View Full Version : Stock Problems/Issues
- Potential Dealer/CPO issue:
- Exterior 'C' pillar removal.
- Hood latch R55/R56
- Smoke only after long idle
- No Turbo!
- First time engine rebuild soup sandwich
- Rear fog/Reverse light and License plate lights inop
- Problem with JCW sport gauge (water temp) on 10' MCS
- 2002 Problem with Radiator Temp ??
- Coolant Temperature too high?
- Engine died during dealer service
- Burnt-looking camshaft and other woes
- looks like the Solenoid valve need replacing!
- Climate control fan speed LEDs
- Mini Windows Openining By Themselves
- Clear misfire error code
- Windshield wipers not working
- '13 r56 Dash liner separating from plastic underneath
- Random misfires - attached video please watch and name that engine problem
- engine rebuild time
- Blown engine
- Misfire/Hesitation @ 2400rpm: R56 Cooper (Non-S) 2007
- Accelerator Failure/ Gas Pedal Fail while driving
- Oil pressure light at idle
- service manuals
- Stumbling and Stalling
- Updated coolant sensor harness backorder?
- The Dreaded P115c Code
- Engine Turns off when Idle
- Timing Chain/Engine Repair
- Need Help With OBDII Code
- High presure fuel pump not covered
- Stalling when warm. Help!
- Rough idle/misfire pls help!!!
- Need some help- re-setting oil change
- R56 left sitting for ~24 months
- coolant tank or cap replacement?
- [Solution] R56S cranks but won't start
- Help id this part!!! (Vacuum Pump - broken nozzle)
- speedometer lights dimmed, blurry, cut off
- Misfires Cylinder
- Help!. High beam doesn't turn on!
- CEL, P2177, P2187, no power over 3000 and stalling idle..
- Spark plug socket stuck aka I'm an idiot, what will this cost
- Water pipe replace: tricky?
- Throw-Out Bearing Clips
- Wouldn't start, now has high pitched whine
- Oil leak...ughhhhh!!!
- Yellow Reduced Engine Power Light
- Car Not Starting
- 2010 clubman s headlights stay on even when car is off
- foot brake problem
- Good source for Turbo Replacement Parts
- Please help solve this Mystery! Air getting into Cooling System only under load\boost
- Am I being taken for a ride? (Not the good kind)
- 2010 Base misfire when warm, smooth when cold problem!!!
- 2010 base misfire when warm, no mifire when cold problem!!!!
- Rattling Dashboard ... solved
- Is this noise coming from my "new" 2010 MCS's engine normal?
- Anyone please help. #4 cylinder compression issue
- Coolant Problems
- Leaking coolant temp sensor O-ring replacement?
- R56 08 cooper s engine removal
- Engine knock at idle only - 2010 Mini Cooper base auto
- Please help with vacuum lines
- Initial No Start(fixed) Now-Loud Clanging Driver's Side
- First issues
- 2011 Mini Cooper Won't Start. Clicking Noise. Help :(
- Mini headlights
- Boost pressure control deviation please translate
- Lucky 2008 S Owner
- Check engine light , no codes 2011 s n18
- 2008 Mini Cooper S Convertible - Maintenance Record
- how to tell if valves need cleaning
- Spark plug broke, now I'm panicking!!!
- Has anyone used 10-60w oil in their mini
- Oil Leaks
- oil in cyl4
- Water pump needs replacement?
- Bad intake hose cause scoring on cylinder walls?
- Turbo seal leak and possible bad fuel pump
- Engine idle and accell problem codes
- 2008 Mini Cooper smell when AC cooling
- Idle Up a few hundred RPM then gone.
- Need help diagnosing the problem
- Lowering Sub-frame - not removing
- JBE Water Damge - No Start Help :(
- Can't reset codes.
- Auto Trans shift lock
- Justa Clubman overheating question
- Clutch noise
- Fuel pump running after its shutoff R56S
- 2009 MCS valve cover leaking oil
- Opinion on timing chain
- Rough Start R56
- 2009 Mini Cooper S electrical problems
- Motor Mount DIY
- Driver's Door Lock Issue
- Misfire
- Chain Tensioner Length?
- R56 water pump replace question.
- Intermittent coolant leak
- Help with Washer Fluid Hose Replacement
- P2096 or P2270 plus reduced gas mileage
- new brakes and sensor, still have low pad indicator
- '07 R56 O2 Sensor Replacement
- Hood Release Not Working - Please help
- Bulb for side marker "arch" lights
- Failed State Inspections 2 Items Needed
- Help! N18 MCS (Singapore)
- Alternator Replacement
- CEL after oil change and WMW noise maker delete
- Fuel smell after hard turn
- Coolant in Intercooler
- Got my @$$ kicked by a turbo stud
- Harman Kardon Amp/Sound Cut out
- 09 Cooper no warning chimes
- Difficulty shifting + Dilemma
- Washer Stalk Control Does Not Work
- Hood Release Help
- 2007 cooper non s idle issue
- P0957 - Thermostat stuck open?
- '09 Mini Clubman - driver's side window won't close completely.
- having engine trouble (new to site)
- Cyl 2 misfire on 07 Cooper S
- Mystery Noise
- Where's the smell?
- Tranny probs
- Oil Leaking from Lower Control Arm Bushing
- Coolant Leak Troubleshooting 2009 R56
- 2008 S Auto having trouble shifting out of 1st gear
- JCW Recaro Seats - The real deal SOLD
- clutch and flywheel are toast...how many miles can i go?
- Oring for coolant reservoir connection?
- R56, sometimes 3 cyl, sometimes not, + Gbox problem?
- Engine light/loss of power/ not rev past 3k rpm
- Getting a 2nd key fob (2011 hardtop)
- Could this be a bad thermostat housing?
- Water pump pulley
- Engine decisions
- Clutch, flywheel, both..?
- How to turn off service warning 2009 mini
- Anyone diy replacing oil solenoid valve yet?
- Clutch issues and bloody knuckles
- help locating wire for coolant temp sensor
- Help: 2011 LCI models driving light bracket issue
- Po 117 r56
- Taking out option armrest, need to order parts.
- Need Some Help Here
- Red Steering Wheel Lock - No Start
- h13 hid wiring question
- Airbag warning and random loss of electricity related to door slam
- sudden p013e code and lack of power
- 2007 Mini Cooper Timing
- Fuel additives
- 07 Cooper s compression issue
- A/C Not Cold After Only 3K Miles On the Odometer
- 2009 R56 Base M/T Won't start
- 2007 used mini s
- 2013 mini cooper s alternstor whine
- 2013 cooper Heater issue
- 2009 mini cooper s loss of power p3091 and P2177
- Sputter on load
- P0087 and carbon build-up: related according to a Mini SA
- Red oil light comes on briefly
- Stumbling on Cold Start - 2007 MCS - thoughts?
- Can bad vacuum pump cause fuel pump codes?
- 2008 R56 Bearing Noise...Help!!!
- What fails inside the HPFP?
- The right Gen 2 S Spark Plugs/Misfire Codes/Coil Packs
- Hazy spot on headlights - BUT t's not oxidation
- Replaced thermostat housing - code P2F19 after install
- Oil light after engine heats up st idle
- Dirty exhaust
- Rough Cold Starts X 2
- N18 Engine Hissing Sound and Weird noise (Video inside)
- Knee Bolster removal
- Help! 2011 Clubman S quote - ignition coils
- 2010 Clubman S- Disconnected Battery, now electrical issues
- Official Timing Chain repair kit
- Anyone had the "Transmission Malfunction" message?
- Need advise on troubleshooting overheating issue.
- Anyone Else had Multiple Valve Cover Failures?
- Does Anybody Have TIS or DIY for Lifting R57 SoftTop to Replace BeltLine Trim?
- tach display issue
- R56 Radio stopped working suddenly
- High Pressure Fuel Pump PRICE GOUGE (HPFP)
- P129D - MAP Max Pressure Implausible
- Sunroof leaking question: Is seal replaced with new cassette?
- R56 Oil leak
- Class Action Settlement Confirmed for R56 Timing Chain Issues
- P0015 "B" Camshaft Position - Timing Over-Retarded
- After Intake valve media blast
- Finally took it to Mini and.....
- Whats wrong with my car!????
- misfire still after spark plug change
- High pressure fuel pump
- Turbo R55 starts but doesn't run
- Severe issues happened while replacing a trunk light bulb
- Cold idle noise
- low horn not working
- cabin air filter help
- Low battery warning light
- R56 Engine Oil Pump replacement
- 2007 Mini Non-S Hatch Misfire on all Cylinders
- Fuse for TPMS?
- All I want for X-mas is a New Engine...
- Coolant cross over tube help needed.
- Checking cam timing
- Climate Control Issues - 2009 JCW
- Drivetrain check light...
- How I killed the footwell heat.
- "Loose rocker arm"
- No start after fuel filter change 2009 Clubman
- Power folding mirror missing start-stop points
- Slipping clutch or something else causing acceleration hesitation?
- Sunroof problems (again)
- Have I lost my key coding HELP
- Carbon Buildup Treatment
- Mini cooper spuddering help
- Seat disassembly
- Cruise control malfunction indicator lamp. Extreme low engine power.
- Constant oil Burn. White Smoke! Decat
- Drivetrain engine light and airbag warning
- need v clip for thermostat replacement
- Clutch slave cylinder & starter lockout circuit
- R56 Headlight adjustment
- Help with fault codes
- Need part number for a light on my mini cooper
- 2008 Clubman S Head Gasket / Head
- 2013 r56, heater won't blow hot air
- Valve Cover Leak?
- Any solution for oil consumption where the are no oil leaks?
- Spark plugs worn out at 53k miles (R56)
- Car wont start turbo blew and clutch replaced
- DSC/ yellow brake light
- Several oil leaks
- Bulb indicator
- R5x windshield cowl help please
- 2005 HID Ignitor melted, can I go aftermarket?
- Is this normal?
- Intake pipe between MAF and turbo broke
- Stumbling at WOT, no codes
- FRM VIN change problem
- 2009 MCS with 130K miles and a broken exhaust valve
- Buzzing from rear when car is off? Sound attached
- r55/r56 xenon adjustment ???
- I found the dtc!!!!!!!
- 2007 Mini Cooper R56 p0015 & p0017, Please help! :)
