Stock Problems/IssuesDiscussions related to warranty related issues and repairs, or other problems with the OEM parts and software for MINI Clubman (R55), Cooper and Cooper S(R56), and Cabrio (R57).
In few days I'll be doing the Seafoam treatment to my MINI (through the vacuum line and the fuel tank. Not to the oil. But that's another story.)
My question is:
has anyone done the "distilled water cleaning" method in addition or in place of seafoam treatment?
If yes, is there any good result? and how was applied? in the same way as the Seafoam?
Not sure about that method, but if you're interested we do have a great DIY for a method on carbon clean up if interested.
The method is about spraying distilled water on the vaccum line instead of Seafoam, but I don't know if this is the procedure. The idea is the same: get water on the combustion chamber so it will clean the carbon there.
Apparently it is more effective but I will not get water in the engine of my car until to be totally sure of what I'm doing.
I don't see the article on your site. Have a link?
I'm interested in your DIY method, of course!
This method is great for those who don't have the walnut blasting wand and adapter HERE. It's located in our R56 articles "Tech Info" section under Turbocharged Engine Carbon Cleaning. The method does utilize an engine cleaner. It's a little time consuming, but works well. This method is used a lot for carbon cleaning VW's and Audi's as well.
+1 on this article. It is an EXCELLENT walkthrough. I bought my media blaster at Harbor Freight for $90, and ordered the vacuum adapter and wand. Everything I read says that the Seafoam does nothing. I can vouch for the carbon blast as being effective at 60K miles with a spark plug change.
The absolute cheapest is carb cleaner, picks, brushes and elbow grease. Someday if I can afford new gadgets might try some of the linked stuff.
Check out our article. It doesn't require you purchase any carbon cleaning tools (such as the media blaster and wand). It should be very helpful to you and other individuals who do not have the budget or just don't want to purchase the tools. This is also the method done before these types of tools were available.
Nice article. My cost was about $50 and I've done it twice now. Once two years ago for the intakes and now both intake and exhaust. About the only thing I bought was carb cleaner. Don't really need to spend much money.
That is not implied in the article, as the repair is performed with the intake removed and all cleaner is removed from intake ports before reassembly. Questions for turbocharger safe cleaners are best kept for the manufacturers of the cleaners. I'd advise you to check the brand's use terms for the cleaner.
just curious, but has anyone tried dumping a bunch of seafoam in with the valves closed and letting it sit overnight? then vacuum out and repeat on the other valves?
nothing you can spray/pour/dump/paste is going to magically 'peel off' carbon build up..its baked on carbon..its hard AF..even a pick and brush dont make it easy
