R56 water pump replace question.
Old Mar 11, 2016 | 07:34 PM
Doc Pain's Avatar
Doc Pain
long story short -- i didnt have radiator filled to capacity--it got hot/showed lo level/ water pump blew seal [i assume..] saw fluid from weep hole. After removing pump i find the following inside where impeller stays [bits i thought were a seal but end up being fragments of black plastic water pipe/ 1 o-ring].
Question: where does o-ring go?? 2. am i going to have to replace the plastic water pipe insert??[i.e. pipe end is not flush aprox. 2mm of end knocked off over 80% of diameter].
tried searching FAQs and didnt find anything similar. this is 2009 S / 2nd production run vehicle.
Old Mar 14, 2016 | 09:01 AM
Its here: 11537589713 Water Pipe
https://www.northamericanmotoring.co...8-no-heat.html
aparrado
Jan 7, 2019 08:30 AM
Tundrageek
Mar 12, 2016 10:55 AM
Minimini1212
R60/R61 Stock Problems/Issues
Mar 11, 2016 02:01 PM
Minimini1212
Mar 11, 2016 01:18 PM
Minimini1212
Mar 10, 2016 09:24 PM
