I found the dtc!!!!!!!
Old Oct 24, 2015 | 07:44 AM
BucksCountyR57's Avatar
BucksCountyR57
Ok so I was on my way up to Bloomsburg with the wife today and I got the code
P0300 $07E8
I went on to list the 2nd and 3rd cylinder and went into half power mode. I was not in a place where i could pull over for the next few miles so I had to drive a bit.....well...it started flashing. Having the scanner still plugged in I ran another test... this time I saw it read misfires on all cylinders and started slowing way down. I pulled over needless to say and the car was at a rock steady idle. Tiny bit high but still...no shuddering, hesitation, shaking etc., Desperate to get to where i needed to go...I saved the data on my computer and cleared the code. The car ran fine. Now that I am at Bloom....I am in the library researching some ways to diagnose whats causing the misfire. I am trying my best to use the kiss method (Keep it Simple Stupid).
- Spark Plugs?
- O2 sensors?
- Coil packs?
Also this light came on after about a solid hour and 10 min of highway driving. I was getting about 33-35mph too.
Anyone have this problem before? I have limited time here at the University so I figured I would post about it and then research on here to see if anyone has had that problem.
Old Oct 24, 2015 | 03:54 PM
JR2012IBB's Avatar
JR2012IBB
Sorry that I cannot tell what year/model you have but I can share that my 2012 Justa was a mess with all kinds of issues due to a marginal battery. I got it running with a jump start from AAA and figured all was good as it idled fine and under light load all was OK.
I never got the codes but my dash went 'blank', engine was a mess over 2.5K RPM and all in all it was running like crap for the duration of my ride home from work. I kept going figuring each mile was one less on the tow truck.
Massaged it home and figured given the issue started with the battery I'd start there. Changed it out, reset the clock and it's been fine since. I know modern cars with weak batteries act odd but this was a whole new level for me. From now on the battery will be a maintenance item.
Old Oct 24, 2015 | 04:54 PM
BucksCountyR57
I have a 2011 R57 MCS with the N18 engine. Out to dinner right now (took the truck). I plan on elaborating on the subject when the wife and I get back home. I even have pics of the codes and plugs I took out.
Old Oct 24, 2015 | 05:19 PM
cerenkov's Avatar
cerenkov
It could be the high pressure fuel pump. If you can monitor fuel rail pressure using a smart phone app that can help diagnose.
Old Oct 24, 2015 | 05:45 PM
BucksCountyR57
Yes! I have read that too. Can you elaborate on the tolerances the HPFP needs to be within?
Old Oct 24, 2015 | 06:18 PM
BucksCountyR57
The hunt for the P0300 cause
Ok! I made it home with no trouble actually. Here is how today went.
I was on the road with my wife to Bloom and I got the half engine power light. Luckily I brought my scanner with me and hooked it up while driving. I scanned and it spit the P0300 codes out to me that you see below. Car said it was find to drive but moderate my speed, so I did. About 10min went by when the actual CEL light on the speedo lit up and blinked at me. I ran the code again. This time around it was all cylinders and the car slowed waaaay down.
I ended up pulling over to read this and think things through.
My wife was a key note speaker at a conference at Bloomsburg University today and we needed to go just 4 more miles. Desperate, I saved the data and cleared the codes and off we went. I decided that if it happened again on the way home I would call AAA and have her flat bedded home.
I normally don't do this but during this time (the trip up) I had cruise control on and was getting great gas mileage at about 75mph. Was about to get off the highway and boom, that's when it happened...about 100miles.
From the time I cleared the codes and to the time I got to our garage door...well over 100 miles. About 120miles my wife says. And to be honest. the car performed like a champ! Rock steady idle at/around 500-800rpm acceleration was/is great, could hear the turbo spooling up and acting normal. Was like the 1st time I ever drove her :D
Now...the last time I got a light with half power I didn't have a scanner to tell what the code was so I have no idea if the code was a P0300 or not. All i know is that I was almost to where I needed to go anyway and shut the car off and by the time I got back into the car....it was fine...it cleared.
Since that time (about a week ago from today 10.24) I cleaned the plugs and ordered new ones. The one I cleaned and scrapped were pretty dirty but I got them to look pretty new. So I put them back in and this is what I got below.
Before I load those. My plan of attack is as follows:
  • Change Spark plugs with the new ones that came in the mail the other day.
  • Pull vanos’ and clean them 117-18
  • Pull intake manifold and reinstall stock air box and stuff 130-50 while checking for carbon build up.
  • Crank sensor? 120-9
  • Since I have low milage (technically low mileage about 45K) get a fuel inject and carbon build up cleaner for the car. maybe do the old fashioned thing and scrub them myslef
  • Coil pack replacement?
  • HPFP replacement?
I am trying to keep it simple and stupid. Please let me know if anyone has any input or if anyone has been through this. BTW, the numbers above are my book marks for the bentley manual I have on hand.
Cylinder the plugs came out of are noted.
Let the fun begin
Old Oct 25, 2015 | 01:49 AM
robbo mcs's Avatar
robbo mcs
With misfires on all cylinders a bad batch of fuel, or low octane fuel is always a consideration.
Definitely change the plugs, probably the most likely cause
Old Oct 25, 2015 | 06:43 AM
BucksCountyR57
Missing Hose under intake manifold?
So I found this as I was just now doing some investigative work. It is under the intake manifold, I am guess its a part of a vacuum pump (separate from the vacuum pump booster that goes to the brakes/brake booster)
I tried feeling around inside the opening with a small zip tie so I don't hurt anything and it feels like it hits a wall unless there is a check valve there or something. This was an unexpected find so I will have to do a little more research if that is the vacuum pump and what all is supposed to be connected to it.
Here are the pics. Any insight is helpful! BTW this is a 2011 MCS N18 Engine
Old Oct 25, 2015 | 07:44 AM
BucksCountyR57
I think that may be unlikely in this situation. 93oct from a Sunoco that is not that old and right off of a main road in the suburbs of philly.
However, I did replace the plugs just now and checked out the vanos solenoids. Exhaust one looks fine. Hell I even have a small camera that I put into the valve cover....everything looks like good. No evidence of coolant in the oil either.
Old Oct 25, 2015 | 07:47 AM
cerenkov's Avatar
cerenkov
Did you have a open intake installed? Sometimes the MAF can get dirty/oily. Clean it with a little MAF cleaner can be helpful.
Old Oct 25, 2015 | 08:17 AM
BucksCountyR57
just got done looking at that, I am trying to get to the intake vanos which is a B of a location. I do have an open element intake (K&N) mass air flow looked fine.
the intake vanos tho. From what I can see with my camera i use for home duct work stuff haha (thing is coming in handy), it looks a bit dirty on the outside and some possible oil leakes. I wish it were easier to get to like the exhaust one.
Old Oct 25, 2015 | 09:27 AM
BucksCountyR57
update
Intake Vanos is too much of a pain the *** to get to so I moved on to other things. I will deal with that when I remove the intake manifold to take a look at the intake valves another day. Time to move on with the plan of keeping this simple and stupid.
I did find a Crank positioning sensor protective cover that was broken and half off. Meaning the sensor plug is exposed....but I doubt that cover even protects it from water and other grit that fell out of there when I took it off the rest of the way.
welp, time to install the stock air box back on (removed to try and get to the intake vanos) lower her down and start it up and drive it like normal. Time will tell if the codes will come back.
Old Oct 25, 2015 | 12:43 PM
BucksCountyR57
Back and out on the street
So everything went back together and took it for a test drive and came back. I ran a scan and actually got a green check LED light on my scanner. Seems to drive fine and so i left the scanner hooked up to capture some live data. I am going to download it to the computer tonight to do some analytics and see if anything is out of tolerance (HPFP, O2 sensors etc)
For now, driving it like normal!
Old Oct 25, 2015 | 05:51 PM
BucksCountyR57
OEM Tolerances??
So I sitting here, few beers deep, and I am looking at this live data I recorded but the thing is....none of this is going to mean anything to me unless I have manufacturer specific tolerances /acceptable ranges to compare it to...I think. At least that would be the easiest. Anyway...here is the data I collected at idle with a few minor revs.
Live Data
Numbers of DTCs 0
Fuel system 1 statusCL
Fuel System 2 status--
Calculated Load Value(%)19.2
Engine Coolant Temperature(¡£C)102
Short Term Fuel Trim -Bank 1(%)7.0
Long Term Fuel Trim - Bank 1(%)-0.8
Intake Manifold Absolute Pressure(kPa)93.0
Engine RPM(rpm) 698
Vehicle Speed Sensor(km/h)0
Ignition Timing Advanece for #1 Cylinder(¡£)0.5
Intake Air Temperature(¡£C)40
Air Flow Rate from Mass Air Flow Sensor(g/s)1.88
Absolute Throttle Position(%)15.7
Location of Oxygen SensorsB1S12--B2S----
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.785
Short Term Fuel Trim Bank 1-Sensor 2(%)N/A
OBD requirements to which vehicle is designedOBDII
Time Since Engine Start(sec)1193
Distance Travelled While MIL is Activated(Km)0
Fuel Rail Pressure(kPa)4700
Commanded Evaporative Purge(%)15.7
Fuel Level Input(%)54.1
Number of warm-ups since diagnostic trouble codes cleared3
Distance since diagnostic trouble codes cleared(Km)221
Barometric Pressure(kPa)100
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.987
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.055
Catalyst Temperature Bank 1,Sensor 1(¡£C)623.2
Control module voltage(V)14.206
Absolute Load Value(%)18.8
Commanded Equivalence Ratio0.999
Relative Throttle Position(%)5.1
Ambient air temperature(¡£C)20
Absolute Throttle Position B(%)15.7
Accelerator Pedal Position D(%)14.1
Accelerator Pedal Position E(%)7.1
Commanded Throttle Actuator Control(%)6.7
Long Term Secondary O2 Sensor Fuel Trim - Bank1(%)-0.8
Numbers of DTCs 0
Calculated Load Value(%)19.6
Short Term Fuel Trim -Bank 1(%)6.3
Intake Manifold Absolute Pressure(kPa)94.0
Engine RPM(rpm) 710
Air Flow Rate from Mass Air Flow Sensor(g/s)1.97
Time Since Engine Start(sec)1195
Fuel Rail Pressure(kPa)3800
Commanded Evaporative Purge(%)0.0
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.834
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.453
Catalyst Temperature Bank 1,Sensor 1(¡£C)622.7
Control module voltage(V)13.499
Absolute Load Value(%)45.9
Commanded Equivalence Ratio0.932
Relative Throttle Position(%)40.4
Absolute Throttle Position B(%)51.0
Accelerator Pedal Position D(%)29.4
Accelerator Pedal Position E(%)14.5
Commanded Throttle Actuator Control(%)11.0
Numbers of DTCs 0
Calculated Load Value(%)51.4
Short Term Fuel Trim -Bank 1(%)0.0
Long Term Fuel Trim - Bank 1(%)2.3
Intake Manifold Absolute Pressure(kPa)99.0
Engine RPM(rpm) 1816
Vehicle Speed Sensor(km/h)1
Ignition Timing Advanece for #1 Cylinder(¡£)21.5
Air Flow Rate from Mass Air Flow Sensor(g/s)4.77
Absolute Throttle Position(%)49.4
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.890
Time Since Engine Start(sec)1196
Fuel Rail Pressure(kPa)8050
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.852
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.398
Catalyst Temperature Bank 1,Sensor 1(¡£C)620.5
Control module voltage(V)14.135
Absolute Load Value(%)17.3
Commanded Equivalence Ratio0.951
Relative Throttle Position(%)6.3
Ambient air temperature(¡£C)21
Absolute Throttle Position B(%)22.0
Accelerator Pedal Position D(%)31.8
Accelerator Pedal Position E(%)16.1
Commanded Throttle Actuator Control(%)16.9
Long Term Secondary O2 Sensor Fuel Trim - Bank1(%)0.0
Numbers of DTCs 0
Fuel system 1 statusOL-Drive
Calculated Load Value(%)24.3
Long Term Fuel Trim - Bank 1(%)0.0
Intake Manifold Absolute Pressure(kPa)97.0
Engine RPM(rpm) 1431
Vehicle Speed Sensor(km/h)6
Ignition Timing Advanece for #1 Cylinder(¡£)-12.0
Air Flow Rate from Mass Air Flow Sensor(g/s)23.58
Absolute Throttle Position(%)83.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.875
Time Since Engine Start(sec)1198
Fuel Rail Pressure(kPa)8340
Fuel Level Input(%)52.2
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.550
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)0.422
Catalyst Temperature Bank 1,Sensor 1(¡£C)618.9
Control module voltage(V)14.229
Absolute Load Value(%)14.1
Commanded Equivalence Ratio1.999
Absolute Throttle Position B(%)16.9
Commanded Throttle Actuator Control(%)7.8
Numbers of DTCs 0
Calculated Load Value(%)10.2
Intake Manifold Absolute Pressure(kPa)95.0
Engine RPM(rpm) 1178
Vehicle Speed Sensor(km/h)3
Ignition Timing Advanece for #1 Cylinder(¡£)-1.5
Air Flow Rate from Mass Air Flow Sensor(g/s)2.27
Absolute Throttle Position(%)16.5
Time Since Engine Start(sec)1199
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.243
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)0.211
Catalyst Temperature Bank 1,Sensor 1(¡£C)618.4
Absolute Load Value(%)15.7
Commanded Equivalence Ratio1.040
Relative Throttle Position(%)5.5
Absolute Throttle Position B(%)16.1
Commanded Throttle Actuator Control(%)7.1
Numbers of DTCs 0
Calculated Load Value(%)14.5
Engine Coolant Temperature(¡£C)103
Intake Manifold Absolute Pressure(kPa)92.0
Engine RPM(rpm) 900
Ignition Timing Advanece for #1 Cylinder(¡£)-7.0
Air Flow Rate from Mass Air Flow Sensor(g/s)16.25
Absolute Throttle Position(%)56.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.835
Time Since Engine Start(sec)1201
Fuel Rail Pressure(kPa)7170
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.802
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.551
Catalyst Temperature Bank 1,Sensor 1(¡£C)617.1
Control module voltage(V)13.876
Absolute Load Value(%)85.5
Commanded Equivalence Ratio0.884
Relative Throttle Position(%)59.6
Absolute Throttle Position B(%)31.4
Accelerator Pedal Position D(%)40.0
Accelerator Pedal Position E(%)20.0
Commanded Throttle Actuator Control(%)67.1
Numbers of DTCs 0
Calculated Load Value(%)28.2
Engine RPM(rpm) 1801
Ignition Timing Advanece for #1 Cylinder(¡£)16.5
Air Flow Rate from Mass Air Flow Sensor(g/s)12.97
Absolute Throttle Position(%)23.1
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.905
Time Since Engine Start(sec)1202
Fuel Rail Pressure(kPa)7290
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.959
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.117
Catalyst Temperature Bank 1,Sensor 1(¡£C)614.4
Control module voltage(V)14.182
Absolute Load Value(%)46.7
Commanded Equivalence Ratio0.940
Relative Throttle Position(%)13.7
Absolute Throttle Position B(%)24.3
Accelerator Pedal Position D(%)32.9
Accelerator Pedal Position E(%)16.5
Commanded Throttle Actuator Control(%)18.8
Numbers of DTCs 0
Calculated Load Value(%)29.8
Engine Coolant Temperature(¡£C)104
Long Term Fuel Trim - Bank 1(%)0.8
Intake Manifold Absolute Pressure(kPa)96.0
Engine RPM(rpm) 1680
Vehicle Speed Sensor(km/h)12
Ignition Timing Advanece for #1 Cylinder(¡£)22.5
Intake Air Temperature(¡£C)39
Air Flow Rate from Mass Air Flow Sensor(g/s)14.19
Absolute Throttle Position(%)24.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.855
Time Since Engine Start(sec)1204
Fuel Rail Pressure(kPa)7000
Commanded Evaporative Purge(%)2.4
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.942
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.160
Catalyst Temperature Bank 1,Sensor 1(¡£C)612.3
Absolute Load Value(%)49.8
Commanded Equivalence Ratio0.980
Relative Throttle Position(%)14.1
Absolute Throttle Position B(%)24.7
Accelerator Pedal Position D(%)33.3
Numbers of DTCs 0
Calculated Load Value(%)30.2
Short Term Fuel Trim -Bank 1(%)-3.9
Engine RPM(rpm) 2287
Vehicle Speed Sensor(km/h)21
Ignition Timing Advanece for #1 Cylinder(¡£)33.0
Air Flow Rate from Mass Air Flow Sensor(g/s)12.47
Absolute Throttle Position(%)22.7
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.860
Time Since Engine Start(sec)1205
Fuel Rail Pressure(kPa)8000
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.296
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)0.254
Catalyst Temperature Bank 1,Sensor 1(¡£C)611.1
Absolute Load Value(%)11.4
Commanded Equivalence Ratio1.023
Absolute Throttle Position B(%)16.5
Commanded Throttle Actuator Control(%)7.5
Numbers of DTCs 0
Calculated Load Value(%)7.5
Engine RPM(rpm) 1430
Vehicle Speed Sensor(km/h)20
Ignition Timing Advanece for #1 Cylinder(¡£)3.0
Air Flow Rate from Mass Air Flow Sensor(g/s)1.05
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.850
Time Since Engine Start(sec)1207
Fuel Rail Pressure(kPa)4770
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.591
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)0.445
Absolute Load Value(%)17.6
Commanded Equivalence Ratio1.223
Relative Throttle Position(%)4.7
Absolute Throttle Position B(%)15.3
Commanded Throttle Actuator Control(%)5.9
Numbers of DTCs 0
Calculated Load Value(%)16.1
Engine Coolant Temperature(¡£C)105
Intake Manifold Absolute Pressure(kPa)89.0
Engine RPM(rpm) 880
Vehicle Speed Sensor(km/h)9
Ignition Timing Advanece for #1 Cylinder(¡£)1.5
Absolute Throttle Position(%)14.9
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.845
Time Since Engine Start(sec)1208
Fuel Rail Pressure(kPa)4740
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.790
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.590
Catalyst Temperature Bank 1,Sensor 1(¡£C)610.8
Commanded Equivalence Ratio0.925
Commanded Throttle Actuator Control(%)6.3
Numbers of DTCs 0
Calculated Load Value(%)15.3
Intake Manifold Absolute Pressure(kPa)91.0
Engine RPM(rpm) 878
Ignition Timing Advanece for #1 Cylinder(¡£)6.5
Air Flow Rate from Mass Air Flow Sensor(g/s)2.05
Absolute Throttle Position(%)15.3
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.830
Time Since Engine Start(sec)1210
Fuel Rail Pressure(kPa)5040
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.841
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.430
Catalyst Temperature Bank 1,Sensor 1(¡£C)610.5
Control module voltage(V)14.277
Commanded Equivalence Ratio0.904
Accelerator Pedal Position D(%)20.8
Accelerator Pedal Position E(%)10.6
Numbers of DTCs 0
Short Term Fuel Trim -Bank 1(%)-6.3
Intake Manifold Absolute Pressure(kPa)87.0
Engine RPM(rpm) 1515
Ignition Timing Advanece for #1 Cylinder(¡£)-6.0
Air Flow Rate from Mass Air Flow Sensor(g/s)26.11
Absolute Throttle Position(%)38.0
Time Since Engine Start(sec)1211
Fuel Rail Pressure(kPa)9150
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.845
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.418
Catalyst Temperature Bank 1,Sensor 1(¡£C)609.3
Control module voltage(V)13.711
Absolute Load Value(%)43.1
Commanded Equivalence Ratio0.924
Relative Throttle Position(%)14.5
Absolute Throttle Position B(%)25.1
Accelerator Pedal Position D(%)30.2
Accelerator Pedal Position E(%)15.3
Commanded Throttle Actuator Control(%)14.5
Numbers of DTCs 0
Calculated Load Value(%)27.8
Short Term Fuel Trim -Bank 1(%)0.8
Engine RPM(rpm) 1642
Ignition Timing Advanece for #1 Cylinder(¡£)24.0
Air Flow Rate from Mass Air Flow Sensor(g/s)12.22
Absolute Throttle Position(%)23.5
Time Since Engine Start(sec)1213
Fuel Rail Pressure(kPa)6560
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.012
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.012
Catalyst Temperature Bank 1,Sensor 1(¡£C)607.7
Absolute Load Value(%)51.0
Commanded Equivalence Ratio0.998
Accelerator Pedal Position D(%)34.1
Accelerator Pedal Position E(%)16.9
Numbers of DTCs 0
Calculated Load Value(%)33.3
Vehicle Speed Sensor(km/h)15
Ignition Timing Advanece for #1 Cylinder(¡£)21.0
Air Flow Rate from Mass Air Flow Sensor(g/s)20.33
Absolute Throttle Position(%)27.5
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.815
Time Since Engine Start(sec)1215
Fuel Rail Pressure(kPa)8010
Catalyst Temperature Bank 1,Sensor 1(¡£C)606.1
Absolute Load Value(%)63.5
Relative Throttle Position(%)17.3
Absolute Throttle Position B(%)27.8
Accelerator Pedal Position D(%)37.3
Accelerator Pedal Position E(%)18.8
Commanded Throttle Actuator Control(%)23.1
Numbers of DTCs 0
Calculated Load Value(%)38.4
Short Term Fuel Trim -Bank 1(%)-2.3
Engine RPM(rpm) 2810
Vehicle Speed Sensor(km/h)26
Ignition Timing Advanece for #1 Cylinder(¡£)27.0
Air Flow Rate from Mass Air Flow Sensor(g/s)27.61
Absolute Throttle Position(%)28.2
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.780
Time Since Engine Start(sec)1216
Fuel Rail Pressure(kPa)10460
Commanded Evaporative Purge(%)12.2
Equivalence Ratio (lambda)(Bank 1-Sensor 1)0.978
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)-0.074
Catalyst Temperature Bank 1,Sensor 1(¡£C)604.5
Absolute Load Value(%)12.5
Relative Throttle Position(%)7.8
Absolute Throttle Position B(%)18.4
Commanded Throttle Actuator Control(%)9.8
Numbers of DTCs 0
Calculated Load Value(%)7.1
Long Term Fuel Trim - Bank 1(%)1.6
Engine RPM(rpm) 2667
Vehicle Speed Sensor(km/h)31
Ignition Timing Advanece for #1 Cylinder(¡£)18.5
Intake Air Temperature(¡£C)38
Air Flow Rate from Mass Air Flow Sensor(g/s)4.47
Absolute Throttle Position(%)17.6
Time Since Engine Start(sec)1218
Fuel Rail Pressure(kPa)6110
Equivalence Ratio (lambda)(Bank 1-Sensor 1)1.039
Oxygen Sensor Current(Bank 1-Sensor 1)(mA)0.023
Catalyst Temperature Bank 1,Sensor 1(¡£C)605.3
Control module voltage(V)14.041
Absolute Load Value(%)53.3
Commanded Equivalence Ratio0.991
Relative Throttle Position(%)18.0
Absolute Throttle Position B(%)28.6
Accelerator Pedal Position E(%)17.3
Numbers of DTCs 0
Calculated Load Value(%)32.5
Engine Coolant Temperature(¡£C)106
Engine RPM(rpm) 2487
Vehicle Speed Sensor(km/h)36
Ignition Timing Advanece for #1 Cylinder(¡£)26.0
Air Flow Rate from Mass Air Flow Sensor(g/s)16.66
Oxygen Sensor Output Voltage Bank 1-Sensor 2(V)0.760
Time Since Engine Start(sec)1219
Fuel Rail Pressure(kPa)8400
Commanded Evaporative Purge(%)0.4
Catalyst Temperature Bank 1,Sensor 1(¡£C)605.1
Absolute Load Value(%)12.2
Commanded Equivalence Ratio1.000
Relative Throttle Position(%)6.7
Absolute Throttle Position B(%)17.3
Commanded Throttle Actuator Control(%)9.0
Numbers of DTCs 0
Calculated Load Value(%)7.8
Old Oct 26, 2015 | 05:45 PM
BucksCountyR57
Update
So another day driving her like normal and everything seems fine. I recorded some data this afternoon to keep an eye on things and even entered into Mode 6 data to take a look at the misfire count. If I can remember correctly the misfire count on:
- Cylinder 1: 0
- Cylinder 2: 2
- Cylinder 3: 4
- Cylinder 4: 1
Max number provided in the scan tool was 15,000 which I think 2.5% is the limit before a code is thrown. That would bring it to mid 300s. Well within tolerance now. Keep in mind. Any engine will have a misfire here and there. I drove home from the train station and had even less misfire counts when I got home.
According to the data, things are looking good so far... KNOCK ON WOOD!
eliseo1981
May 10, 2016 05:19 AM
CRC
Sep 14, 2015 07:27 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
