View Full Version : Stock Problems/Issues
- Dead on the offramp
- Passenger door area rattle
- Found a part on RealOEM, how do I get it?
- 2010 MCS Poor Seat Build
- crevier loaner...
- 2010 Clubby S died
- Misfires High Pressure Fuel Pump
- 2009 ECU Reset?
- Weird Pedal
- Bzzzzzz....
- Engine Knocking!? HELP***
- Water drip from small black oval tube?
- What is this stuff on my engine?
- CC ID 036
- Hand On Shifter?
- Auto tranny "problem"???
- Trimmed In Clutch
- What is this loose hose hanging here? (pics)
- Unable to reset service alert for rear brakes
- Axle leak?
- boot latch clack
- JCW cutting power during overboost
- Cruise control subtle surging
- DSC and Brake Light acting weird - 2010 MCS
- Tire Pressure Sensor Reset
- Low oil pressure warning when taking a hard corner?
- Help... this is not cold start chatter anymore!!!
- Clutch and flywheel replacement
- CEL: "increased emissions" = fuel pump
- Dirty Fuel Filter = CEL
- New hub
- Transmission
- 09 Water Pump Failure - Damage
- another one bites the dust....
- Colder Weather = Reduced Boost Pressure
- Paint Issues (Dark Silver)?
- Torque Values Mistaken in Manual?
- Warranty and Expected Life
- New lifters ,and maybe a head!!!
- Wheel arch snaps broke. Needs help.
- Passenger airbag off Over rearview mirror
- Wiggle While Driving, Tread Squirm?
- German Engineering = Way Too Complicated?
- Auto Transmission surges...
- Mini Wheel and Tire Warranty
- Windows go down by themeselves
- Occasional loss of power
- Key Fob/Dead Car
- rear view mirror help
- Help again please.... CEL
- Torque Steer mostly resolved
- Comfort Access issue ...
- Proud owner of new 09 Clubman S.... sort of...
- Rear sunroof squeaky rattle
- Remote lock/unlock won't work
- High pitched squealing sound from water pump area
- Headlight Surround's Bubbling
- Power steering problem on 2nd generation
- R56 Wiper Blades
- Brake loss after sitting.
- Sunroof Glass Shattered
- CEL.. Help please. Philippines no dealership....
- Helpppp!!!! Engine light?
- OEM Chrome Scoop issue
- A screw/fastener sticking (picture)
- MINI Strict service
- Windshield Damage
- ACC - Automatic Climate Control
- Effectiveness of Clear Bra?
- Battery issues
- Intake Valve Deposits
- Front brakes gone in the first 19 000 km
- 5th visit to the dealer in 3 1/2 months: should I just sell my car?
- Broken Vanity Mirror
- Someone stole my emblem
- Check engine light issue
- Engine Hot, Then Overheating! Help!
- Bad news: Apparently, 2010s also suffer from cold start rattle
- Car never starts the first time around... Why could it be?
- Early Build 07 MCS's
- Car wont shift into 3rd gear!!! Help!!
- HELP would be the best thing right now...
- Headlight connector help please!
- First the Window, Now the Head Lights
- Won't start, gas pedal stopped working while driving
- Gave a jump to another car and now mine will not start
- FOB startup TROUBLEEE
- 2nd gear syncro warranty question
- Squeak when coming to full stop / new wheels put on yesterday
- Airbag/Seatbelt lights on after Heated Seat Install
- Ran out of gas...again
- Driver's wing mirror on R57
- *POP* then squealing...
- 2009 Cooper S Automatic Transmission Problems
- Found this screw on the passenger floor
- Shifter very tight
- How have you been treated by your BMW dealership?
- R56 Turbo blown.
- Blue fluid leaking INSIDE my mini by the driver side
- Intake/Engine Whistle on non-S Clubman
- Tach Rattling
- Burnt clutch on 2008 after 14,500 miles?
- More than just the hood scoop melted during test drive [video]
- Turbo Rust?
- Can some one take a photo of the engine bay...
- dropped brake reservoir cap, help!
- Rough solutions? - Codes: 016,012,011,017
- Dreaed Red Battery Light
- High RPM Engine 'Buzz'
- Fuel gauge accuracy
- Water in door on kick plate
- Power Loss plus CEL @ 650 miles!
- air conditioning
- Replacing headlight glass
- Can't fix window issue due to non-factory amp installed
- Mis-Matched Paint on 2009 Cooper - Accident Damage or Shoddy Workmanship?
- 09 Issues?
- Washer Fluid Light Staying on post re-fill
- "Lifter knock noise" after hard track driving?
- upper wishbone nuts fell off!!
- Can't read oil
- Is something disengaging?
- Door sill indentations?
- Installed new High press.fuel pump
- Random light bulb icon?
- Carbon Deposits on Direct Injection Engines
- A/C issue (bad smell)
- passenger side window problems
- Coil removal to get to spark plugs...
- Carbon Build-Up/Stains Under Bonnet
- Weird Hatch Noise
- Extended Warranty From Mercury Insurance
- How can I identify a cold start problem?
- Garage door opener problems
- bad to turn a/c off, then on?
- High Pressure Fuel pump
- Engine Start Problems
- Programming the R56 with minitechinfo site and a J2534 tool
- Folding Mirror Issue?
- Problem with my R56, DSC kicking in early and often, car out of control without DSC?
- R56 DIY Air Filter Replace for Newbies
- Key fob ('08 Clubman)went through laundry
- Rear wheel negative camber
- Resetting the Tire Pressure Alert
- Water in spare tire well
- Metalic Clicking while turning
- Buzzing/vibration from tach
- Replacement key
- Richmond VA - Crown Mini - Cold Start Rattle
- Burned clutch after one year???
- Chime won't stop
- Unpaired Comfort Access Key
- warped rear bumper
- Moonroof Sticking/Cold Start Fixed - Long!
- If you want a headache free car, MINI is def not for you
- My car has a evil demon inside
- Power steering
- High Pressure Fuel Pump Replacement
- True cost of "free" maintenance
- Air Conditioning
- MINI Cooper S just stopped while driving
- Interesting trip to the dealer today. (long)
- Buzzing around 80mph
- What's up with my car?
- Squeaky brakes...
- New JD Survey...
- Stock continental tires?
- Found a puddle of clear sticky liquid under the car?
- Latest round of problems...
- Throttle hesitation
- Really difficult to shift
- 3 days of Mini ownership... HUGE rattle in the dash!
- Coolant Disappearing???
- ABS - DSC - (!) lights on randomly
- 2007 catalytic converter
- What's your MCS idle? (M6)
- Side Marker/Scuttle
- Missfire cylinder #4
- yellow engine light/rough
- Window dipper fix = breaking the bluetooth?
- Air Conditioning issues... anyone else?
- Driver's side window problem
- Torque values
- Engine light... loss of power... exhaust system issue?
- Oil Smell at Startup
- Help on tire bolts... torque wrench setting...
- Extreme Clutch Issues
- Turbo got louder after 2K miles
- Suspected misfire on WOT!
- MCS High Fuel Pressure Issues
- Radio Preset glitch
- Fastners for Nose Mask Needed
- Key fob working intermittently
- Creaking sound when turning steering wheel
- What is with the brake pads on my r55 clubman
- Snapping noise and hesitation
- Driver's Side Window Rattle
- Stalling out at start
- Dead Battery? Issue
- 09 JCW CEL
- Service reset
- Is 220 degree water temp typical for 2007 MCS?
- Long Beach MINI says cold start chatter is not true
- All Electronics Shut Down While On The Freeway
- Oil filter - Anyone seen this
- How to remove side sills.
- Exhaust Campaign on 07 MC
- Clubman S non-HIFI Audio Problems
- Leaky windows, bad trunk latch...
- Rotational vibration while accelerating in high gears?
- Clicking noise when depressing/releasing clutch after a drive.
- some oily liquid dripping down my bumper!
- Tear in vinyl on door, looking for advice please
- Accurate Info Regarding Ethanol
- Stupid question time--oil changes
- JD Power survey
- Just got my MINI and this sub-forum has me "Driving Miss Daisy"!
- A challenge for the Varsity Players
- Help with Torque Steer
- Need help engine code P2270
- Another front end CLUNK issue along with bad handling...
- Can`t fill up gas properly
- 2007 MCS with dead engine :(
- Xenon Replacement Bulb/Running Lamps
- Cold Start with a 2009 Build Date
- help! diagnose this sound!
- Fuel pump replacement isn't covered under warranty because of "bad gas"?
- 2009 scoop melting???
- 07 MCS engine failure
- Check when engine is at Idel. Almost stalls out.
- Trunk and Reading Lights inop
- Starter Doesn't Turn Engine Over,Only Solitary Click
- Chirp in suspension?
- Yikes ... that sinking brake pedal feeling, at the track.
- Idle Surge
- Mini engineers are so fn stupid they cant fix a sunroof!!!!!!!!!!!!
- Cold Manual Transmission shifting problems???
- Passenger side A-pillar squeak
- R56: hub replacement questions
- Grrr...
- Rust spots on exterior chrome
- Brakes
- Turn signal stuck on!
- Watch out for leaky TPMS sensors.
- Car self-steers left - but wheels are aligned!
- Hazard lights turn on/off on their own
- '08 MCS - Are excessive repairs part of the normal owner experience?
- Turbo heat solution?
- Picky TPMS
- 2007 makes strange noise after shut off
