R50/53 Need opinion
Need opinion
Found a set of 370cc injectors for sale, but that's based on 3bar. Good price with warranty. I've got a few mods. Would it be ok to run them. My
Mods are: 16% pulley
M7 header & cat delete.
CAI. And is tuning necessary
Someone correct me if I'm wrong, but all injectors do is increase the fuel volume POSSIBLE to be injected per combustion stroke. There's no reason to get higher capacity injectors unless your stock injectors can't keep up with the air you're sucking into the engine. Here's some information on their maximum power ratings if you're trying to figure out if it's necessary.
Well I've read a few posts on here about doing some mods, and what I can figure out is that the
Stock injectors can't keep up, running at 90-100% duty cycle. After i did the header and cat delete I'm afraid I'm running lean and the injectors won't keep up so I figured I would do a larger cc injector and then soon after get it tuned. Now I know this kinda makes sense but correct me if I'm wrong but don't criticize me.
Oh no one was criticizing me I jus didn't want anyone to, but I do know the differences in 2004 and 2005 minis was the 05 had a limited slip diff and bigger injectors factory
I'd still put your money else where before injectors unless you've definitely got a problem. Its not going to magically add horsepower unless you feel a dull in acceleration or a flat spot/ stutter
Get some sway bars or suspension stuff. Check out my thread for options
That's why I was asking about injectors because it has a slight studder and hesitation when in boost, what size are the factory injectors. And as soon as I get it tuned in going to do some suspension work to stiffen it up
Got to be careful about injector specifications. There is the length of the injector between O-rings, the tip length, connector type and spray pattern & dynamic flow rate to consider besides just the static flow rate. The R53 injectors are dual cone spray (with I think a 20 deg. spray angle separation) to minimize port wall wetting. A single cone probably works fine at WOT, but could be a problem at cold start or cold idle. There is a thread here somewhere that describes all of the different injectors that have good compatibility with the R53 engine and that have been used successfully. I plan to use the Volvo 380CC injectors with a 17% pulley, ported head and a few other mod's.
If you use the 370CC injectors with mild mod's and no tune, The fuel adaptives should adjust properly for closed loop operation, but you'll probably still run overly rich in open loop (high load) conditions, as the standard calibration with 340CC injectors is already very rich in the overboost portion of the fuel map. You then run the risk on extremely hot days of reaching the rich misfire limit, not to mention very poor fuel economy.
Here's the thread I mentioned. Very long but gets into specific part numbers that are usable.
https://www.northamericanmotoring.co...jectors-6.html
Also, the idea that the stock 340CC injectors can't keep up with the mod's that you have I think has been overstated. There are folks running stock injectors and tune with 17% pulleys without a problem. Your added exhaust side improvements only very slightly increase the air mass flow through the engine (I'll look it up later tonight as I have some hard data on that but I think it's < 2%) that would result in slightly leaner open loop operation than stock, which is already very rich. From what I've read, it's when you port the head and/or add a bigger cam that you hit the limit of the stock injectors. Since you're de-catted, you don't have to worry about the pre-cat temp. limit that defined the stock fueling at WOT. The only way to know for sure what your combination of mod's needs is to run a wide range O2 sensor and/or thermocouple in the header collector or primary runners, otherwise you're just guessing.
Thank you for your info it has been very helpful, I've been doing a ton of research on injectors and found that the vw injectors will work they are the 4 hole design and shouldn't hit the wall between ports very much at all, and they are 380cc @ 3bar. I'm still
Doing as much research as I can before i buy a set. And another benefit they are the ev1 connector style. Even though it's not hard to change over to the ev4(considering I have a set of them out of a camaro and they are 370cc)
Some great info. Always nice to read something you post. When's the next installment of the origins of the Tritec coming out?
Sir Ric
Feb 14, 2016 07:45 AM
