HPFP, could, or plugs...
Old Feb 11, 2019 | 09:23 AM
TheZeroHero2012's Avatar
TheZeroHero2012
Okay so I have a 2013 S Hatch that I bought at 36K. I have owned it for a year and have put about 30K on her. I had a coil pack go at around 50K. Previous to the replacement it had started sputtering or choking (like a misfire but no code) under full throttle. Then one day under full throttle the sputtering, threw me into limp mode and my car sounded like a diesel. I ran the codes, found a misfire, tested the particular coil for the misfire, replaced the coil, and erased the code. It was fine for another 5K and had similar issues. Got a cylinder 2 misfire. Repeated all the steps above again, except this time I replaced plugs as well. Now I am having the same problem. Weird thing is this time, there is no codes. Not through basic obd, schwabben, or my euro shop’s scan tool. So, I used obd to monitor FRP thinking that the HPFP could be the only other culprit. However, I’m running 900-1100psi on startup and between 1800-2000psi under full load. So, I’m doing my research I’m going to assume that it is not the HPFP. My question to the community is: Could my plugs have been pregapped incorrectly? Could anything have gone wrong with coil pack installation? And finally, do you think upgrading all of my coil packs and doing colder plugs will solve this issue?
Old Feb 11, 2019 | 10:30 AM
MiniToBe's Avatar
MiniToBe
the gaps can certainly change over time. You could try find the dead cyl by unplugging and plugging each coil one at a time noticing the engine smoothness. once you located the cyl, swap the coils or if you have a spare one to test.
Old Feb 11, 2019 | 10:45 AM
TheZeroHero2012
I tested the packs and it sputters on all of them. But I assumed the pregapped plugs were good. I have a few coworkers who said that the gap could be incorrect from the factory. Do you think it would be worth it to just upgrade the coil packs and plugs?
Old Feb 11, 2019 | 10:54 AM
MiniToBe's Avatar
MiniToBe
i believe the gap should be .36. since your engine is not modified, these plugs should be fine. I would suggest checking the gaps first. then checking the timing chain (just to be on the safe side)
Old Feb 11, 2019 | 12:03 PM
aunknown's Avatar
aunknown
Definitely check the gap before you guy buying stuff.
Old Feb 11, 2019 | 02:37 PM
TheZeroHero2012
Well it looks like the ones I bought were gapped at .026
jaequery
Jan 21, 2016 01:24 PM
2004JBMINI
Jul 2, 2012 12:02 PM
jggimi
Sep 16, 2008 11:48 AM
Archanum
Jun 17, 2008 01:40 PM
