2007 r56 issues
Old Apr 10, 2019 | 09:12 PM
DarkMiniz091's Avatar
DarkMiniz091
2007 r56 issues
Ok so let me start out by saying that i bought this car as project/daily.
Day 3. Clutch goes, new one gets installed,
Day 5. having hard time starting, turns out needs a new timing chain. Done under recall.
Day 12. Battery terminals are missing parts for secure c9nnection, new battery and connectors.
Issues im still having
1. Coolant going missing but no oil or anything in resevoir tank. Used to have over heating issues until mini service fixed that during timing chain recall. Most likely culptit for coolant is thermostat housing.
2. Burning oil like crazy/ slight oil leak. This is the big one. I have multiple misfire codes across all 4 cylinders but good compression in all cylinders. Was told by mini during timing chain service That there was tons of carbon buildup. Do Hydro tunes since i have access to it. Need to probqbly do a walnut clean or whatever its called. Have oil all under neath where the tubro is but not directly under turbo itself.
Just looking for a little insight on what possible oil consumption and coolant leaks could be. Dont think i have a head gasket leak or i would have nore issues. I still have a hard time starting sometimes so im assuming 1 of the 2 furl pumps is gping out. Any ideas or knowledge will help
Old Apr 11, 2019 | 08:00 AM
08miniS08's Avatar
08miniS08
Without pics, it is a bit difficult to diagnose blind, but:
1) coolant is likely t-stat housing and/or oil filter housing gasket and/or coolant pipe and/or hose connected under reservoir; pressure test the system and you will see where it it pouring out
2) oil can leak from a number of places, oil turbo lines, oil filter housing, front main seal, oil pan gasket, valve cover gasket, and vac pump leaks should be checked
3) misfires are typically plugs and coils, valve cover gasket can also leak here
4) hard/slow starting sounding like a lawn mower engine is typically the HPFP and needs to be replaced
Old Apr 11, 2019 | 09:15 AM
DarkMiniz091
2007 r56 issues
Thats sounds about what ive figured out for myself. Ill get photos later today and post them to you so you kind of know what im looking at underneath the car. I see no leaks from the top of the engine but plenty of oil on the underside where ypu cant see past the turbo.
Old Apr 16, 2019 | 07:06 PM
Mike Qualls's Avatar
Mike Qualls
07 with a thermostat code. Garage said everything checks out good. Said that the parameters on the thermostat and the computer are different. Went back to the and they opened up the parameters all the way. Check engine light was off for 2 days and now is back on. Any ideas?
Old Apr 16, 2019 | 10:06 PM
DarkMiniz091
2007 r56 thermostat code
Between me and you I would just go to FCPEURO.com and get a new thermostat. It's a one part from Germany and it's like $80 for it. Fairly simple to drain coolant, change thermostat out, and refill with coolant. YouTube is my best friend with this car.
Here is the link for the thermostat
https://www.fcpeuro.com/products?utf...er+thermostat+
Old Apr 17, 2019 | 04:25 AM
Mike Qualls
Thanks. Had the car for 6 years. Changed the thermostat a couple of months after I got it and I’m on the third one now. I’ve been told the same thing by two different garages. Both say there is nothing wrong with the thermostat and it’s not hurting the car. Just hate seeing that light.
Old Apr 17, 2019 | 08:44 AM
DarkMiniz091
R56
I know how you feel. I just got mine and I've already sunk $1000s into it. Still gonna have to do more too. Needs a new turbo, believe I have a head gasket leak(losing coolant somewhere), needs new o2 sensors, needs a HPFP, gonna put a bigger intercooler on it since the one on it is tiny for a turboed car, needs new headlights and dogfights seeing as 2 are broken and 1 is cracked, and will probably do new fuel injectors if I'm gonna tear the head off anyway. Gonna put in forged pistons and heads too. $$$$ tons of it 😂
trailrated
Dec 13, 2021 09:10 AM
Dorambo
Apr 24, 2020 12:43 PM
bflo
Mar 25, 2017 08:11 PM
