Mini Cooper Hood Scoop Vortex 1 Gen1 Cooper S R52 R53
Click Here for Pricing
Let's face it: The small opening in that stock plastic hood scoop just isn't delivering air to the intercooler the way you think it should. Don't worry, M7 has you covered once again. We're proud to bring you the M7 Vortex Scoop for the R53!
Fits the following models:
2002-2006 R53 MINI Cooper S Hatchback
2005-2008 R52 MINI Cooper S Convertible
Available in Fiberglass or Carbon Fiber. Make selection.
This Vortex Scoop replaces your stock hood scoop with a larger opening and more aggressive appearance. Tear drop flow straighteners are placed on the floor of the inlet surface to enhance air flow rushing into the scoop's opening. This is the perfect upgrade for those not ready to change out their intercooler but want to make the most of what they already have under the hood. The M7 Vortex scoop will deliver more air than your stock hood scoop helping to keep intercooler and engine temperatures down.
And it looks Aweaome! With its agressive stance and added flow straighteners it will set your MINI apart from the crowd.
Please Note: The plastic hood shroud may require some minor trimming to fit the larger aperture of the Vortex scoop.
As with all of our fiberglass scoops, the Fiberglass Vortex scoop comes in a white primer coating that must be prepped and finish painted to you desired color. These are hand crafted parts and minor imperfections may need to be finshed prior to paint.
Easy 60 minute installation. Drilling required.
Made in the USA!
Ryan Chamberlain
Nov 25, 2015 08:10 AM
