Has anyone had a manual transmission warrantied out (2013 MCS) ?
Old Jun 21, 2013 | 05:59 PM
M'Cooper's Avatar
M'Cooper
I had my car in for a warranty fix twice now and the dealer has been great as far as service goes.
On the 2nd time I was talking over with the SA and he stated Mini may look into changing the transmission. I was not thrilled but what am I gonna do. Hoping it wasn't going to come to this, it seems it may. I go to the dealer tomorrow for an oil change and will have them look at it but idk what to do. Has anyone ever had a transmission issue like this?
Old Jun 21, 2013 | 06:12 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I have never heard of this happening before.. Does it shift fine? Any vibrations or noises? Maybe someone else will chime in here..lol
Old Jun 21, 2013 | 06:36 PM
SuperGreg's Avatar
SuperGreg
Check Lemon Law for your state and see if you have a case. Not normal.
Old Jun 22, 2013 | 09:46 AM
M'Cooper's Avatar
M'Cooper
No vibrations, or noises. Maybe a smell here or there and that when I realize its returned.
As for the Lemon Law I will have to read up on that.
Old Jun 22, 2013 | 12:24 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
This is strange I must say... I just wonder whats causing this.. Keep us posted Im am very curious what they end up doing on this.. Good luck!
Old Jun 22, 2013 | 12:40 PM
EHans's Avatar
EHans
Have they considered replacing the axle? If it is bent or has a defect, it could be wearing out the seal. Heck of a lot cheaper to fix than a tranny replacement.
Old Jun 22, 2013 | 02:35 PM
M'Cooper's Avatar
M'Cooper
The SA says its never been anything they have herd of bit they have had odd issues.
They will have to look at it good on Tuesday and figure out what to do.
Old Jun 22, 2013 | 02:42 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Hope things go well on Tuesday.. Such a nice MINI too..lol..
Old Jun 22, 2013 | 03:02 PM
minibx's Avatar
minibx
I don't think that the lemon law will apply if they change the transmission and fixes the problem IMO but read up on it. Good luck
Old Jun 22, 2013 | 03:18 PM
SuperGreg's Avatar
SuperGreg
AZ lemon law states "tried to fix 3+ times". Varies by state.
Old Jun 26, 2013 | 08:16 AM
M'Cooper's Avatar
M'Cooper
The outcome was its getting a new transmission, it's rather depressing and embarrassing.
Old Jun 26, 2013 | 08:23 AM
EHans's Avatar
EHans
Why would that be depressing or embarrassing? Not every part is perfect and once in a while, things aren't made right. It isn't like I've heard of a rash of this for a Mini. And BMW/Mini stepped up to replace.
I hope this is the end of your saga!
Old Jun 26, 2013 | 09:50 AM
M'Cooper's Avatar
M'Cooper
It's depressing because its my first new car and at 8600 miles it needs a new transmission. It's embarrassing for the same reason. I understand they are fixing it but its not like I even had the car for long so I have a right to feel that way. Ill write a saga if I want, I rarely ever complain and as said before I have a reason. I'm sure if it was your car you wouldn't proudly walk around and explain to everyone that asked about your car that's new, in the shop for the 3rd time for the same reason that now it needs a new transmission.
Old Jun 26, 2013 | 10:42 AM
Slave to Felines's Avatar
Slave to Felines
I can understand that it's depressing to be without your baby, but focus on the fact that the transmission will be brand new when you get it back! Lots of motoring to do after that!
No need to be embarrassed about it, though. You didn't assemble the transmission; you didn't make the parts; you didn't create the design. You did absolutely nothing wrong, you simply got unlucky.
Sometimes parts are bad from the beginning. That's why there are quality inspectors. Sometimes flaws that are present will escape their notice, especially if the flaw is only something that manifests after some time and use. That's why they have warranties.
This does not seem to be a common problem. If it really is one-in-a-million, it shouldn't happen to you again. (If it does, then it's probably time to Lemon Law the thing.)
No, it's not a source of pride to have the car broken so early. But you did nothing wrong--so there's nothing to be embarrassed about, IMHO.
Old Jun 26, 2013 | 11:03 AM
ra2fanatic's Avatar
ra2fanatic
If I were you, I'd file under Lemon Law, take your money and put into another '13 MCS so you have the piece of mind that this issue would not plague you down the road even though you're getting a new transmission.
Old Jun 26, 2013 | 10:40 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Sh*t happens. Sorry that it happened to you, it sounds like you got the "one in a million" bad part. Manual transmissions generally don't have a lot of problems.
For perspective, go do a search on the 2001/2002 Acura MDX transmission. Acura warranty replaced a LOT of transmissions in the 2001s and 2002s, recalled them all to install a fix, and then changed the design for 2003 and later.
I'm surprised that the latest generation of dual clutch 8 speed automatics aren't blowing up everywhere - those things are incredibly complicated. I'll take the simplicity of a manual any day.
Old Jun 27, 2013 | 04:15 AM
yetti96's Avatar
yetti96
If they replace it, no biggie. I had a buddy get a 2011 when they first same out and within 600 miles he got a new tranny because something was wrong with 4th and 5th and it whirled and had an occasional grind. Just a bad part that needed to be replaced. Not common, but occasionally parts are just made bad. Trust me, it sucks but being in a manufacturing facility I totally understand how "it just happens" (PS I work in medical manufacturing so QC is super strict and tight and we find out of spec parts at a further operation or down the line)
FrostyFox
Oct 28, 2015 02:06 PM
theblackfalcon
Oct 11, 2015 09:49 AM
phrza81
Oct 10, 2015 11:37 PM
clintmeister
Aug 12, 2015 11:11 AM
oldsbear
Eastern Iowa MINIs
Aug 9, 2015 04:02 PM
