dropped brake reservoir cap, help!
Hey guys, I dropped my brake reservoir cap down that stupid black square hole that it's housed in, and I can't see the damn thing, and I tried fishing for it with a coathanger and anything I could get my hands on.
Is there some way I can remove that damn plastic? It looks like it's all sealed up....
I need help with this ASAP, thanks in advance
1. pull caps off of windshield wiper arms to expose nuts.
2. loosten with (i think) 13mm. You may need to just barely loosten the nuts and hit them with a rubber mallet to break them loose from the wiper stalks
[wipers now off]
3. pull off weather stripping at rear of engine bay (theres no glue or anything)
4. there are 3 points (i think 10mm) on each side holding the plastic down. 2 plastic nuts, one by the strut and one by the hood hinge. There is the last metal bolt near the windshild behind the hood when its up.
5. pull the plastic cowl off. its clipped onto the plstic firewall too...just pull
should be it
you can just do the driver side if you want... but youll need to remove both wiper arms still
[wipers now off]
should be it
Help. Is there anything down the hole the cap can hurt if left in there
[QUOTE=etalj;2846979]thanks very much. Also, I should mention that I have a right hand drive car (as I live in australia), would anything be different?[
I have a left hand drive 2010 and have dropped the brake fluid cap in the “hole” is there anything down in there the cap can hurt if left ?
Kimolaoha
Jul 5, 2023 01:04 PM
blackie
Jan 18, 2017 09:56 PM
minipopkart
Aug 13, 2015 05:22 AM
