R50/53 Intermittent No-Crank on 2002 MINI Cooper S (R53) – Now “Working Again” with No Fix
Looking for some insight on an intermittent no-start issue that has me questioning whether this car is trustworthy for longer trips.
Background
Car is a 2002 MINI Cooper S (manual). No prior starting issues. About 70k, I'm the second owner. I bought it two years ago after it had been sitting for three years. I've put 10k miles on it.Initial Failure
A few nights ago:- Turned the key → engine cranked briefly (maybe 1 second) and stopped
- Second attempt → nothing at all
- Third attempt → started normally and got me home
Current Symptoms (When Failing)
The next day:- Battery shows ~12V
- All accessories power up normally (dash, lights, etc.)
- Turning key to “start” → absolutely nothing
- No crank
- No click
- No relay noise
- It genuinely feels like the car doesn’t recognize the key being turned to start
Suggestions Received
From others, the main ideas were:- Battery / dead cell / voltage drop under load
- Ground strap or cable issue
- Clutch safety switch (manual)
- Starter solenoid
- Ignition switch failure
- Neutral safety / interlock logic
What I Checked / Tried
- Battery is only a couple years old
- Connected a fully charged jump pack → no change
- Cleaned ignition switch contacts → already clean, no improvement
- Pulled codes → nothing relevant to starting
- Removal and checks of battery connections
- Visual inspection of the clutch pedal switch
Current Status (The Weird Part)
I went back out to begin proper troubleshooting (checking for voltage at the starter trigger wire)... …and the car started normally. No changes. No repairs. No adjustments.New Observation
I did notice something interesting: If I turn the key to “start” and then stab the clutch, there’s sometimes a slight delay before it cranks. That made me wonder: Is that normal behavior, or does it point toward a failing clutch switch / interlock?Where I’m At
Right now I’ve got:- A no-start that lasted for two days
- No crank, no click when it happens
- A car that is now working normally
- No clear trigger or fix
What I’m Looking For
Before I start throwing parts at it, I’m hoping for insight from people familiar with R53s. Does this pattern point strongly to:- Ignition switch (start circuit)?
- Clutch safety switch?
- Starter solenoid/control circuit?
- Is the “no click at all” a key diagnostic clue here?
- Does the clutch interaction/delay suggest anything definitive?
- Any known MINI-specific failure points that match this behavior?
usafdrew
Nov 30, 2023 10:13 AM
AvianMan
17
May 17, 2019 07:25 PM
Al T
Feb 15, 2014 11:23 AM
