Cylinder 1 Misfire... Which is Cylinder 1?!
Old May 16, 2009 | 11:09 PM
JCampos's Avatar
JCampos
Is it safe to assume cylinder 1 = the first cylinder from the left?
Old May 17, 2009 | 01:36 AM
Joser's Avatar
Joser
yeah follow your spark plug wires they are numbered too
Old May 17, 2009 | 09:23 AM
JCampos's Avatar
JCampos
aftermarket wires :\ (and coilpack)
Old May 17, 2009 | 12:37 PM
BlimeyCabrio's Avatar
BlimeyCabrio
1 is on the right side of the car (your left as you're looking into the engine bay from the front) - aka the US passenger side.
Old May 17, 2009 | 03:48 PM
Crashton's Avatar
Crashton
Blimey is correct. On inline engines #1 is usually the one closest to the front of the engine. IE the end with the belt.
I'd agree with a set of wires if your MINI has over 50,000 miles. They do wear out over time. Aftermarket coil pack, well not so sure I'd buy one. See if the wires cure your problem if not I'd go from there.
Old May 18, 2009 | 10:54 AM
schreiber117's Avatar
schreiber117
I think he was saying that that his wires are not numbered because they are after-market, not that this is his possible solution.
Sorry, I do not know which is cylander 1, but I think (based on previous f bangers) that Blimey is correct.
Old May 18, 2009 | 11:58 AM
herbie hind's Avatar
herbie hind
put the stock coil pack back on and try it if you've already cleaned all connections and checked plugs and ohmed wires . my aftermarket caused major issues about a year after install .
drrigg
May 27, 2022 03:31 AM
eliseo1981
Nov 2, 2015 11:24 AM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
SneedSpeed
Oct 1, 2015 03:01 AM
