Head removal: keep timing chain in?
Old Mar 12, 2019 | 11:36 PM
cpmetz's Avatar
cpmetz
Have a JCW that needs head work (burnt valves).
Looking at a couple threads, some folks seem to keep the timing chain in, keeping tension on it with bungee cords.
Any thoughts on this? The JCW had the chain recall done pretty recently.
Thanks,
Philip.
Old Mar 13, 2019 | 05:13 AM
MiniToBe's Avatar
MiniToBe
you could hold it or even drop it, there is no right or wrong. however, you have to remove the sprockets because when you set the timing, you want to allow the chain to take its best position before torquing. You also have to release the crankshaft bolt. I hope this helps.
Old Mar 13, 2019 | 05:34 PM
mkov608's Avatar
mkov608
Thanks,
Philip.
First, don't believe every thread you read. Follow the manual. Second, get all your valve seats replaced while the head is in the shop. They tend to fall out once the head gets too hot.
Old Mar 14, 2019 | 12:06 AM
cpmetz's Avatar
cpmetz
Just what I wanted to hear.
weaver9000
Sep 14, 2015 05:48 PM
gbfan10
23
Dec 12, 2012 08:26 PM
5810
Nov 17, 2010 10:49 AM
turnkey
Jun 30, 2007 09:27 AM
