P0015 "B" Camshaft Position - Timing Over-Retarded
Hi All.
My Wife's 2009 Cooper (petrol) had the engine light come on. So I scanned it and got the code P0015 which apparently is "B" Camshaft Position - Timing Over-Retarded.
Having searched the forums and googled it, this could be as simple as the camshaft position sensor. It certainly looks like its cheap enough to replace if only for elimination purposes anyway.
Is this the sensor in question?
TIA
TIA
Excuse me answering my own question, but this is for the benefit of anyone searching the archives.
On R56 MINI models, the intake (inlet) camshaft sensor is located on the left rear of the cylinder head (green arrow). The exhaust (outlet) camshaft sensor is located at the left front of the cylinder head (red arrow).
Full replacement procedure here.
Credit PelicanParts.com
Glad you found our article and it was useful for you and your issue. Hopefully it's the sensor and not a timing issue. Were there any other symptoms besides the P code? Be sure to report back once you replace the sensor and let us know if your issue is resolved.
888.280.7799 | 6am - 5pm PST
You can try switching the intake and exhaust sensors around to see if the issue follows to the intake sensor, but chances are you are out of time and need to do a timing cassette.
It looks like the picture shows 2 sensors to replace. The Pelican website says only one is needed. I have a 2011 Cooper hardtop. I haven't looked under the hood yet, but does anyone know off-hand if I need 1 or 2 sensors? Thanks
Sensors - http://www.pelicanparts.com/catalog/..._pg1.htm#item1
On N12, N16 (which is your motor), and N18 engines there are two camshaft sensors, intake and exhaust. On N14 engines, there is only an intake camshaft sensor.
You're welcome. Thank you for your order. I'll be sure to look into that. It's the same part number for both base and S models. If you ever get confused with something like that on our site you can always just shoot me a PM with the last 7 digits of your vin and I can double check fitment for you. Let me know if you need anything else or have any questions during the replacement.
Sadly my fault code has returned a few times now. I clear it but it comes back again? Also this time when I scanned it, I also had a p2414 code. Should I replace the other bank sensor and is there a possibility that the p2414 code was because of the bank sensors?
If it is a lambda sensor how do I know if its the pre or post cat one? Are they the same or different types?
So random that you posted this - my check engine light has returned also. It comes on for a day and then goes off the next. It's been coming on and off over the last two weeks and I don't know what the problem is. My code though, is the same original code you had (P0015).
I think I might need that timing cassette thing...
I've ordered another sensor to replace the other one and see what happens then. I'm wondering about the wisdom of buying non Bosch sensors TBH.
I'll replace both LAMBDA sensors if need be.
I missed nkfry's post about the cassette and just looked up what that is. I sure hope that isn't what it is? Does it affect the Cooper or is it just the Cooper S?
I'm not really sure if it ever went away as I was talking with my Father-in-law about how I'd used an OBD scanner on her Mini to identify and clear a fault and she said yes but it didn't work as that light still comes on and goes off!
We have done multiple Cooper timing chain kits, many of which have had the timing tensioner come out in 3 pieces, or the top timing guide broken.
You need to have the car professionally diagnosed, as it could be anything from a failed VANOS solenoid, which is an easy fix but about $145 for the solenoid, or you need a timing cassette installed, which will run you anywhere from $750-2500 depending on if you find a qualified indy shop or go to the....Dealer....
Don't replace the lambda sensor, chances are you don't need it and it is quite expensive. If there is actual proof that the sensor is failed then do so, but if you aren't having fuel economy problems, poor running/starting, and the sparkplugs don't "read" stoich, leave it alone.
Thanks nkfry. Its coming up for a service and we have a good local indy (BMW trained) so i'll see what he says.
I've stuck another camshaft sensor in there and went to reset the engine light but noted it had a P2414 code this time. The only fault in its running is, according to my wife, you put your foot down but nothing happens.
I've reset the code and test driven it and it seems fine, but we'll see how it goes...
My wife does mainly short journeys and they are all around town. So I'd be happy to replace that as a service item and if the video below is right it looks easy enough. Car has done 46k, is there a mileage these typically go at?
