View Full Version : Stock Problems/Issues
- Oil spot and smoking
- Cleaned my valves today...
- Rattle and DME software upgrade...
- HELP! How loose is my Cam Chain, see pic:
- It's FREEZING and my R56 is sputtering
- Oil leak and cold start issue - recalls performed
- What does the "gas cap light" look like?
- 2009 JCW Problems
- Why is this light on!
- Is the timing chain tensioner considered an internaly lubricted part?
- extended warranty ideas ?
- check engine light, C342D, C3064
- How many miles to change timing chain tensioner for N18 engine
- 2007 MCS - Won't start in the morning, takes 4-5 pushes of the button
- Cost for break in service? Oil/ Manual trans fluid change.
- Computer reading twice the actual mpgs
- Rattling air cleaner box
- PCV Mystery solved!
- Key Fob not starting car
- HELP! My R56 Cooper non-S coolant leak.
- Bluetooth, AUX, SAT Not Working
- POS French Engine- What the hey is wrong?
- Clicking sound when the engine is under a heavy load.
- Rear upper brake light bulb socket, can't remove
- Help: stalling in cold weather with multiple warning lights
- Crank case vent and oil leak
- CEL = three codes. Oxygen Sensor?
- Fault codes HELP!!
- Automatic Transmission Failures
- Stock Vband is Crap!
- Oil in the intercooler?
- Amp trouble?
- p2626 error code
- red brake and mini on lift
- Passenger Air Bag Light off
- Engine Stalling/2 Camshaft positions sensors?
- Clutch Slippage/gear box?
- A yarn about a mini cooper S R56, a timing chain, and a warning.
- Refill coolant and bleed system question
- Replaced Brake Pads at 16,700 Miles
- Full Engine Power No Longer Available - New 2013 Mini! Ugh!
- Ouch!
- In need of your opinion. Did Mini fixed my issue?
- Cold Start issue then CEL, found vac leak, fixed it. Now what?!
- Aux Input Shut Off/Bluetooth Disappears
- Should my warranty cover this?
- 2007 Mini Cooper S fault Codes
- About to leave WARRANTY; Any Advice? (2010 Club. S)
- Tires Feathering
- I really wanted to love this car...
- Phone, Ipod, and AUX not working on my R56
- Uh Oh - The Rattle Cometh?
- Transmission issues/questions 1st, clutch
- Stuck Fuel Door / Gas Cap
- Remote Control Malfunction??
- Clearcoat Problems
- R55 S running rich, bad iddle, bad fuel economy and more
- TPMS: Constant State of RESETTING
- Removing a turbo from an 07 s
- Removing a turbo on 07 s
- CEL P1497 Decreased Timing/Boost, Rough Idle On Cold Start, What Sayest Thou?
- Sensor locations
- Cc-id 167
- Please Help, CEL Codes, Limp Mode
- Vacuum Pump
- Low Coolant Temp, No Boost...
- Curing haze on inside of taillights?
- O ring in filter housing
- Driving mini when it's cold outside help with rattle
- Temperature sensor "recall" - cold start on hot day
- No compression cylinders 1, 2, AND 3 - What would cause this?
- Rally Lights
- Newly formed buzzing/whining while accelerating - 2011 JCW - video included
- Anyone chg their own timing chain
- Been to the dealership 3 times in 3 weeks still not fixed (video)
- 3 issues on 2012 MC with 7800 miles
- Water in Clubman trunk with corrosion
- DME fault codes
- I just bought a 2007 mini :( so sad
- Stereo problem--USB not responding
- 2007 R56 w/ bad oil leaks, toxic fumes in cabin, jumpy cold idle
- Weird rhythmic interior ticking sound
- Extended Maintenance Program Questions
- 09 JCW - Hub Replacement Questions
- Oil Weight
- Louder than normal fan plus light
- Dipstick Keeps Blowing Out.
- Timing chain rattle......
- Automatic Transmission Issues
- Rip in material on inside driver's door - patch or repair advice?
- Wind Noise
- rust on spark plug walls help
- 2010 MCS R56 Rear Fog Lamps
- CarbonBuildup Software Fix? (my saga)
- Air inflator/fuse watt for car
- Option code 0B42
- 2008 clubman shudders at lowish rpms
- Hiccup under modereate acceleration
- More road noise when the heat is on!??
- 09 JCW: a new mini owners string of problems
- Stuck O2 Sensor and V Clamp
- Serpentine Belt Friction Pulley/Gear Stuck
- HELP! Mini won't start after doing carbon cleaning!
- Oil Leak
- R56 Hydraulic fluid leak between motor and transmission
- Oil Leak R56
- Strange Window and Sunroof Behavior
- Help me get my boost back
- Replacement intercooler hose cold side
- Death Rattle?
- Could this be a faulty PCV - no boost above 4000rpm
- Harman Kardon buzzing speakers
- Has anyone else ever had a 2786 code? Only running ALTA CIA...
- Death Rattle -- Im a bit confused...
- Oil Leak - Turbo Line and Heat Exchanger?
- Hot Side Boost Tube Popping Off - Noisemaker
- No Hazards & Fast Blinkers & Exterior Bulb Warning
- Air humming sound in R56 JCW
- Battery discharge after Alta Cai Install
- Stalling issue
- HELP! Car Apart cant find Oil Leak
- Oil filter cap on N18 engine
- Intake valve fouling on DI engines: Next gen Corvette solutions
- Water leak issues
- Engine Longevity
- Self-Funded Maintainence
- Rattling sunroof shade
- Misfires & Ignition Coils
- Need to replace Turbo and warranty won't cover it, need advice!
- something to worry about?
- Intake hose wont stay attatched ti turbo
- 2009 MC, Approaching 50k miles, what should I ask the dealer to check?
- Rattling in engine?
- Odd shifting balance in the car
- HELP! Broken Coolant Plastic Pipe
- Suspension Creak/Groan
- 2013 MCS Noisy Engine at Idle
- '12MCS coolant / cold start issues
- Rattle - Front Wheel Area
- Help with locating oil leak around Turbo & other...
- You guys will never figure out this one!
- Damaged Turbo Flange
- Have You Had Your Clutch Replaced?
- No grunt on the down low
- high pitch whine sound
- Bentley Manual worth it?
- Was I smart to get the Mini extended warranty \ maintenance?
- Yellow CEL
- A dreaded squeak!!!
- Help With Fault Code
- Excessive Crankcase Vacuum
- mini tech needs helo from other mini techs
- BMW _ MINI Class Action Lawsuit Timing Chain Issues
- 2009 Clubman Sunroof Problem - It takes 7 steps for full deployment
- Joyriding mouse or wheel problem?
- $2,600 Clutch! Fed Up
- Auto Level Headlights
- leaky thermostat
- 10k miles, one dead clutch. HELP.
- Big question
- Arm Rest Issue
- Suspension rattling
- Standard Warranty Length?
- Exhaust leakage issue?
- Push Start W/ Comfort Access Error
- Newby with aux water pump question.
- 2013 Justa whistling sound when idling.
- Need Help
- New recall for the Engine coolant temperature sensor?
- Question about timing chain
- Transmission & Engine Fail
- I am stupid.
- Rattle in the rear at higher speeds
- Key fob error
- Boost leak
- Engine Turns off while coasting
- '07 S Engine Wobble Sound
- confusing overheating problem
- Extended Warranty - Anyone use these companies?
- 2007 Mini Cooper Stalling
- Turbo Intake Pipe broken - need advice
- diesel rattle but not from cold start
- clunking problem when accelerating.
- Clutch Replaced this Week
- Stuck Parking Light - Won't shut off
- P1497
- Enthusiasts Wanted
- Is Mobil 1 extended Life ok for the 2012 MCa?
- Loaner car: MCSa impressions
- P2885 Saga and Conclusion
- Getrag 6-speed? Clutch? Input shaft? Confusing issues
- Alignment Marks?
- CEL, limp mode, no codes?
- Highway Speed Vibration - Stock Suspension
- Buzzing/whirring/whine/moo when powering off
- Range = 0, fuel tank full > gauge problem
- Leak in oil supply line to turbo
- 6yr Maint Items on R56 2007 MCS
- 2010 Premature Clutch Wear
- comfort access key fob problem
- popping/clunk noise
- Re-attaching your spare tire
- 2007 Mini - Rough Idle
- New engine JCW
- 101 Gremlins
- Bavarian Technic First Scan: Cylinder 3 Coil and VANOS Actuator Movement
- Help with Replacing Turbo coolant supply hose
- I hate the stock jack!
- Coolant Resovior leak
- High Pitched noise, no power 2 codes
- Dealers overfilling oil
- Pressure Values
- BSH oil catch does not work
- Open Campaign - Coolant Temp Sensor (9/6/2012)
- Justa starts rough
- CEL after my first oil change?
- Looking for picutres of wiring harness near the transmission r56 MCSa
- Exhaust Bang Bang & missfires
- 2009 S: High Pressure Fuel Pump Replaced Today
- engine lugging in tight turns
- Side marker light wiring harness repair?
- Rough idle/stumble from cold start
- Sun Damage Windshield Cowl
- Another P0303
- California Dealership Recommendations
- Coolant Temperature Sensor
- Latest Tensioner Info
- Engine won't start
- Rough Idle, Black Plugs, Misfires, Backfiring, Sputtering
- Oil residue on top of valve cover
- Thump coming from speakers
- Brakes Grinding?
- Oily residue on back window, head gasket?
- HELP!...Turbo Oil Feed line is leaking!
- SRS seat mat sensor/lumpy upholstery
- Took my 08 mini into dealer and 20 miles later it is worse... Long rant
- Fuel pressure riddle!
- turbo intake pipe
- Loss of power?
- PCV Hose Removal Possible?
- Transaxel
- Oil Change
- Leaking Heated Windshield Washer Nozzles
- strage and interesting issue R56S
- Timing Chain Issue: Both S and Basic Affected or Just S?
- wastegate vacuum issues
- carb issue w/ 09 MCSa
- Error codes for Misfire/oxygen sensor
