Coolant Problems
Old Apr 5, 2016 | 05:25 PM
ubertev's Avatar
ubertev
Coolant Problems
Hello all. I am new here. Bought my Mini Cooper Base used from a private seller two weeks ago. The car runs excellent and no complaints. Just out of curiosity, I opened the engine bay last Friday and I noticed that the coolant level was really low. No problem. Went to my local Autozone and picked up some blue coolant (learned that here ) When I filled up the reservoir I drove home which took me 30 minutes. Checked it again and coolant is damn near gone. Looked down into the bay and I see the fluid has leaked down onto what appears to be the transmission (couple of inches below the engine and offset to the right). Can anyone tell me what part possibly needs to be replaced? I have read up and saw the problems related to the thermostat housing. Also, how much could this possibly cost to replace if I take to a mechanic?
Old Apr 5, 2016 | 05:31 PM
AZdsrt's Avatar
AZdsrt
As you suspect, most likely the thermostat housing. As far as cost, why don't you just go ahead call some local Mini independents for cost estimates..
Old Apr 5, 2016 | 06:10 PM
son-of-mini's Avatar
son-of-mini
Look around that thermostat housing. It may be a cracked housing, or just the seal where the sensor connects to the thermostat. The sensor connection is easily repaired. Replacing the thermostat is a bigger job.
Old Apr 6, 2016 | 07:43 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I agree, thermostat. It's a plastic component and they typically start as a hairline crack, which can pool on top of the transmission. Yours seems to be a pretty significant leak and should be inspected and replaced if it is the culprit. What R56 do you have?
888.280.7799 | 6am - 5pm PST
Accessory Products
Feb 21, 2016 07:23 PM
Feb 19, 2016 02:52 PM
Feb 18, 2016 10:47 AM
Austinsynthetics
Feb 17, 2016 11:09 PM
Feb 16, 2016 11:07 AM
