View Full Version : Stock Problems/Issues
- Whats Wrong?
- 2007 R56 Bluetooth can't pairing
- Suspension Help
- '07 clutch not engaging
- Intake tube popping off turbo, any suggestions or similar stories?Help Needed!Thanks!
- Yet another Carbon cleaning report...
- DIY turbo oil line pointers
- One xenon is brighter than other
- 2nd CAS in less than 30k miles!
- P0012 code after oil change, and how to reset the service lights?
- 07 Base R56 jerking/surging at idle and while driving
- Wynn's De-Carbon Foam
- I hate working on this car
- Incorrect Odometer Due to Speedometer Readings
- Fuel filter missing ?
- Mending the HighPressurreFuelPump
- P0303 Cylinder 3 Misfire. Please help
- 2010 R55 Clubman S Won't Take Coolant
- Help! Need turbo removal help!
- Coolant Leak - Thermostat?
- Warranty almost up, upper guide cracked?
- Topped Oil Off / Leaking Engine Gasket
- Rats! Cable chewed - Replace or Not?
- 2010 HPFP issue - warranty or not?
- R56 MCS random misfire
- How to take off coolant water pipe
- Heated seats not working
- delete stored messages
- Rattling or Chattering on WOT
- Cold start noise?
- Anyway to bypass depress clutch to start?
- Replaced HPFP almost 2 years ago but...
- Creaking noise when wheel is turned sharp
- Mini r56 "S" no fire
- A/C "damage" due to impact?
- New here, Car Is Broked.
- CEL: p115d non-S 2010 R55
- harmon/kardon radio can not switch channels
- Misfire! P0300, P0301, P0303 errors
- Emissions readiness issue with dash command
- Oil cosumption, engine noise, AC noise
- Water from exhaust and bubble in coolant tank while starting
- 2007 R56 S - Possible HPFP problem???
- White smoke from bonnet
- Battery Issue
- Crank sensor location Justa non s r56
- Broken front sway bar
- Justa 2007 idle/eml issues
- 09 JCW turbo failure
- Water in boot
- No voltage between fuel pump and fuel pump relay
- yellow warning light MC r56
- High Pressure Fuel Pump, MINI wont replace mine!
- Auto dimming rearview mirror issues
- Coolant Reservoir, Coolant Wanted Out!
- p3091- warranty?
- Head Gasket or Cracked Block
- Rubbing/Grinding Noise on Right Front
- Just Fixed my "Death Rattle"
- DIY timing chain - cam lock tools from eBay?
- Any Problems With the Aisin Automatic Transmission
- Dual Mass Flywheel Hot Spots?
- P2ee2?
- Door sill trims to R55 Clubman
- Vibration under acceleration
- Oil Leak Help
- Help I'm stranded ! Code p2b64 ??
- 2014 clubman oil leak
- low engine oil issue?
- Need help with bent bumper frame!
- P0112, P0112B, low power, low ECT. '08 R56 S.
- airbag warning light
- P0300, p0301, & p0303
- R56 s howling
- Sunroof rattle
- Code P3091 after HPFP replacement
- Transmission Limp Mode Problems
- Surging on acceleration, compression testing.
- 2008 MCS with suspension issue
- Loose seat back
- My BOV blew itself apart
- Triangle Warning Light, but No Codes??
- Yellow Engine Light & Limp Mode
- 2009 MCS engine light P0303 (misfire)
- A/C low charge from factory ?
- Can you hear your AC compressor inside the car?
- 2007 R56/N12 VANOS and Timing Chain Issues
- TPMS Inactive after summer wheel back on
- Diagnosing smoke/smell from turbo
- n18 high pressure fuel pump failure and walkthrough.
- P2626 code - Check engine light
- N18 JB+ intake/valve weird sound
- Key Fob Stopped Working Not starting ?
- Rebuild or replace engine
- Boost leak or something
- Small oil leak
- Anyone replacing fuel injector seals themselves?
- Lower Radiator Hose
- p0442 Check Engine Light
- Running rich?
- 2nd High Pressure Fuel Pump Failed Out of Warranty
- Cam Tensioner Bolt Seal.
- Ruined Turbo - Replace the catalytic converter?
- Flickering left dipped beam Xenon
- R56 stall/dying/start up
- Strange cracking noise on left front wheel
- Recommend clutch mechanic in Milwaukee, WI
- Any Problems With 2nd Gen Justa's?
- R56 cruise control and hill start assist not working after Viper alarm removal
- Is Carbon-Buildup still a problem in N18 engines??
- Driver Side Window LOST ONE TOUCH UP after ECU updated
- glued my sunroof shade shut
- Need help/advice! White smoke!
- Need some help/advice!
- OEM rear sway bar endlinks
- High Oil Consumption?
- Is this coil pack shot?
- stuck piston ring scenario
- Fuel Tank Vent Valve Location
- R56 High Load/WOT Misfire
- Any Non-S Coopers with Oil Consumption Issues
- Sporadic Hatch Functionality
- Idling issues loss of power
- Rough Idle, Stuttering Accel., Exhaust smoke
- Coolant leaking from block?
- Starting issues battery
- Check Engine Light - Carbon Build Up
- Need help with engine codes P0014, P0015
- 2008 mini cooper base water pipe replacement
- Check engine light and air filter
- N12 with P0015
- Working on brakes
- Rough idle, acceleration and lack of power
- new Service Bulletin? SI M11 01 12
- 07 Cooper S Dead at 107k
- 2008 Cooper won't start, no CEL and no OBD codes
- Auto Gear Position Lights go off
- Limp Mode
- Blown O2 Sensor?
- Power Fold Side Mirror Intermittent Problem
- Nav Screen/System Not Booting
- timing chain tensioner & engine oil
- Intermittent Thermostat Failure?
- Stock Problems "Wiki" Database
- Need Some Positivity in Here
- Clutch slipping and failed at 36K; keep the car?
- Auto gearbox help
- 08 MCB's driver's window rolling to the midway when flick auto-up
- Power loss, ECL, etc
- What type of bulb in the fog light housing of the 2013 Cooper S?
- After Burnt Exhaust Valve Rebuild....Noise From Valve Cover
- This doesn't sound right - vacuum leak
- 07 Cooper Base Auto- No crank issue.
- CEL & Oil Leak
- Fuel Rail Pressure Question
- Theres oil everywhere...
- Tachometer display not working - no odometer reading
- Service Interval counter: rapid countdown.
- Wheel noise when turning right at speeds over 30 mph
- Can you lock the doors?
- Smog Fail
- 12 Degrees today and I get no heat.
- Really hard shaking and dies at stops
- Downpipe leak and influx boost
- Inner tie rod replacement
- Power steering failing when cold
- Oil in Turbo
- Red steering wheel lock on display
- Auxiliary water pump noise
- P2400 Help
- Power window, clock, and door lock issues.
- Rad Fan staying on after driving
- R56-Passenger seat broken - loose release handle
- Coolant leak - not thermostat housing !
- Justa Timing Chain Slack
- 09 r56 s auto stuck in park
- 2187 error code on the R56S
- 2007 Manual stalls when in neutral?
- Help with coolant leak, Water Pump - Thermostat pipe
- Busted CV joint. Advice?
- engine noise from driver's side
- Timing Chain Tensioner
- 2007 MCS R56 with sunroof rear view mirror water leak
- Mini reliability
- Engine issue, not sure if dealer fixed underlying problem
- O2 sensor problem
- Help! - Replace PCV Hose
- Airbag Light problem on 2007 R56.
- clutch/flywheel changing
- Several codes thrown, need some opinions
- R56 JWC not shifting smoothly
- '13 oil selanoid leaking
- Airbag light on constantly
- Need some advice regarding gas tank issue
- CEL but no code
- R56 JCW electronic issue
- Dealer finds cracked water pump and leaking timing chain tensioner
- Engine shaking when coming to a stop/idle (video)
- Ambient Mood Lighting - Cycling through colors at door open.
- xenon headlight help
- ECL and loss of acceleration when stepping on the accelerator
- 07 MCS Slow to Warm Up!?!?!?
- Help Me Stop The Noise
- Replace OEM cat with aftermarket
- Timing chain reimbursement advice?
- 09 R56 MCS Grinding while steering
- Justa automatic - car goes in manual sport
- Help on how to Seafoam a 2011 MCS
- Side Markers Occasionally Light Under Braking
- Stalling out after long drive??
- 2011 Base throwing 3 codes: P0100, P0003, P15E5
- "Better" clutch parts question
- Water Pump time
- Passenger Window Doesn't Roll Down Completely
- 2011 Mini Cooper S Seat Belt & Airbag Light
- High Pressure Fuel Pump failure symptoms
- no start, need help
- 07 mcs speedo
- stuck in neutral
- Need help diagnosing the VANOS fault
- Timing chain question (hopefully not a retread)
- yellow half full cel with weird idle
- 2nd Gen - MINI - Update
- TPMS and cold weather question
- Startup Problems with Recent Arctic Cold
- 2007 R56S lean/rich idle and Throttle position codes
- Engine overheated - need new engine?
- My 2010 justa sounds like a tractor
- Backfire while idling?
- R58 Electrical or Brake problem?
- 07 MCS Shifting Woes
- electrical or mechanical?
- Less dust brake pads instead of the OEMs
- New Valve Cover Needed 2007S - Any Joy?
- P2188 back with a vengence
- Tips for friend buying a used R56 Justa
- Lost compression in #2 cylinder - 2009 R56
- Care and Feeding of Timing Chain
- Gunk found in oil catch can
- a petition towards BMW
- A stupid mistake involving super glue and my finish...
- Yellow steering wheel, arrow left and right side of it??
- No heat -- and no diagnosis.
- 2011 R56 Whirling noise after engine shutoff
- MFSW Cable Problem
- Buzzing like noise on accelerating
- Xenon Lights Auto Level Issue
- vacuum pump, lines, tank and pressure converter
- 2008 Cooper - CEL P1062 - VVT Limp Home Request Full Stroke Position Reached (Bank 1)
