Sunroof problems (again)
Old Dec 9, 2015 | 09:54 AM
alexs3d2's Avatar
alexs3d2
After a long time in hiatus, I am again back on the forum...
On the issue: My sunroof keeps kicking back at the full open position whenever I try to close it. I need to so it in stepped-fashion to get it to move out of that. I literally tried everything, from oiling the hell out of the frames and the seals, re-positioning the glasses, to re-initializing and finally upgrading the ECU with WinKFP and recoding. It even does it with the rear panel removed, so I've concluded that the culprit is the body-seal.
Is there any lubricant, that I could use on the seal?
Old Dec 10, 2015 | 01:15 PM
Try some gummi pflege ? That's what MINI used to use on all the seals and weatherstripping.
https://www.google.com/webhp?sourcei...q=gummi+pflege
Old Dec 13, 2015 | 11:23 AM
KKelly's Avatar
KKelly
Same Sunroof Problem -- with a workaround
I've had the issue with the sunroof kicking back when trying to close from wide-open.
Here's what I've observed:
From the wide-open position, when I press the "close" button on the sunroof, it starts to close but then "kicks back" to the wide-open position after about a second of movement.
I can try hitting the button as many times as I'd like, I can try turning the car on and off for various lengths of time--all to no avail.
It only happens when I'm parked.
If this happens, the workaround I've found is to start driving down the street, get it into second gear, and press the close button and magically--it works.
I do not know what's happening, but it seems that I can do nothing when parked. Only when I'm driving will it close, and it has closed every single time i've tried this without fail. Once it has kicked back while parked, it will NEVER close while parked. Strange indeed.
I have done some coding. Specifically coding to allow things like key fob and comfort access to close and open windows/sunroof. I do wonder if this has helped create this issue. I can imagine that there are a bunch of logical conditions that create a different "state" of the car when driving versus being parked, and there could be a conflict between the logical conditions enabled by default versus the ones activated by coding. I'm just guessing.
Any ideas? Anyone else have this problem with or without coding??
Old Dec 14, 2015 | 10:18 AM
Did you treat the seal and see how it slides ?
Old Dec 14, 2015 | 11:08 AM
alexs3d2's Avatar
alexs3d2
I haven't yet got the GummiPflege thing, but I did try some silicone spray. Unfortunately it did not help...
I know that using Tool32 you can see all the data recorded when the anti-trap kicks in. Including the force, but I don't know how to interpret them. I'll post a copy to see if anyone can shed some light...
Old Dec 14, 2015 | 11:14 AM
ok, see what we can find, the silicone stuff is slippery , but does come off in time, gummi fledge seems to stay longer.
Old Dec 15, 2015 | 03:30 PM
alexs3d2's Avatar
alexs3d2
Here we go...
apiJob("SD_KWP","bb_history_lesen","","")
Satz : 0
OBJECT = sd_kwp
SAETZE = 1
JOBNAME = bb_history_lesen
VARIANTE = SD_KWP
JOBSTATUS =
UBATTCURRENT = -1
UBATTHISTORY = -1
IGNITIONCURRENT = -1
IGNITIONHISTORY = -1
Satz : 1
STAT_BB_01_POSITION = 1881 07 59 .Y
STAT_BB_01_AMBIENT_TEMP = 22 00 16 ..
STAT_BB_01_COIL_TEMP = 33 00 21 .!
STAT_BB_01_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_01_FORCE_THRESH = 2918 0B 66 .f
STAT_BB_01_OPENING = 0 00 00 ..
STAT_BB_01_CFLINORPOST = 0 00 00 ..
STAT_BB_01_CFLPREORIN = 1 00 01 ..
STAT_BB_01_CARSPEED = 0 00 00 ..
STAT_BB_01_MOTOR = SHD
STAT_BB_02_POSITION = 1880 07 58 .X
STAT_BB_02_AMBIENT_TEMP = 22 00 16 ..
STAT_BB_02_COIL_TEMP = 33 00 21 .!
STAT_BB_02_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_02_FORCE_THRESH = 2887 0B 47 .G
STAT_BB_02_OPENING = 0 00 00 ..
STAT_BB_02_CFLINORPOST = 0 00 00 ..
STAT_BB_02_CFLPREORIN = 1 00 01 ..
STAT_BB_02_CARSPEED = 0 00 00 ..
STAT_BB_02_MOTOR = SHD
STAT_BB_03_POSITION = 577 02 41 .A
STAT_BB_03_AMBIENT_TEMP = 17 00 11 ..
STAT_BB_03_COIL_TEMP = 19 00 13 ..
STAT_BB_03_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_03_FORCE_THRESH = 9104 23 90 #
STAT_BB_03_OPENING = 1 00 01 ..
STAT_BB_03_CFLINORPOST = 0 00 00 ..
STAT_BB_03_CFLPREORIN = 1 00 01 ..
STAT_BB_03_CARSPEED = 0 00 00 ..
STAT_BB_03_MOTOR = SHD
STAT_BB_04_POSITION = 574 02 3E .>
STAT_BB_04_AMBIENT_TEMP = 17 00 11 ..
STAT_BB_04_COIL_TEMP = 17 00 11 ..
STAT_BB_04_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_04_FORCE_THRESH = 9104 23 90 #
STAT_BB_04_OPENING = 1 00 01 ..
STAT_BB_04_CFLINORPOST = 0 00 00 ..
STAT_BB_04_CFLPREORIN = 1 00 01 ..
STAT_BB_04_CARSPEED = 0 00 00 ..
STAT_BB_04_MOTOR = SHD
STAT_BB_05_POSITION = 1880 07 58 .X
STAT_BB_05_AMBIENT_TEMP = 23 00 17 ..
STAT_BB_05_COIL_TEMP = 24 00 18 ..
STAT_BB_05_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_05_FORCE_THRESH = 2887 0B 47 .G
STAT_BB_05_OPENING = 0 00 00 ..
STAT_BB_05_CFLINORPOST = 0 00 00 ..
STAT_BB_05_CFLPREORIN = 1 00 01 ..
STAT_BB_05_CARSPEED = 0 00 00 ..
STAT_BB_05_MOTOR = SHD
STAT_BB_06_POSITION = 578 02 42 .B
STAT_BB_06_AMBIENT_TEMP = 24 00 18 ..
STAT_BB_06_COIL_TEMP = 25 00 19 ..
STAT_BB_06_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_06_FORCE_THRESH = 9104 23 90 #
STAT_BB_06_OPENING = 1 00 01 ..
STAT_BB_06_CFLINORPOST = 0 00 00 ..
STAT_BB_06_CFLPREORIN = 1 00 01 ..
STAT_BB_06_CARSPEED = 0 00 00 ..
STAT_BB_06_MOTOR = SHD
STAT_BB_07_POSITION = 1880 07 58 .X
STAT_BB_07_AMBIENT_TEMP = 20 00 14 ..
STAT_BB_07_COIL_TEMP = 32 00 20 .
STAT_BB_07_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_07_FORCE_THRESH = 2887 0B 47 .G
STAT_BB_07_OPENING = 0 00 00 ..
STAT_BB_07_CFLINORPOST = 0 00 00 ..
STAT_BB_07_CFLPREORIN = 1 00 01 ..
STAT_BB_07_CARSPEED = 0 00 00 ..
STAT_BB_07_MOTOR = SHD
STAT_BB_08_POSITION = 577 02 41 .A
STAT_BB_08_AMBIENT_TEMP = 20 00 14 ..
STAT_BB_08_COIL_TEMP = 20 00 14 ..
STAT_BB_08_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_08_FORCE_THRESH = 9104 23 90 #
STAT_BB_08_OPENING = 1 00 01 ..
STAT_BB_08_CFLINORPOST = 0 00 00 ..
STAT_BB_08_CFLPREORIN = 1 00 01 ..
STAT_BB_08_CARSPEED = 0 00 00 ..
STAT_BB_08_MOTOR = SHD
STAT_BB_09_POSITION = 1880 07 58 .X
STAT_BB_09_AMBIENT_TEMP = 11 00 0B ..
STAT_BB_09_COIL_TEMP = 18 00 12 ..
STAT_BB_09_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_09_FORCE_THRESH = 2887 0B 47 .G
STAT_BB_09_OPENING = 0 00 00 ..
STAT_BB_09_CFLINORPOST = 0 00 00 ..
STAT_BB_09_CFLPREORIN = 1 00 01 ..
STAT_BB_09_CARSPEED = 0 00 00 ..
STAT_BB_09_MOTOR = SHD
STAT_BB_10_POSITION = 1880 07 58 .X
STAT_BB_10_AMBIENT_TEMP = 11 00 0B ..
STAT_BB_10_COIL_TEMP = 17 00 11 ..
STAT_BB_10_REF_FIELD_VAL = 0 00 00 ..
STAT_BB_10_FORCE_THRESH = 2887 0B 47 .G
STAT_BB_10_OPENING = 0 00 00 ..
STAT_BB_10_CFLINORPOST = 0 00 00 ..
STAT_BB_10_CFLPREORIN = 1 00 01 ..
STAT_BB_10_CARSPEED = 0 00 00 ..
STAT_BB_10_MOTOR = SHD
DENORM_BB_INDEX = 8
DENORM_BB_BUFFER = 80 Bytes
0000 : 07 58 3D 44 00 0B 47 04 02 41 46 46 00 23 90 05 .X=D..G. .AFF.#.
0010 : 07 58 46 52 00 0B 47 04 02 42 4A 4B 00 23 90 05 .XFR..G. .BJK.#.
0020 : 07 58 49 4A 00 0B 47 04 02 3E 43 43 00 23 90 05 .XIJ..G. .>CC.#.
0030 : 02 41 43 45 00 23 90 05 07 58 48 53 00 0B 47 04 .ACE.#. .XHS..G.
0040 : 07 59 48 53 00 0B 66 04 07 58 3D 43 00 0B 47 04 .YHS..f. .X=C..G.
JOB_STATUS = OKAY
_TEL_ANTWORT = 86 Bytes
0000 : 80 F1 44 51 63 07 58 3D 44 00 0B 47 04 02 41 46 ?ñDQc.X= D..G..AF
0010 : 46 00 23 90 05 07 58 46 52 00 0B 47 04 02 42 4A F.#..XF R..G..BJ
0020 : 4B 00 23 90 05 07 58 49 4A 00 0B 47 04 02 3E 43 K.#..XI J..G..>C
0030 : 43 00 23 90 05 02 41 43 45 00 23 90 05 07 58 48 C.#..AC E.#..XH
0040 : 53 00 0B 47 04 07 59 48 53 00 0B 66 04 07 58 3D S..G..YH S..f..X=
0050 : 43 00 0B 47 04 42 C..G.B
Old Dec 16, 2015 | 10:14 AM
alexs3d2's Avatar
alexs3d2
I guess this is a bit too technical to understand.... But I've been looking at these values and what I am finding interesting is the "REF_FIELD_VAL" value, which is also returned when running the "status_kennlinie_lesen" command. For all the locations the sunroof is jamming, the reference value is 0. So I believe the sunroof is not "learning" the resistance values, otherwise that field would have a value.
I'll investigate a bit more and post back...
Old Feb 9, 2016 | 02:42 PM
alexs3d2's Avatar
alexs3d2
UPDATE!!!
I was able to finally solve it!! I removed the SHD motor from the cassette, opened it up and sprayed some silicone spray on the motor bearings. I tried manually rotating the cogs using a hex driver before and after and the difference was quite noticeable. Now my sunroof no longer stacks!! I recommend this to anyone with a sunroof, it really is pretty simple. I'll try and take some pics next time I open the module.
There were some cracks on the plastic cog and I am planning to find a way to fix this. Unfortunately you cannot change the cogs without special equipment (nor are they an official part) and the motor assembly is ridiculously expensively if you just need a plastic gear. For the time being it works flawlessly.
Old Feb 9, 2016 | 02:49 PM
Glad it worked. Looks like its was just a binding of the motor. Yea the motor is available on its own , those nylon gears are hard to repair. Post up if you find a material to repair them as most of the time you have to have a whole new piece due to the way they are made.
Old Feb 10, 2016 | 12:21 AM
alexs3d2's Avatar
alexs3d2
I am thinking of using an epoxy resin and glue a nylon washer over the gear. That should reinforce it and prevent any further cracking.
There is a guy a UK-based guy on ebay making replacement cogs but the price he is asking is steep: £60 if you install them or £100 if you send your motor in and they do the replacement.
Old Feb 10, 2016 | 08:20 AM
That's some pricey cog work Update with what you end up doing. Would like to see.
studio47
Dec 4, 2015 08:46 PM
aviaator
Nov 26, 2015 06:47 AM
elite2000
Nov 25, 2015 07:37 PM
Danske
R60/61 Cooper S Drivetrain
Nov 24, 2015 11:03 AM
Mrjoey22
Nov 21, 2015 11:07 PM
