2010 R56 no start
Old Mar 9, 2019 | 05:56 AM
yaofeng's Avatar
yaofeng
2010 R56 no start
All of a sudden the 2010 Mini Cooper does not start. It has 70k miles. I replaced the engine at 40k miles because the darn plastic water pump impeller ruined the engine. The old engine is still in my garage. There is fuel when I disconnected the fuel hose. Still I replaced the fuel pump.
Replaced coils,
checked compression, #1 206 psi, #2 215 psi, #3 191 psi, #4 214 psi.
swapped both the intake and exhaust cam sensor,
Recently pulled the engine to put in a new clutch, replaced the crank pulley, bothe the front and rear seals. It ran okay after. A week later the no start came. Last diagnosis attached. I could not find my Carly plug in the house so I could not do another diagnosis.
Old Mar 9, 2019 | 07:00 AM
yaofeng's Avatar
yaofeng
Found the Carly plug. New diagnosis attached. Ignore the messages on the mass air meter and the air box. I disconnected both.
File Type: pdf
Old Mar 9, 2019 | 09:05 AM
yaofeng's Avatar
yaofeng
Removed #1 spark plug, connected it to the coil, grounded it. Cranked. There is no spark.
Old Mar 9, 2019 | 02:33 PM
yaofeng's Avatar
yaofeng
Swapped the crank position sensor. Still no go.
Old Mar 9, 2019 | 03:56 PM
MiniToBe's Avatar
MiniToBe
Did you check the fuses and relays?
do you hear the fuel pump priming?
did you check the green wire on the cylinder head (ground wire):
Old Mar 9, 2019 | 04:30 PM
yaofeng's Avatar
yaofeng
All fuses are fine. There is fuel in the fuel rail. Ignition coil wiring is grounded. The car started and ran for a week after I put in the new clutch, did the seals, pulley and put it back together.
Just did another diagnosis. See attached.
I wonder if the immobilizer code 00A10A: EWS$ timing challenge respond error is preventing the car to start.
Old Mar 12, 2019 | 10:53 PM
Sunny Chan's Avatar
Sunny Chan
I have the same exact problem and turns out my CAS was fried. BMW replaced my CAS and the juction box and it works like a charm, expensive though.
NCapurata
Apr 1, 2019 07:54 PM
Slyone
Jan 4, 2018 12:34 PM
Nikkielynn
Oct 12, 2015 07:33 PM
ericmakkar
May 20, 2011 05:16 PM
paulsminis
24
Feb 7, 2011 01:24 PM
