PDA
View Full Version : Stock Problems/Issues
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. MAF Sensor Issues
  2. 2007 Cooper S Starting Issues - Any Help
  3. Turning N14 engine by hand?
  4. Fan running after shut off
  5. 2013 JCW Hardtop fuel filter ??
  6. Desperate Need Of Help!!!
  7. how many sensors?
  8. Probably a stupid problem... dash lights off
  9. P0015 tried it all...
  10. Squeal from engine compartent at certain speeds
  11. 2011 Cooper Window, Battery, Electrical Issues & Confusion
  12. Odometer(vehicle mileage) resetting!
  13. P0013 "B" CMP Actuator Ckt (B1)
  14. RFID = Bad for Your Mini
  15. Another CC-ID 029
  16. Driver's door open warning light won't go off (07 R56)
  17. 2007 Project
  18. 5DEE - Control Module Supply
  19. Has anyone had a manual transmission warrantied out (2013 MCS) ?
  20. 2012 MCS Engine Replacement
  21. 4 ways to modify or read the dipstick
  22. Central PA Service location needed
  23. Red Temperature Light
  24. Sat Radio ....acquiring.... no audio
  25. Looking at a used R56 coming from owning an R53 - what to watch out for? General Q's
  26. Dipstick Fix!
  27. Broken hood latch
  28. Engine needs replacement after only 3.5 years; excellent condition to toast in a day
  29. Wierd Sound
  30. Moonroof stuck on 07 S
  31. 2007 MINI 2 door hatchback problems-Help!
  32. 2009 Clubman S - New Engine at 55,xxx Miles :'-(
  33. 07 Mini Not Downshifting When Stopping
  34. "Rattly" engine
  35. Water Pump replaced now No Boost?
  36. Warrantee expiring, what should I have checked
  37. surge and bucking when accelerating hard
  38. 2007 Mini Cooper S John Cooper Works no start
  39. P2418 & P1447 codes.
  40. Strange thumping
  41. why?
  42. Error in secret menu
  43. Carbon build up causes timing chain rattle?
  44. Timing chain parts replaced but....
  45. Coolant Hose , then Sport Button, now entire radio???
  46. oil light issues
  47. Constant Rough Idle at Full Stop
  48. 2013 MCS Backfiring in 3rd/4th?
  49. Loose brake pedal?
  50. Check engine light and misfire: Mini cooper S 2009
  51. K104 Relay auxiliary water pump anyone know where it's located
  52. Coolant leak - Thermostat housing or Water pump?
  53. Idle Misfire & Surging
  54. Need repair advice
  55. Another Oil Leak
  56. Clear fluid dripping
  57. Replaced Timing Chain - Car No Longer Starts
  58. Help
  59. overheating 2009 clubman
  60. Loose shift lever? Maybe?
  61. Door lock pins
  62. What is the best way to prevent the Timming Chain to fail?
  63. HELP! >>> Mystery clutch issues in 2008 Mini Clubman
  64. 2010 Baseline Cooper Idle/Stall Problem
  65. Does anyone have a list of voice commands?
  66. AC Doesn't Work / Radiator By My Feet is HOT
  67. carbon and n 18 engines
  68. Replacing oil pans (low car problems)
  69. P0597 code
  70. Oil on plug, various other issues
  71. Vacuum line problems
  72. Timing chain tensioner class action
  73. R56 Sunroof Rattle- want to avoid a whole new sunroof!
  74. Coolant
  75. Motor spinning noise coming from around gas tank.
  76. CEL P2418 Evaporative Emission System Switching Valve Control Circuit/Open
  77. Loss of power but only sometimes after startup when the car sits for a few hours
  78. Random loss of certain MPH's available in cruise
  79. Crankcase housing
  80. Car won't start - Coolant temperature sensor replaced
  81. P15FD - Engine shutdown time: Too slow in shutdown phase
  82. HELP Engine Rebuild!!!!!!!!!!!!!!!!!!!!!!!!!!!
  83. Mystery CELs - P2B5B/C
  84. MCS Won't Lock/Stay Locked
  85. Rear suspension
  86. Engine light after track day
  87. Engine light after track day
  88. What should I do about my clutch problem? Need advice on how to talk to dealership
  89. Expanding screw thingys in fender well
  90. Blown OEM rear shock at less than 20,000 miles?
  91. Possible Belt/Pulley Vibration- Maybe engine knocking
  92. $2K service bill a rip-off???
  93. What is wrong with my ac ???
  94. '13 N18 Service Intervals
  95. P1497 & Rough Idle - Not the valve cover!!
  96. Grinding noise coming from car.... only 13,900 miles???
  97. Missing Part In Engine Bay?
  98. Car still stalls at cold start up.
  99. Need help adjusting cam timing
  100. Replacement key fob
  101. How to screw up an OCC install
  102. Lowering Spring Clunking/Knocking? Help!
  103. keyless comfort lock button doesn't work
  104. p2402 check engine light help! 2009' hardtop S
  105. R56: Broken Exhaust Valve + Possible Blown Motor
  106. Front strut stud/pin broken..help!
  107. Low Oil Level
  108. Gear selector nylon bushing on tranny gone bad ??
  109. 07 R56s off the line dead spot
  110. Burning too much fuel!
  111. Sunroof operation problem?
  112. R59 Roadster Top Wear Marks
  113. Driver's Door Hard to Open
  114. Wheel shaking
  115. Need help to do a compression test
  116. Air Conditioning
  117. P1497...misses from take off.
  118. 08 Base Cooper - Atypical Coolant Loss?
  119. crank gasket leak
  120. Yellow Check engine
  121. multiple fuel pump, battery replacements
  122. when AutoStartStop isn't functioning...
  123. Unified theory of timing chain/cold start/ overfill?
  124. Fan running after engine shut down
  125. Anyone using Valeo clutch & Sachs flywheel combo?
  126. 08 Base Cooper - Missing Bolt in Trans?
  127. Thread on replacing tensioner ?!?!?!!!
  128. 2013 R56 MCS - Garage Door Opener Problem - No LEDs Light Up
  129. strange sound
  130. Fan running after engine off: coincidence?
  131. White smoke/ Burning oil
  132. OEM Turbo Inlet Pipe Crack / Rip
  133. How do I remove the water tube?
  134. Automatic Headlights
  135. Changed my '13 MCS oil
  136. Loose wastegate..quick response PLEASE
  137. Si m11 01 13
  138. Do the common problems continue to re-occur??
  139. Key fob or serious issue?
  140. 09 S timing belt issue
  141. Service life, Clubman S spark plugs.
  142. Check Engine/Fan on/P0117
  143. High pressure fuel Pump help
  144. battery...
  145. Droning at 2800-3100rpm?
  146. Coolant temp too high??
  147. How do I clear check engine light?
  148. Advice before buying 2010 Cooper s
  149. Oily residue on back side of valve cover on 2009 MCS
  150. Independent Shop & Customer Supplied Parts
  151. Any chance MINI replaces my clutch for me for $0 at 52K miles?
  152. Brake duct - only one side??
  153. weird noise after tensioner replacement?
  154. 08 Base Cooper - Steam in the Oil Fill & dipstick tube after Hot
  155. 08 Base Cooper - Cruise Control Stability? Or just wind?
  156. 08 Base Cooper Cold Idle - Slight flutter
  157. Rattle coming from back hatch
  158. Driver's side door "sticking"
  159. New N18 Wastegate Rattle? (2013 CM JCW )
  160. CEL, getting P0012 code
  161. Rear Sway Bar Bracket Bolt Stripped
  162. Headlight adjusters
  163. cylinder head cover recall
  164. Engine mounts?
  165. Headlight Broken Aimed Down
  166. Limp mode/boost cuts with a variety of codes...er, help!
  167. Replace engine, or...
  168. Where is the relay for the headlights?
  169. Mold or mildew smell in defrost mode?
  170. Airbag wires
  171. Burning too much fuel and harsh sound after 3k rpm!
  172. Clock keeps resetting!
  173. Bonnet closed..Broken release..Any answers???
  174. Car having start issues
  175. 2013 Mini GP clutch issues
  176. Coolant Leak, Dealer Can't Find
  177. Reverse Transmission Issue
  178. Engine Troubles 2007 R56S Hatch
  179. Engine Seized at 76k 07 MCS
  180. Intake housing issue
  181. Boot stuck closed - how can I open it?
  182. Door Handle Button won't work for 1 remote only!
  183. Coilpack gone bad? R55 non-S
  184. where is all that oil coming from?
  185. 2F22 Engine Temperature Signal not plausible - changed sensor to no effect!
  186. 2009 Cooper S - Died without warning, please help
  187. Yellow engine light, car not communicating with cylinder 3
  188. Climate control malfunction?
  189. New engine needed @66k miles (2008 MCS)
  190. Help! Weather stripping keeps coming off!
  191. Is this normal?
  192. CEL = all four cylinders misfire - but no noticeable issues?
  193. over heating water temp too high??
  194. Oh Noes - '13 MCCS Squeal at Idle
  195. Minor oil leak at crankcase gasket. What's the cause?
  196. Exhaust Clamp Question?
  197. Rear main seal/Clutch issues
  198. Yellow Engine Light
  199. Help!!! Oil everywhere... again!!
  200. P2FD7 Fault Code
  201. P115c then p1497
  202. Coolant Leak Problem - Warranty Just Expired
  203. oil leak only on for a bit on cold engine
  204. Help with CEL codes? evaporative emission system
  205. Clubman 2008 R55 Engine Rattle (non S)
  206. Miss firing
  207. Misfire I think...help please
  208. Normal Fuel Pressure
  209. I hit the Mini issues trifecta
  210. Manual or Automatic
  211. Help my mini won't start
  212. MINI won't start.. Please help
  213. '13 MCS dirty oil at 5K
  214. At Last, Class Action N14 Timing System Lawsuit
  215. Left rear tail light error CC-ID 136
  216. Sunroof, ya, me too
  217. Sunroof, ya, me too
  218. I'm Gonna DIY my Timing Chain Repair...Need Some Advice Please
  219. Transmission replaced
  220. Standard HD Radio
  221. rattling noise from the back
  222. Transmission
  223. Gasoline Smell
  224. Help! Rear PCV hose delete problem...
  225. 3 weeks old and I have a leaking axle seal and a window issue.
  226. Display brightness problem
  227. 07 Cooper S Engine Problems - Advice Needed
  228. Tire wear!
  229. Coolant Sensor Leak: Change Housing or just the gasket
  230. Timing chain/cooling system/all other common problems
  231. Best Timing Chain Tensioner Fix
  232. 2012 R56 RPM issue
  233. AC Fan only blows on High
  234. Losing boost....help!
  235. Automatic dislikes shifting under light acceleration/heavy deceleration
  236. Reliability of the new Aisin auto for the R56 and the cost of a fluid change for it?
  237. My sunroof won't open!
  238. Stock Radio Problems/Questions
  239. Help! My 2008 R55 turbo seized
  240. BiXENON HID BALLAST KEEPS BLOWING
  241. "Yellow" Engine Light on - code definition help please.
  242. Mushy clutch?
  243. Replacing oil feed line to turbo
  244. O2 sensor fuse location?
  245. CEL = nine codes
  246. Does the Bentley repair manual cover the Cam Chain replacement for a 2007 R56?
  247. Exhaust pops gone while service due?
  248. Grinding chatter noise from front-end over rough surfaces
  249. Water pump leaks - how many miles?
  250. Oil spot and smoking
