Oil Leak - Turbo Line and Heat Exchanger?
Hello all.
I recently performed and oil change on my 09 JCW and noticed it was leaking a bit of oil, not enough to cause concern but enough to clean it up to see where it was coming from. It seems that the oil feed line on top the turbo is leaking which I have researched and it seems to be common. So I am ordering the Detroit Tuned oil line kit. Is there any other hoses/pipes/gaskets/washers that I should replace while I have everything off? I know I am taking the time to wrap the DP so I dont have to keep with the shield.
I also noticed a slight leak around what REALOEM calls the Heat Exchanger. Are those seals known to go bad as well as I have not come across any threads/posts regarding this.
Any insight would be appreciated! Pics posted below to show what Im referring to.
I had to get the heat exchanger on my 2008 MCS replaced right at 50,000 miles. I think I could count on one hand the number of other posters I've seen that have had their heat exchanger replaced. imo, it is one of the more rare parts to fail.
If you are going to be in there doing that work, might want to consider also replacing the oil return line (parts 10/11/12 on the diagram). I did it on DT's recommendation.
My car has 75K on it and I just did the following. My turbo line and the leaky oil pan were the initial cause of the repair and I figured since the current mileage it couldn't hurt to do it all.
- Turbo feed line (replaced with Detroit Tune version)
- Turbo return line
- Exhaust Manifold Gasket
- Downpipe to Turbo gasket
- New studs/nuts for manifold and turbo
- Oil Pan Gasket
- Vaccuum Hoses
- Heat Exchanger seals/gaskets
Total project was about $400 (ordered through Sewell Parts) and a couple of weekends. I didn't initially do the heat exchanger seals/gaskets and I discovered they were leaking too only after I put it all back together, so I had to go back last weekend and do those. If you do the oil pan, get the fel-pro actual gasket. Mini offers a Gasket In A Tube for the oil pan and mine is still leaking a little, so I will be going back and putting a real gasket in.
For everything I had to do, I know this repair would have been over $2K at a dealer, and it was really easy. A regular socket set, some wrenches and a screwdriver or two was all I needed.
Do yourself a favor and drain the oil and coolant before you start. Will save you a lot of time cleaning up a mess. haha
- Turbo return line
- Oil Pan Gasket
- Vaccuum Hoses
- Turbo return line
- Oil Pan Gasket
- Vaccuum Hoses
- Turbo return line
- Oil Pan Gasket
- Vaccuum Hoses
Yep this is what Im doing!
Ordered:
Heath Exchanger Gaskets
Detroit Tuning Oil Line
Mini Oil Return Line Kit
BSHR Boost Tap
I didnt see my oil pan leaking, I have roughly 45K miles. But I have ordered exhaust wrap as well so that I dont need to throw the heat shield back on.
The oil pan seems to have a gasket from the pictures Im looking at? Or do they show them with gaskets but in reality you have to use Fuji Bond?
Ordered:
BSHR Boost Tap
Ordered:
BSHR Boost Tap
Anyone have any experience doing that as a way to eliminate the heat shields? Any pluses or minuses? Seems like it would make things a whole lot easier than dealing with the stock heat shields.
I bought a basic from summit racing. ive had the same idea of getting rid of all the heat shields. im going to ceramic coat and wrap everything.
Ceramic coat would be nice to have. I can tell you putting the heat shields back in was a hassle. I spent more time messing with the heat shields than I did with the actual repair. www.jet-hot.com.
Would be interesting to see how effective it would be.
Powershift
Aug 16, 2015 05:14 PM
