Szl/sas question
Old Mar 17, 2019 | 08:38 AM
TheZeroHero2012's Avatar
TheZeroHero2012
Szl/sas question
So I’ve had a 2013 MCS for about a year. Shortly after I bought it I had the wavy road and steering wheel lights come on. After extensive research I concluded it was the dreaded szl problem. Well, I’ve finally had the time and resources to pull everything apart only to be absolutely stumped. I tried accessing it from the bottom of the steering column but couldn’t find it. When I removed the steering wheel however I found a manufacture date on my column date to be from 07. Now my question is: Who else has this happened to? Can I force an 07 szl to work? Should I just find a 2013 szl and try to integrate?
Old Mar 17, 2019 | 08:09 PM
mkov608's Avatar
mkov608
We need to know what DTCs are set in memory. "pull everything apart"? What did you pull apart?
"I tried accessing it ..." what is it? The SZL module?
Old Mar 17, 2019 | 08:33 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
If you have a failed SZL I would only recommend going with a new one as a used one may not work just because of coding, and when cars are wrecked the airbag going off usually also damages them.
Also it will need to be coded to the car and aligned.
We can get it for you if you email over your VIN, but they aren't cheap.
Old Mar 17, 2019 | 10:53 PM
TheZeroHero2012
5dfb is the only code. I have a Foxwell 520 I used to clear the code. Then I did a live data read and it said it’s -1• soooo I tried to recalibrate by removing steering knucle and trying to turn the wheel but it just says cannot communicate with the module. When I finally pulled the steering wheel, I saw the manufacture date on the center column (Szl column) and it says it was made October of 2007. I’m guessing that’s why I couldn’t pull the szl off the steering column from the back. I’ve heard that previous to the LCI, the szl was located behind the airbag. And it appears that is the steering wheel I have currently.
Old Jun 6, 2019 | 06:26 PM
TheZeroHero2012
So after taking everything apart, I now know I have a 2007 steering wheel from an automatic trans vehicle. It has paddle shifters and my car is a manual. So how do I correct the szl issue?
Old Jun 8, 2019 | 06:12 AM
mkov608's Avatar
mkov608
I would go to realoem.com, enter the last 7 of your VIN, find the part number needed for your car, and search the internet for the best price on the module.
Then used these steps to install it: https://www.newtis.info/tisv2/a/en/r...odules/HTxR0mr
Others are correct; the instructions says this component must be coded to the vehicle. You'll probably need an indy shop to help you with that step.
arebifrzok
Mar 11, 2019 07:41 AM
Timbo14
Suspension
Jan 15, 2019 07:25 PM
Pottery_Pal
Jun 10, 2017 05:10 PM
dwdyer
Dec 10, 2008 03:18 PM
