View Full Version : Stock Problems/Issues
- 2013 Mini Cooper Coupe Noise
- Faint Ticking Noise Only on Light Acceleration/Gas
- No Power On Very Cold Start....
- Mini cooper (non S) CEL: P2187, is there an easy fix?
- Fuel Gauge 4 bars out of gas
- Cold Weather long cranking, hard starting
- Car on yellow lift for no reason ?
- 2009 Clubman base serious idle issue
- Speedo inaccuracy
- Engine rattle base 2009
- How to disable sunroof
- Fuse for power outlets?
- 2007 MCS Non-Return valve any ideas?
- Odd looking wire tap in foot well fuse area, also best fuse to tap always on/hot.
- Help with oil leak near oil filter
- Fuel System Monitor Bank 1 fail
- Strong vibration/harmonic humming from driver side wheel?
- Knocking noise heard from above cylinder head?
- I Need My Horn To Sound When I Lock
- Transmission fluid flush?
- Heater is not hot.
- R57 Auto Tranny Fluid Change Problems
- P1637 and P2103
- Extended warranty... What did you buy?
- Is Oil filter housing related to the turbo line
- Auto door lock feature
- Noise when cornering
- R56 BC1 location
- Engine randomly dies
- Lost interior and guage lights.
- Troubleshooting possible turbo failure.
- Exhaust Valve Carbon Build Up
- No sound from driver side door after replacing door shell
- Hard starting on '09 Base after sitting
- Auto-Up window issue
- Checking for Boost Leak
- Strange blow off valve noise
- Hard to start in the cold, suddenly
- Keyfob buttons falling out
- Need some guidance and tips
- Valve timing
- Water Pump Pulley
- Running Rich? (PID Snapshot)
- cold start on a 2008 cooper s
- R55 N12 Clubman - various leaks, and common suspects?
- Just got my Mini to the dealership......it isn't good
- Is ANY rattle normal on cold start? 2011 Justa Clubman
- External Light Warning - All lights work...
- Blower motor for ac/heat not working
- N14/N18 Carbon Buildup TESTER NEEDED
- Oil leak in 2009 mini
- Not boosting properly 😔
- 2008 mcs death rattle/timing chain replacement
- Urgent help me, my car wont start
- Oil On Top of Valve Cover
- hood release issue
- 2012 S Towed To Dealer
- Interesting ignition issue
- Aisin Automatic Transmission Noise
- What am I looking at? (loose cable near rear view mirror)
- Is this sound the "Death Rattle"?
- Strange Front Motor Mount
- RPM flat spots and feels slightly under-powered.
- BMW dealer / MINI codes?
- Braking/chassis stabilization malfunction
- Brake Pedal "clap"
- Alternator whine on stock Harmom Kardon system?
- Mini coolant
- Looking for Advice for MCS in Canada -cold start issues
- My mini went tick tick boom
- Electrical Problems
- Aisin Automatic Transmission Problem: Valve Body
- DIY Blower Motor?
- Halogen headlight bulbs replacement................
- Radiator fan starting even when engine cold
- R56 , the ultimate mystery jerking
- Reset TPMS....CEL briefly came on. Why?
- 2008 Justa fuel cap door?
- BRAKE replacement on 2011 MCS, sensor question
- BG's Engine Performance Restoration Results!
- N18 Boost Problem
- Turbo advice
- Which is Relay K19
- Dealership Etiquette, Oil Leak, Vacuum Pump, and Battery Questions
- Issue with high pressure pump and oil pump solenoid leaking
- Bavarian Techinic and Fuel rail pressure?
- Petrol Tank popping and fuel gauge all over the place
- 2009 MCS Clutch Issues / Replacement?
- Tools required for r56 (n12) inlet camshaft and valve removal
- a question for the ones that replaced the HPFP
- 2007 R56 Mini possible death rattle
- Need help identifying and finding/fixing plastic piece inside headlight
- Sudden Clutch failure
- Error messages after a brake job
- Rear wiper arm removal-how to?
- 2011 Justa rattle
- #$%!?? torx rotor retention bolt
- Need Advice. Misfire cyl 1 and 3, completely dead cylinders.
- Squeaky rear shock
- Clutch problems
- Air conditioning doesn't work anymore
- R56 2007 S camshaft removal
- quick ? about tpms...and changing tires
- Anyone have issues with unsteady cold start idle?
- R56 Thermostat replacement different cable socket?
- Passenger airbag fault
- 09 MCS P0300 and P0304 codes, help
- I hate my '11 MCS suspension during COLD WEATHER!
- Water Temp Over 250
- p2414 and p2626 codes o2 sensor
- Mystery squeak is scraping my brain - help!?
- To Hibernate or Not??
- DSC Issues
- Intermittent Third Brake Light
- Help, car won't start after walnut blasting!
- Help - Coolant leak at two places
- Looking to buy an 07 base
- LIGHTS, IDIOT LIGHTS - Any one?
- 08 MCS N14 - Remove only Engine ?
- 2009 Clubman S, Need Advice On Numerous Problems. (Timing Chain, Turbo-line..)
- Water dripping from rear view mirror???
- Black Trim Popping out!
- Grump! Oil solenoid leaking--again!
- R56 Carbon buildup- permanent fix?
- HPFP- early failure warning signs?
- Need help finding part
- Overheating. Fuse for fan?
- R56 Exhaust - Downpipe Back Failure
- misfire codes after parked for a few days.
- Comfort Access Won't Work (first post)
- Timing chain tensioner came apart
- P0055 code states sensor 3
- New Smoke from Exhaust?
- Timing help
- Greenish fluid leak?
- Oil Leak? Help?
- 2008 R56 automatic transmission problem
- R55 2010 Clubman S P0012 Camshaft Position/TIming Issue
- oil pump drive chain slack
- leaking overflow coolent tank 2003 S
- Engine cranks but won't start
- Mini won't start, redux
- 2013 R56 weird cold start RPM fluctuations
- Windshield washer hose broke
- Inside the R56 thermostat
- TPMS receiver locations
- 2007 mini copper s cold start running rough at low rpm
- Throttle Body Half Power PLEASE HELP
- po300, po301, po304
- Help 09 MCS No start after walnut shell blasting and BSH vapor can install
- Steering twitch while parked
- Help with sensors: car cranks but doesn't fire
- Help Request: R55 Clubman, Dome, Footwell, Puddle Lights not working
- in tank fuel pump
- Buzzing/Rattle noise under deceleration
- R56 - Cold Start Issue - HPFP or Carbon Buildup? Codes from scanner
- No AC... Fan seems to work, but does not come on when AC does
- Rear hatch button disintegration
- Yellow Brake light, "Start-off Assistance Inactive", DSC working
- engine oil cap probleme
- N18 Camshaft Problem? Code P1339
- Is my MAP sensor shorted?
- loss of boost after oil feed line replacement...
- Engine misfire with code p0302, engine oil found in the #2 spark plug socket
- Only 1150 miles and P12A9 code :(
- 2009 vents that move on there own
- 2011 MCS red warning lights: service lift car with break
- The windshield cowl...
- 2008 R56 MCS Repair: Next Steps?
- HELP! 2011 R56 won't turn over!
- new HPFP yet no fuel to the rail?
- p0977 shift solenoid B Control circuit high
- Are AC leaks common? Bad condenser?
- loss of boost
- Code 2885
- A/C recirc button shuts off in auto mode
- Rattle's all over the interior!
- Rough idle on first start of day
- How to remove rear view mirror?
- End of Warranty is Coming Up
- Pressure blaster for carbon removal?
- Chain noise and super-knock around 3k rpm
- dtml pump wiring
- Multiple Issues 09 Cooper S
- Coolant Temperature and Fluctuations
- strange radio and now car issues!
- Readiness monitors clearing on shutdown
- Mutiple problems dont know where to start
- Service Bulletin Roadster Top
- loud rattle and hitching when turbo engages
- Rear fog failure indication
- valve cover removal
- A/C problem
- On a hot day engine will not start properly
- Engine Spins...Won't Fire
- R55 Clubman JCW - how do I get the rear bumper cover off?
- Cold Start with A/C off car sounds like it will stall
- Coolant Bleeder Screw Location on Base Motor?
- Part ID help
- Can you identify this connector?
- Chatter noise when key is inserted
- Observations when replacing the serpentine belt
- P0128 Code Comes Back After Replaced Thermo Housing
- Overheating, disappearing coolant
- Codes P0118 and P1638
- Second Walnut blasting today
- Airbag/Seatbelt Warning - No codes?
- N14 Oil Leak, Please Help!
- Code P1777; abs yellow icon appears and CEL
- MINI not covering battery under warranty
- gp2 metal on metal sound (ringing)
- Camshaft Sensor: Car only runs good without it
- scratching head. "sudden loss of power and oil smell."
- Suspected oil pump solenoid leak - confirm?
- CEL Under Full Throttle
- High temperature on a cold start
- doesnt want to warm up
- 2012 MCS: CEL can't be reset by the usual tools?
- Walnut shell blasting today
- R56 Sun Roof
- Aligning head lamp assy to hood
- Carbon Buildup 08 58k miles
- Is this pipe important?
- Help with OBDII codes after a short circuit
- Helps determine BTDC
- p0015 code on 08 mini cooper base
- Intermittent Loss of Power
- horn will not shut off R58
- leaking turbo oil line
- Brake warping problems. Need regional contact info.
- reviewing the service warning
- Base 2007 MC misfires
- '12 JCW turbo lag
- R56 Turbo rear hatch release
- Gear linkage clanking?
- Rough idle in traffic
- Timing Chain DIY Questions for r55/r56 N14
- 2007 Base R56 MC misfire diagnostics?
- Diy hpfp
- upgrade spedo to stock navi
- Exhaust Moisture - Normal?
- 2b5b
- Centering Ring/Hub Issue
- no indicators no headlamps....2007 R56 justa
- Whats Wrong?
- 2007 R56 Bluetooth can't pairing
- Suspension Help
- '07 clutch not engaging
- Intake tube popping off turbo, any suggestions or similar stories?Help Needed!Thanks!
- Yet another Carbon cleaning report...
