loss of power at fuel pump fuse
One day last week, I went to move the 2008 r56 cooper s from the garage. Cranks but no start. It ran just fine 2 days before. From checking out the pelican part fuel pump diag steps. I have no fuel pressure,( undid the sub frame fuel line connection) .. and then pulled up the back seat. and checked for power @ the fuel pump. no power and no click. It did get 10.9 volts when I hit the key to start it, no power in the run poss ?? Checked for power at the fuse (f43) no power with a multi meter. The relay is after the fuse from what I read. I thought it mite be a crank poss. sensor. but I have spark I did test that.. I did run a hot wire to the fuse ( left the fuse in ) with the key in the run poss. no luck. Ran a hot wire to the fuel pump pin #2 blue and white, and grounded to the brown wire pin #5 and the pump came to life. So I m thinking the fuse box maybe bad ? or the relay or am looking in the wrong spot.
thanks Brian
thanks Brian
a jbe ?? what's that ? I've swaped relays, and ordered a new fuse box, they seem to have a history of going bad :(
sorry for no posting up sooner, it went to the dealer after cranking for 30 plus mins it fired up. they said the cylinders were flooded with gas, and had to use wd40 to wash them due to no compression in the cylinders. I find that funny, cause in the 30 days I worked on the car I didn't have fuel pressure !! I changed relays and a fuse box, they got it to run on hoockis poockis I guess. haven't had any issues expect the power seats didn't work when I t came back. I have yet to look in to that :(
Adam Smith (04-05-2023)
John Mitchem
07-26-2023 06:16 PM
