R50/53 Abs light issue
Old Mar 29, 2026 | 05:25 AM
Min64's Avatar
Min64
Abs light issue
Has anyone any advice re my 2003 R50 . I have both ABS & Tyre pressure lights intermittently coming on when starting so far I’ve had New ABS pump all correctly coded , new battery , all wiring loom rewired by ABS pump all voltage tested on all the wires up to and from ABS pump and all ok plus new wheel speed sensor and the lights are still coming on so I don’t know if it’s wires further down on the dash or an electrical glitch somewhere . Does anyone have any suggestions?
Old Yesterday | 08:17 PM
noodlesandsam's Avatar
noodlesandsam
You need to read the codes. I got a foxwell 510 ( back in 2021 ). OBD readers won’t give you these errors. Mine was the left front bearing @ 149k. He was going bad, and ruined the wheel speed sensor. I replaced both, and all has been good. A good reader will tell you what the problem is.
Old Yesterday | 11:11 PM
Min64's Avatar
Min64
it’s had new wheel speed sensor replaced plus new wheel bearing first it was reading passenger side wheel speed sensor so it was replaced plus new wheel bearing .. then lights on again code saying ABS under 9v all of that has been replaced ABS , wiring loom , fuses checked , new battery , another front wheel speed sensor , ABS & tyre pressure light reappeared after a day or two code read was ABS under 9v
Old Today | 07:42 AM
cooper48's Avatar
cooper48
Try swapping the wheel sensors (left to right and vice versa) and see if the problem moves. You wouldn't be the only person to install a new (but damaged) wheel sensor.
Old Today | 10:21 AM
LukasH's Avatar
LukasH
That or use your code scanner to read out live data on each individual wheel speed. The one thats odd is your issue.
I found that either the quality of parts is going down or Minis are a bit specific about the resistance in the wheel speed sensors. I bought one new and couldn't get it to work. Tried another brand and it was fine. Also check if the pins on the plug are not corroded (increases resistance)
Old Today | 03:36 PM
ssoliman's Avatar
ssoliman
+1 what brand of sensors did you install? OE?
celticfc
Aug 20, 2015 01:54 PM
Silverbullit
May 23, 2014 03:31 PM
mellowfe
Mar 1, 2010 05:28 PM
jmainella26
Dec 11, 2009 06:20 PM
donuttang
Electrical
Aug 28, 2008 09:27 PM
