pump pulley swap going to be?
- 2013 Hatchback (R56) Stuttering at ignition.
- While driving , it died then turned on.....HPFP?
- R56 N14 low mileage and slight vibration
- HPFP, could, or plugs...
- I dropped a socket wrench on my battery terminals. Various Malfunction lights
- Fuel injector testing
- Blower motor only works on low settings?
- Strange electrical problems?
- My Mini met a Dimensional Vortex
- Smoke after Long Idle
- C587 code error
- My 2013 mcs is having a bunch of electrical issues.
- Help save my Mini!
- P0010
- I need some HELP on a couple things (MCS JCW experts, step inside...)
- Show me where I can stick my borescope, baby!
- 2014 Clubman, O2 sensor not ready
- Purchase of O2 sensor for 2007 (R55) mini cooper S clubman
- Having trouble setting locking pin in flywheel
- Piston play??
- Help with boost issue
- Minis vs Automatic car washers
- Strange Audio Problem R56 Hifi White noise
- IPNA issues
- Rattle at Idle Cold Start......
- R56 cc id o31 trouble
- P1774 code error
- Unknown Hose
- another yellow check engine light
- High fuel pressure at idle
- HPFP issues... theory.
- loss of power at fuel pump fuse
- 4th cylinder problems
