Thermostat & water pipe fittings
Old Apr 21, 2019 | 12:58 PM
idickers's Avatar
idickers
I am replacing the thermostat on our 2009 Clubman S, and the hard plastic water pipe that connects the water pump to the thermostat broke where it attaches to the water pump. When I removed the water pipe, it appears to have a flange for a bolt that was not present, and realoem does not show the bolt, and I can't find a spec. Is there in fact a bolt that might mount this to the engine block a little more securely?
Old Apr 21, 2019 | 03:00 PM
MiniToBe's Avatar
MiniToBe
that is not for a bolt. there is a plastic wire holder that attaches on it. most of the time, once you pull it, it breaks!!! not a big deal though
Old Apr 23, 2019 | 06:34 AM
idickers's Avatar
idickers
Thanks for the quick response. It looks like the thermostat just seals against the block housing by the gasket, with no groove or centering other than than what is provided by the 3 mounting bolts. Is that correct?
Old Apr 23, 2019 | 06:36 AM
MiniToBe's Avatar
MiniToBe
100% correct.
The pipe and thermostat are aligned though. notice the notch and groove on them.
Old Apr 23, 2019 | 02:28 PM
idickers's Avatar
idickers
Thanks for the confirmation. Yes, with the notch in the water pipe everything lines up nicely once the bolts go in.
cheetoman
Jun 7, 2019 08:55 AM
MtDew
Sep 25, 2017 09:38 AM
greentrees
Jul 14, 2016 08:18 PM
Pepelx
Dec 30, 2015 05:08 AM
zamfield
Jul 20, 2012 05:49 PM
