Help! N18 MCS (Singapore)
Old Mar 7, 2016 | 01:31 AM
Thia's Avatar
Thia
Hey guys!
I own a 2011 N18 Mini Cooper S in Singapore
I've got a persistent issue on my N18 MCS. Are these signs of failing HPFP / In Tank Pump?
1) car is sluggish and not as responsive as before.
2) between 1500/2000 rpm there's always a distinctive jerk when changing gears. It happens during shifting up or down the gears.
3) Issues on point 2 is more prominent when fuel is running low (3/4 tank and below)
I was also told by my workshop that it could be a faulty throttle body issue. No codes have been thrown on the scanners though. So i'm wondering if anyone could give me some advice / explanation.
Thanks in advance
Old Mar 7, 2016 | 06:11 AM
thebombardier's Avatar
thebombardier
How many miles does it have and have you ever gotten a carbon cleaning on the valves? Could be that. If it was a HPFP issue or a spark plug/coil pack issue I'd bet more on there being a check engine light.
Old Mar 7, 2016 | 06:21 AM
Club77's Avatar
Club77
Hi bro,
I can help you to diagnose if there is any fault code.
Old Mar 7, 2016 | 10:21 AM
What code have you found and cleared in the past and do you have cold start up problems ?
Some other issues stated here:
https://www.northamericanmotoring.co...r-r56-jcw.html
Old Mar 7, 2016 | 10:20 PM
Thia's Avatar
Thia
its currently clocking about 87k. I've done a carbon clean, changed spark plugs and ignition coils. There's never any CEL issues.
Thia's Avatar
Thia
Originally Posted by Club77
Hi bro,
No fault code thrown bro.
Old Mar 7, 2016 | 10:22 PM
Thia's Avatar
Thia
In the past i faced irratic idling problems but it's now gone during cold start. And now once in a while i have problems starting the car but that doesnt happen very often.
Old Mar 8, 2016 | 05:55 AM
You are using premium fuel over there ?
Old Mar 8, 2016 | 10:46 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
A dirty or restricted fuel filter can cause poor engine performance and also hard starting problems. This is what ours looked like.
888.280.7799 | 6am - 5pm PST
Old Mar 8, 2016 | 07:53 PM
Thia's Avatar
Thia
Definitely! Ron 98 (Esso Supreme).
Not sure if this makes sense to you - I'm cruising on the freeway. At these point of time i'm gasing on the throttle. When i see a car slowing down ahead i release the throttle completely to reduce speed (w/o braking) and when the car ahead of me speeds up and i hit the throttle again THERE GOES THE JERK!
And i also realize it happens between 1.5k to 2k rpm.
Old Mar 8, 2016 | 08:59 PM
Systemlord's Avatar
Systemlord
N18 doesn't have a throttle body, it has a Valvetonic head. It could be the electric motor that controls the opening of the valves which ultimately controls the throttle. It's difficult to troubleshoot without codes being thrown or some sort of diagnosed being performed on various components to rule them out.
Old Mar 8, 2016 | 11:02 PM
MarioKart's Avatar
MarioKart
Vendor
The N18 still has a plastic TB, but typical is always open, except on cold start or when the car car isn't warmed up. On cold start the TB partially closes, and then the valvetronic will take over.
Since there are no codes, it makes me think it's the HFPP.
<_CFXNotificationTokenRegistration: 0x14deee70>
Old Mar 9, 2016 | 02:34 AM
Eurothrasher's Avatar
Eurothrasher
On an N18 engine, yours required carbon clean ? Bit irregular....never seen an N18 engine requiring this procedure yet....and they've been on the road since the latter part of 2010.
Give the engine a good once over, any signs of fluid leaks/damp areas ?
Old Mar 9, 2016 | 07:37 AM
Its has the throttle body, the TB can get gummed up from the oil/ moisture build up and need cleaned. I would clean the throttle body first.
https://www.ecstuning.com/Search/SiteSearch/ES2703625__ES2587103/
Some n18 i seen had the carbon cleaning done. It would be a good thing while your cleaning and checking the throttle body to maybe pop off the intake manifold and take a look at the intake side of the head.
Old Mar 9, 2016 | 07:42 PM
Systemlord's Avatar
Systemlord
Thanks for the headsup, looks Iike it performs similar to an electronic choke.
Old Mar 12, 2016 | 12:29 PM
Eurothrasher
There is an extended warranty from MINI for the HPFP on your model/year.
Old Mar 14, 2016 | 11:03 AM
But dont know if it cover all European MINIs or ones from Singapore, might want to give your local MINI dealership a call there if you go down that road.
Old Mar 15, 2016 | 02:54 AM
Thia's Avatar
Thia
Do you guys think the jerk could be a gearbox issue? Or an issue with the diverter valve?
The issue still persist these few days. I don't know how to explain this but it happens when u hit the pedal and when you release it and hit it again it happens.
Old Mar 15, 2016 | 10:43 AM
The gearbox it would be sloop and you would hear wining or clicking. On the diverter valve it would throw a code. Most of the time, pull the diverter valve , is it cracked on the diaphragm ?
Old Aug 28, 2021 | 04:11 AM
vnogueira's Avatar
vnogueira
Dear Friend. I have the same problem and I don’t find the solution. Could you solve it?.
thanks.
May 9, 2017 12:35 PM
Jan 19, 2016 11:38 AM
Jan 18, 2016 10:38 AM
Jan 15, 2016 03:56 PM
Jan 15, 2016 03:30 PM
