Tach Rattling
Old Aug 18, 2009 | 05:17 PM
dooky's Avatar
dooky
Tach Rattling
Is it just mine or does the area around the "alarm light" on the tach rattle (vibrating noise)? Should I take it back to the dealer or is this something I have to live with.
Old Aug 18, 2009 | 05:51 PM
carsncars's Avatar
carsncars
Mine buzzed once in a while. Dealer fixed it with a bit of... silicon glue or something.
Do it under warranty. It might not be something that's worth seeing the dealer fore solely, but you can get them to fix it at next service.
Old Aug 18, 2009 | 07:57 PM
thevelourfog's Avatar
thevelourfog
I had this problem with the tach rattling somewhere between 2k and 2.5k rpms. One dealer tightened the screws which seemed to work for maybe 500 miles and scratched up the back severely (South Bay MINI) and I ended up taking it to Assael MINI and they replaced it which cured it. After this, the programming got messed up and I had to take it in again to get it fixed, but the tach hasn't ratted in a few thousand miles.
Old Aug 18, 2009 | 08:13 PM
krim's Avatar
krim
they (monrovia) put two strips of felt in my tach.
Old Aug 18, 2009 | 08:14 PM
Robin Casady's Avatar
Robin Casady
No rattles here.
I thought Tach Rattling was going to be something like Sabre Rattling, but with MINIs.
Old Aug 18, 2009 | 09:51 PM
dooky's Avatar
dooky
Thanks for the replies... I guess I'll have to try my luck with the dealer!
Old Aug 18, 2009 | 11:39 PM
Sketch's Avatar
Sketch
Mine used to do that but all of a sudden stopped
Old Aug 19, 2009 | 01:25 PM
thevelourfog
I think my tach was replaced because I had a prior issue with it. If they do a patchwork fix, I'd say sabotage it somehow (loosen screws or remove tape) and ask for a more permanent fix.
Old Aug 19, 2009 | 04:03 PM
chowdah's Avatar
chowdah
Mine rattles once in a while ... it has a mind of its own so I'll get it checked out the next time I'm at the Stealership!
Old Aug 19, 2009 | 04:21 PM
BF_'s Avatar
BF_
This is one of my three current rattles, and strangely began occurring after I mentioned a dash rattle (for which the dash was removed) when I came in for my yearly service. Seems I traded one for another.
Rattles from 2.1-2.5k without fail. Even though I'm only about 20 min from my dealer I'll wait to mention it at my next service in 7k.
Old Aug 19, 2009 | 08:32 PM
dooky's Avatar
dooky
I have an appointment next saturday with the dealer... wish me luck!!!
Here's the list of stuff I need to get fixed... so far.
1. hood needs to be re-buff'd again because it still has bad spiderweb marks.
2. tach rattle
3. passenger airbag light is on even though someone is sitting there.
4. the rear tow hook cap keeps coming off
my car has less than 300 miles.
but i still love the car!!!!
Old Aug 20, 2009 | 09:11 AM
thevelourfog
I had this problem too when my car was new, one of the tabs was damaged and the tow hook cover would just dangle there. My MA just took one off a car on the lot and swapped it.
Old Aug 26, 2009 | 12:30 PM
torobud's Avatar
torobud
My tach has been rattling... when the car was in for service they took a look at it and said no problem we will fix it right up as part of a 'dash kit' for rattles... it rattled on the way home from the dealer... car is going in for service again soon and I might not be as nice this time...
Old Aug 26, 2009 | 02:53 PM
Davidoyo's Avatar
Davidoyo
My tach rattles too but only every now and then which is weird .
Old Aug 26, 2009 | 04:43 PM
Porthos's Avatar
Porthos
You dont have the prosport boost gauge cause that thing rattles like its going out of style
Old Aug 26, 2009 | 05:12 PM
Mike1968NM's Avatar
Mike1968NM
We have the exact same problem between 2K and 2.5K rpms as well. Annoys the hell out of me but my wife is indifferent. Next appt with the dealer we will have this and the door sills coming up again addressed.
Old Aug 26, 2009 | 07:15 PM
ElNino's Avatar
ElNino
Yup same problem here. Doesnt happen very often but when it does its bloody annoying. Still need to do the exhaust pipe recall thing, so I'll see if I can get it fixed at the same time.
Old Aug 31, 2009 | 09:44 AM
dooky's Avatar
dooky
So I went to the dealer over the weekend... Showed the tech the problem, he said he'll order a new tach and should have it installed this up coming weekend. I'm happy, except for fact that I keep having to drive there for repairs.
Old Mar 28, 2012 | 05:54 AM
chinq6t's Avatar
chinq6t
So the only fix so far is to replace the tach..? Man im out warranty and its such a minor annoying fix.
Old Mar 28, 2012 | 06:05 AM
axleR56's Avatar
axleR56
A dab of clear silicone fixed mine, can't notice the silicone either if you do it carefully.
Old Mar 28, 2012 | 06:41 AM
chinq6t's Avatar
chinq6t
I'll try that clear silicone, i first tried wedging a toothpick but that eventually came loose since it's not thick enough
Old Mar 28, 2012 | 06:50 AM
alexs3d2's Avatar
alexs3d2
There is some rattling from the tach, but it comes from the internals. But then again, I have a car with Nav which has a different tacho...
Old Mar 28, 2012 | 07:40 AM
chinq6t's Avatar
chinq6t
When i put a finger on the plastic of the tachometer it stops rattling so some clear silicone should help
Old Mar 28, 2012 | 06:51 PM
Btwyx's Avatar
Btwyx
We had a rattly tach, the dealer did something involving felt tape to quiet it.
Old Jun 15, 2012 | 04:21 AM
12 JCW's Avatar
12 JCW
Where did you put the silicone? Did you take the tach off first -OR- only while it is still attached?
On mine, I jammed a piece of camper top foam strip in the front lower part and this made it rattle less for a day and now the rattle is gone. But I noticed the rattle on 90+ deg days and it has only been in the 70s-80s lately, so maybe the heat changes the tolerances between the plastic pieces.
