R56 Headlight adjustment
Old Nov 26, 2015 | 08:04 AM
aviaator's Avatar
aviaator
Happy Thanksgiving!
I get that the drivers headlight is aimed slightly lower intentionally but IMO both of the headlights are aimed too low. Living in "deer country" I'd like to be able to see a little further during these long winter nights. Even the high beams look too low to me.
Standard halogen headlights on a 2013 Justa... Can someone tell me how to raise them a skosh?
Old Nov 29, 2015 | 04:04 AM
wdavidhicks's Avatar
wdavidhicks
This may help, Mike.
https://www.northamericanmotoring.co...eadlights.html
Old Dec 1, 2015 | 09:50 AM
aviaator's Avatar
aviaator
Thanks Dave, I did see that thread but thought it was geared toward the xenon headlights instead of the plain Jane halogens. I'll take a look and see if they adjust in a similar manner.
Old Dec 9, 2015 | 11:45 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
We go over adjustment in our headlight replacement DIY.
To adjust the headlight beam aim, open the engine hood and look for the small plastic Phillips head adjusters (green arrows) at the back corners of the headlights. When adjusting headlight aim, be sure to have the tires at the correct pressure, the fuel tank full and the weight of one person in the driver's seat. You can also align the headlight with the opening in the hood. Loosen the 10mm mounting fasteners, and then adjust them using the screw-in or out adjusters (red arrows). When adjusting the headlight to hood alignment, tape the headlight to prevent scratches.
888.280.7799 | 6am - 5pm PST
Old Dec 9, 2015 | 02:34 PM
aviaator's Avatar
aviaator
PERFECT! That's exactly what I needed - thanks!
For others who may be reading, the upper white plastic adjuster may be under a small black cover (mine was). Takes some digging to get it out.
Old Dec 10, 2015 | 01:02 PM
One thing is the main mount, mounts the headlight to align the hood and gap with the four eccentrics, the adjustment for the housing beam up and down, side to side.
Old Dec 10, 2015 | 01:11 PM
PelicanParts.com
Vendor
You're welcome. Glad I could help.
Old Jul 27, 2018 | 05:33 PM
joetiii's Avatar
joetiii
Floppy
so Maisey failed inspection cuz her right front beam was pointing down. Within the HLAssembly, the socket flaps up an down. Apparently the lamp is only attached by the one conne tion you can see from the access spot. repairable?
Old Jul 28, 2018 | 04:44 AM
joetiii's Avatar
joetiii
Floppy
​​​​​​​so Maisey failed inspection cuz her right front beam was pointing down. Within the HLAssembly, the socket flaps up an down. Apparently the lamp is only attached by the one conne tion you can see from the access spot. repairable?
Old Aug 6, 2018 | 02:25 PM
You would have to gorilla glue it or replace the whole headlight housing.
Old Mar 3, 2019 | 03:32 AM
KHAOS's Avatar
KHAOS
Thank you, this is great.
Are there only 2 plastic screws? I just noticed, while driving in fog, that my drivers side light is point up and to the right. I have not gone under the hood yet, figured I would try to find out how to re-aim before I make an attempt.
thank you
Old Mar 4, 2019 | 02:34 PM
Here is the TIS from MINI: https://www.newtis.info/tisv2/a/en/r...stment/HGzOmOl
Old Jan 5, 2020 | 03:05 PM
Royson's Avatar
Royson
R56 Bi-Xenon headlight adjustment
I spent at least an hour googling and looking for the location of the headlight adjustment screws on my 2009 Cooper S. This thread was one of the most useful I found, but still did not give me the exact location of those adjustment screws. I finally found a photograph showing where the adjustment screws are. Here it is
Old Sep 25, 2020 | 04:05 PM
luisfebar's Avatar
luisfebar
thanks for this guide!, but i have a real issue with my headlight... i buy a used mini cooper R56 and the plastic screw for adjust is smasshed, so cant adjust vertical light, any ones know what is the part number of that screw or where i cant find a replacement?.
thanks
willy-mini
Feb 19, 2015 09:45 PM
AKIndiMini
European MINIs
12
Jan 28, 2014 03:06 PM
troylees
Dec 5, 2013 10:49 AM
08pappy
Apr 5, 2011 10:30 AM
