Low oil pressure warning when taking a hard corner?
Old Oct 22, 2009 | 08:04 PM
leonbev's Avatar
leonbev
I have a 07 MC with about 40,000 miles on it, where the low oil pressure light comes on when I take a hard right turn. I mean a HARD right turn, where the tires are squealing and you feel like you're driving sideways! The light only stays on for about 3 seconds before it goes off.
Otherwise, the car behaves normally. It never shows a low oil pressure light at any other time, and the oil levels look fine.
Has anyone else seen an issue like this one? The light is a bit concerning, even though I've only seen it happen a few times while I'm driving like a crazy guy.
Old Oct 22, 2009 | 08:17 PM
Robin Casady's Avatar
Robin Casady
You are sure its oil, and not the DSC light?
Oh, and what are you doing looking at the dash when you are driving sideways?
Old Oct 22, 2009 | 08:21 PM
nickminir56's Avatar
nickminir56
1.0+ g?
Old Oct 22, 2009 | 08:46 PM
remip50's Avatar
remip50
I had this problem with my 08 and it was because there was not enough oil in the car.
Old Oct 22, 2009 | 08:55 PM
Oxybluecoop's Avatar
Oxybluecoop
That light only comes on when oil pressure is critically low.Your probably about two quarts down. I'd check your dipstick again. After a track weekend I had that light come on traveling home.It's amazing how much oil passes through the pcv on these engines at high rpms.
Old Oct 22, 2009 | 10:17 PM
thevelourfog's Avatar
thevelourfog
Does the oil pan have any baffles in it stock? I'm guessing not.
Old Oct 22, 2009 | 10:35 PM
Dr Obnxs's Avatar
Dr Obnxs
Nope.
it's oil starvation from being low and staying at a high lateral G. Get in touch with Revolution Mini Works (vendor here) and they have a baffled pick up. Even with good oil levels long sweepers can do this on the track.
Matt
Old Oct 22, 2009 | 10:53 PM
thevelourfog
So it's not baffled. +1 on oil starvation. I wouldn't worry about it too much for occasional hard street driving and good oil levels.
Old Oct 23, 2009 | 05:05 AM
slinger688's Avatar
slinger688
Yes, the Mini is a wet sump with no baffle. I always keep an eye on this on the track.
Does RMW have a baffle kit for a R56? Has anyone used one?
Old Oct 23, 2009 | 09:03 AM
countryboyshane's Avatar
countryboyshane
+1 on the baffled pickup, but still I've never heard of the R56 having this issue unless you are very low on oil, but you should be checking that regularly.
Old Oct 23, 2009 | 09:42 AM
CFMINI's Avatar
CFMINI
AFAIK, the RMW baffled pickup is only for the R53 and not yet for the R56, but as always, call Jan to confirm.
Old Oct 23, 2009 | 09:50 AM
Dr Obnxs's Avatar
Dr Obnxs
Damn!
I've got to stop forgetting to look at what forum this stuff is posted in.
Sorry for any confusion.
Matt
Old Oct 23, 2009 | 10:22 AM
Porthos's Avatar
Porthos
+1 You need to change your oil and watch it close cause you might be have oil consumption issues. I had a Sonoma that did the same thing.
Old Oct 31, 2009 | 10:17 PM
ellinara's Avatar
ellinara
I had this light come on to... As soon as it did I stopped driving it and took it straight to the dealer. They topped up the oil and that was it. I felt like such an idiot but then again it's my first car so i don't know...
Old Sep 22, 2012 | 04:29 PM
Valerie Poulter Stone's Avatar
Mine did the same thing when I'm about 5 K out from an oil change - associated with a bit rougher sound to the engine too. Topped up with a quart and both resolved,, for a while. Just had the valve cover gasket replaced, hope that will fix it properly.
Old Sep 22, 2012 | 06:00 PM
slinger688's Avatar
slinger688
Mini does not have baffles in the oil pan so this is likely to happen especially if you are low in oil. At the track, we put 1/4 quart more oil after the full mark to compensate for this.
Old Sep 23, 2012 | 03:05 AM
KeepItLow's Avatar
KeepItLow
Happened to me once doing a hard right turn, the check engine oil light came on for a few seconds. Took it to dealer the next day, they advise the engine burns a bit of oil throughout time so they just top it up and that's it. I've done about 8000km since last service, so a tiny oil burn is not that big of a issue for me. I had a Honda EP3R that burns like 1L engine oil every 3500km..
Old May 17, 2017 | 07:37 PM
sanksalot's Avatar
sanksalot
check engine oil warning came on and I took it to mini dealer. They said they topped it up, but the warning continues to appear during somewhat sharp turns. I find the dipstick hard to read, maybe because the oil is not registering on it(low)? So maybe they didn't top it or maybe I can't read the dipstick or could it be burning(no smoke)or leaking(no spotting)so much that the oil level is already low the next day? Anyone have problems with the oil pressure sensor? 2012 base countryman
Old Jul 30, 2023 | 06:09 PM
DerricBrown2023's Avatar
DerricBrown2023
yes I have experience this what causes that????
Old Jul 31, 2023 | 01:34 PM
You have to keep the oil level up, cars that burn oil a lot tend to run lower oil level and with a hard turn it staves the engine enough to get the low pressure lights. Seen cars below LOW and that happens.
Check your dipstick and add oil if needed. I run mine towards the top of mark near high, not in the middle area. If you have the old wire design get the newer stick
https://www.northamericanmotoring.co...-dipstick.html
Old 2007 wire design that's discontinued
DantheSaint
R59 :: Roadster Talk (2012+)
12
Apr 5, 2016 08:51 PM
Shawn Pierce
Jun 29, 2013 10:40 AM
dougz
Oct 3, 2012 07:55 PM
IQQIMINI
Jul 23, 2004 01:00 PM
username
Dec 18, 2002 11:40 AM
