Spark plug replacement on GP / Diff fluid
Old Sep 5, 2015 | 02:57 PM
rob76turbo's Avatar
rob76turbo
Posted up a couple of other questions, but since I am running a GP, thought I would post here as well.
1. I want to replace the coil / wires / plugs with MSD components and noticed that the supercharger intercooler partially obstructs the spark plug wires. What is the best procedure to replace plugs on a JCW / GP? Do I need to remove the intercooler?
2. I have some Swepco 201 which is a very high end transmission fluid. Has anyone run it on their GP?
Thanks in advance.
Old Sep 6, 2015 | 08:03 AM
quikmni's Avatar
quikmni
I remove the intercooler to replace the spark plugs. If you haven't ever replaced the intercooler boots you might want to replace them now, with OEM boots. The MSD coil doesn't mount well unless the mounting bolts are changed. I would suggest the Screamin Demon coil instead of MSD because it mounts better. For spark plugs I suggest NGK plugs for the JCW.
I have not used Swepco fuild. I used Redline MTL.
Old Sep 7, 2015 | 12:28 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes you have to remove the intercooler to change the plugs.
Like quikmni said we don't recommend the MSD either as it doesn't fit right and doesn't make any power, it's just red.
We do have our screamin demon coils made to use with the stock bolts and sleeves so they are direct bolt on.
http://www.waymotorworks.com/screami...-coil-pak.html
Same with plug wires, no HP their just good quality wires will work fine
http://www.waymotorworks.com/wmw-per...lug-wires.html
Or we have a kit with everything
http://www.waymotorworks.com/wmw-ignition-package.html
09R56
Nov 16, 2022 10:49 AM
blackie
Jan 18, 2017 09:56 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
maniacalmorgan
Aug 19, 2015 08:44 AM
yashmack
Aug 15, 2015 10:16 AM
