JCW Pls help :( Clubman needs a new engine and water pump at 50k miles????
Just a heads up you're in the wrong subforum, you have a second generation this is for third. Just letting you know as you may get some better answers over there (2nd Gen page).
EDIT: It is unfortunately probable that you did the damage by driving your car around almost 2000 miles with the valve cover gasket leaking. Water and coolant don't compress easily, and if they enter the combustion chamber they are going to destroy your engine.
EDIT 2: DON'T EVER DRIVE A CAR THAT SAYS OIL PRESSURE LOW, immediately pull over and have it towed.
No problem, I would ask people to see if you could find a certified independent mechanic who could do the replacement engine you will likely see a huge price drop from the dealers quote. Also, a used engine may be another way to decrease the price. It is an option that obviously has positives and negatives. Finally, feel free to pm me if you have other questions about how engines work or what warning lights mean.
If you need any help you can PM me/
Some info here:
https://www.northamericanmotoring.co...-it-worth.html
Some info here:
Some info here:
Some info here:
Feb 16, 2016 08:26 AM
