4th cylinder problems
Old Jan 30, 2019 | 06:27 AM
soulala0593's Avatar
soulala0593
Hello!
So 2010 S Clubman started shaking and rough start/idle. Giving me random misfire and cylinder 4 misfires.
Here is what I've done:
Checked for leaks - none
Checked valve cover for cracks - none
Removed valve cover to replace gasket - no improvement
unplugged the electrical connector from each coil one at a time- when removing 1-3 the engine slows or almost shuts off, unplug 4 and nothing happens.
Swapped coils - same issue but still only on cylinder 4
Removed spark plugs - all looked good except cylinder 4 plug was black and covered in soot. (could not see anything wet or oily at the base of the plugs)
Replaced spark plug with new one - nothing
Checked that the 4th cylinder connector was sending power to the plug - check, it sparks!
So what is left now? Check the injector? Obviously things are working down to the spark plug but after that something is going awry.
Old Jan 30, 2019 | 07:20 AM
MiniToBe's Avatar
MiniToBe
as you said, you could check the injector. If you just remove plug 4 and start the car, there should be puffs of gas coming out. if there is gas puffs, you need to do a compression test.
Old Jan 30, 2019 | 10:52 AM
soulala0593
so I took it to the mechanic to check the injectors. Apparently they work fine and are clean but there is 0 compression to the 4th cylinder. All other three are between 170 and 190. Also they checked the HPFP and it’s perfect. So they’re thinking the motor. Took the valve cover off and the 4 springs look and move great. Now looking at it being a piston/cylinder block. Looking to replace the whole thing. Thoughts? Anybody seen this? They said it’s pretty common for the mini
Old Jan 30, 2019 | 11:05 AM
MiniToBe's Avatar
MiniToBe
every now and then, the exhaust valve burns or chips away. The repairs for this at a shop will cost a pretty penny. if you DIY, you can save a whole lot. Where are you located btw?
Old Jan 30, 2019 | 12:32 PM
soulala0593
Good to know! I’m in North Florida
Old Jan 30, 2019 | 04:49 PM
AZdsrt's Avatar
AZdsrt
Yep, bet it's a chipped exhaust valve. Have a leak down test done to know for sure. Somewhat common on these cars..
kennyshi
May 21, 2018 03:06 PM
beemboy
Mar 14, 2016 11:10 AM
eliseo1981
Nov 2, 2015 11:24 AM
JCampos
May 18, 2009 11:58 AM
Edge
Jan 29, 2006 09:00 PM
